roelb, here is how I am currently 'running' SeeStar on my Windows computer: https://github.com/Genymobile/scrcpy
This application mirrors Android devices (video and audio) connected via USB or over TCP/IP, and allows to control the device with the keyboard and the mouse of the computer. It does not require any root access. It works on Linux, Windows and macOS.
You need to connect your phone to your computer and set your phone to enabled USB debugging. Not as good as using BlueStacks but it is the best solution I have found so far.
Thanks Cey. I can also use the Windows Phone Link app which displays the phone and I can use the mouse & keyboard.
The connection to the phone can be made using WiFi.
With the newest Seestar updates (app V.13 and latest firmware) I have experienced that it is now possible to use the app over the home WiFi.
As usual to start with the Seestar one must change the home WiFi to the S50 WiFi.
But once the S50 is ready, I can now set my phone back to the home WiFi and use the app as usual.
So full control of the S50 via home WiFi without using the S50 WiFi signal.
I will also check your proposal because I have plenty of time with the clouds rolling over since mid October
Edited by roelb, 21 December 2023 - 08:59 PM.
