Unitron 3” vs Questar 3.5
28 replies to this topic
#26 RMay
RMay
  • Loc: NorCal
Posted 18 September 2023 - 09:34 AM
A 3.5” Questar with Zerodur mirror and BB coatings showed a tiny bit more on Jupiter on a very calm night. With worse seeing, the long focus achromat without a central obstruction showed a sharper, stable image more often.
When comparing my A-P EDF 130 f/6 with my Questar 7, I was surprised by how much cleaner, free from CA, the startest of the Questar was.
All Questars are magical, but some were made with a bit more magic in the mix than others, n’est ce pas?
Ron
  • Erik Bakker likes this
#27 kansas skies
kansas skies
  • Loc: The middle of nowhere, USA
Posted 18 September 2023 - 01:16 PM
While I don't own a 3" Unitron, I do own a 60mm 114 Unitron. I also own both 80mm f/15 and 102mm f/15 Celestron/Vixen refractors. I've taken many opportunities to compare the optical qualities of each scope with my 3.5" Questar Standard, and they all seem to perform as expected for what they are. In my opinion, they all exhibit extremely excellent optical performance, but each in their own way. When used independently, they all seem to be pretty much free of any false color. When compared with the Questar, however, the Unitron seems to lean ever so slightly toward the yellow end of the color spectrum, while the Vixens seem to lean ever so slightly toward the blue (which somehow I find to be more pleasant). As for optical performance, when conditions allow, I can increase magnification on every scope to the point where the image is almost too dim to see and the images don't seem to break down.
Still, larger optics of equal quality will show more fine detail. They also gather more light for a brighter image. When comparing my 80mm Vixen refractor to my Questar, the Questar goes a little deeper and shows a bit more detail. As an example, I had both out looking at Saturn a few days ago and although both displayed images were similar, I had to use my Questar to confirm the placement of a couple of moons that I thought I was seeing with the refractor. On the other hand, the double-double, Epsilon Lyrae, always looks to be a little nicer and more pristine in a refractor due to the almost complete lack of the first diffraction ring that is quite evident in a Maksutov.
As for my 102mm refractor, it's in a class all its own and not a fair comparison to any of these others. Still, at 125 to 150 lbs, along with many trips required to set up, it doesn't see nearly the amount of sky-time as the rest (the Questar wins hands-down in this respect).
Bill
#28 Erik Bakker
Erik Bakker
  • Loc: Netherlands, Europe
Posted 18 September 2023 - 01:58 PM
Ron
My Questar 7 with Pyrex mirror and BB coatings had the finest optics I've ever seen, along with a 55 f/8 and 102 f/8 fluorites I had. But to achieve that at 178 mm of aperture in a compound optical system is nothing short of a miracle. I once had it on a test stand of a custom manufacturer of ESO and satellite optics, avid amateur astronomers themselves. The owners were totally astonished by he perfection of the Airy disc in focus and how the approach to that point from both inside and outside focus was. They were shouting at others in the factory to come and see this perfection for themselves. If it would not have been for oxidation at the edge of the primary mirror, I would have owned that Q7 to this day.
#29 RMay
RMay
  • Loc: NorCal
Posted 18 September 2023 - 03:54 PM
Like Aladdin’s magic lamp and King Arthur’s sword, I’ve indeed read of the many mystical powers associated with your Q7.
(Ok, no more fooling’ around…) 😉👍👍
It must have been amazing… the Seven I looked through back in 1983 was in my mind like looking through an Apollo window; I can only imagine how special indeed yours was - to you and all who spent time with it.
Best,
Ron
