This has pretty nice spherical correction, especially in green and red, and pretty decent control of chromatic aberration for a fast doublet achromat. I also see a central zone and a small turned down edge, but nothing too objectionable considering that this was likely meant to be used as a finderscope.
Overall, I'm very pleased with the way this scope turned out, and I thank my friend who generously loaned me this scope for testing purposes.
If any of you know more about this scope, please fill me in. There's very little about it on the internet.
Scott,
As a finder used at low magnification it is fine but in reality it is not that good. It is zoney with large hill and an even higher one in the center along with a turned edge. This causes the color correction to be off as well since the white light image is showing blue not focusing anywhere close to the other colors. The bottom line is that this a 1/2 wave or worse over wave front.
The concept that I keep seeing getting missed is that a lens can have a perfect Strehl or very good Strehls at a number of given wavelengths but this is only looking at the spherical aberration at those wavelengths. It does not tell you anything about the over chromatic aberration which can be terrible. I can made a very long focal length singlet and it will have perfect a Strehl from the blue all the way to the red. So if you just use these test results you would say the lens is excellent but the chromatic aberration is huge ! Here is an example and the longitude chromatic plot shows it. Over all this lens as couple of waves of chromatic aberration.
Here is another example of 3" f/15 achromat. It has near perfect Strehl in the green of 0.999. So you would think all is well, but if you calculate the total Strehl over the visible range it drops to 0.57 which is the second calculation and that is if the lens is made perfectly. Start throwing zones and turned edges in and both spherical and chromatic get even worse. So again the bottom lines is that you can not say a lens is good by only calculating Strehls from single wavelength DPAC images and then say the lens is "good" You need to look at the chromatic correction as well.
- Dave
Edited by DAVIDG, 09 July 2023 - 11:31 AM.
