OK, thanks. Wolf 3s is green phosphor? Will the Wolf 3s work in prime focus mode with a c-mount to 1.25 inch adapter (+all the needed filters)?
Yes, green. So is the Zeiss. I and all the other observers I know who use it don't find the green intrusive at all. In fact, we find one forgets it after twenty seconds and also doesn't have a coloured memory of the image.
Works fine in prime focus, just like an OVNI - screw off the lens, put on 1,25 inch adapter such as the one made by Baader. This is totally unproblematic with the Wolf 3. With the Zeiss device, with its recessed mount, you need an adapter that is slightly longer than the Baader one and doesn't have a collar around the male C-mount thread, this one for instance from TS: https://www.teleskop...uf-C-Mount.html
Whether H-alpha filters will then do you any good depends on how fast you can make your system. f/4 and slower increasingly kills the nebulae. Globs and galaxies (at least the parts emitting in red/infrared; Gen2+ has low performance in the blue) remain good.
A warning: Try before you buy. These are second-hand devices that can be 15 years old or more. Sellers are often inheritors who don't know anything about them and can't gauge whether they show a good image of the sky - especially not what happens with an H-alpha filter. If you have a return option, fine. But if not, I'd insist on trying it out under the night sky and putting an H-alpha filter on. When last on the market, a Wolf 3 with lens cost about 3400 Euros. A normal price nowadays would be around 800.
CS, Christopher
Edited by C.Hay, 22 June 2023 - 07:39 AM.
