I image in Bortle 3 skies, and others have said, the beauty of dark skies is that you just don't need to use a filter. Moonlight is the only "enemy"! (and these days I usually don't bother when the moon is large).
I mostly use a similar, but full frame, OSC with my RASA 11 - the ASI2400MC Pro. I have a couple of dual narrowband filters - the Optolong L-eNhance which works well on my 8 Edge HD, and an IDAS NBZ, which is better for my the RASA. Both are good filters. But I normally shoot broadband (i.e. no filter), and use a clear glass filter to maintain my backfocus distance. This is essential for me using the RASA at F/2.2, and may not be such an issue for you, but it's recommended. I have one clear glass filter each from the two manufacturers above, so that they have the same glass thickness.
I enjoy shooting all sorts of objects in broadband, including most of the favourite narrowband emission nebula targets (see my Astrobin). I'm only really tempted to use narrowband on the faintest of targets, often using it to enhance a broadband shot. Really faint OIII will often just not be visible at all (e.g. see my Sh2-129 with Barnard 150 shot - no squid is visible at all). But to be honest, the really faint ones like this are probably easier to pull out with mono and very narrow filters, and with broadband you can pull out all sorts of intermediate hues of dust and so on.
With this approach, you're using "natural" colours. If you want to produce bright false colour palettes emulating the mono / narrowband shots, you can do this using the dual narrowband filters, at least up to a point, but I'm just not so interested in doing this.
re: Moonlight - the filter will help, but mostly only with the Ha. I find that moonlight washes out the OIII signal (L-eNhance has a fairly wide 20nm band for OIII and Hb making this worse, but I still don't get much better results with the NBZ and its 10nm band).
re: L-Pro - this is a broadband filter. it attempts to remove some of the light pollution in broad bands. I can't see any circumstances where this is really going to give you any advantage at all in dark skies.
