Public release of the Mitchell Anonymous Catalog
6 replies to this topic
#1 Akarsh Simha
Akarsh Simha
  • Loc: Sunnyvale, CA, USA
Posted 26 July 2023 - 02:37 AM
Hello folks,
With the generous permission of Larry Mitchell, I'm pleased to provide a publicly available and freely re-distributable copy of the Mitchell Anonymous Catalog.
For those not familiar, this is a catalog created by Texas amateur astronomer Larry Mitchell through manual inspection of the Palomar Optical Sky Survey images, I believe in the mid- and late 1990s. At a time when larger professional catalogs like the PGC did not exist, Larry painstakingly cataloged a whopping 117000+ objects that were candidate galaxies. This data was made available as part of the MegaStar planetarium software. After Willmann-Bell shut down, Emil Bonnano, the author of MegaStar, made a public distribution of the software available to amateur astronomers for free -- so one could access this catalog through MegaStar5. Now Larry has permitted redistribution of his monumental work in and of itself. Here are the terms under which we are presenting this work:
The Mitchell Anonymous Catalog is provided here with written permission from Larry Mitchell.
The Mitchell Anonymous Catalog as provided here may be redistributed freely for both commercial and non-commercial purposes. The catalog data may be reformatted as needed, but shall not be altered in content, although additional information from other sources may be added while explicitly mentioning that they are not part of the original catalog. Credit must be attributed to Mr. Larry Mitchell. Copyright © 1996-2023.
The catalog and the data herein are provided on an "AS IS" basis with no warranties of any kind implied. The licensor and the processors/providers of this data/information expressly disclaim all warranties and conditions including any that would normally be implied, to the extent permitted by law. Use of this data is done at your own risk.
The MAC catalog can be accessed in this Google Spreadsheet, which you can download and save as CSV and reformat as needed:
https://docs.google....dit?usp=sharing
A side note: Since this was a catalog compiled by Larry looking at photographic plates manually, there are some cases of plate-artifacts as well as tight double stars being cataloged. If one wishes to confirm an object, I recommend cross-checking the catalog positions against multiple survey plates and deeper surveys like Legacy or PanSTARRS where available. Not all valid MAC objects, I believe, have modern designations as yet! At least there are many bona-fide fuzzy objects that do not have designations in SIMBAD.
Hope the deep sky imager and visual observer community finds this release useful, and thanks goes to Larry for making it available to all of us!
  • Inkswitch, scottinash, Ptarmigan and 9 others like this
#2 Herodotus
Herodotus
  • Loc: Fruita, CO B 3
Posted 27 July 2023 - 05:12 PM
  • Akarsh Simha likes this
#3 Mercure
Mercure
  • Loc: France
Posted 28 July 2023 - 04:01 PM
Many thanks to you and Larry Mitchell for this generous offer.
This is an astounding work!
#4 KidOrion
KidOrion
  • Loc: East Coast Light Pollution Hell
Posted 30 July 2023 - 12:56 AM
A phenomenal accomplishment, and of immense value to amateur astronomers. Thanks to you both for bringing it to us!
#5 Ptarmigan
Ptarmigan
    Lagopus lagopus
  • Loc: Arctic
Posted 14 August 2023 - 08:52 PM
#6 yuzameh
yuzameh
Posted 15 August 2023 - 02:58 PM
I've just done a quick and dirty check against other galaxy catalogues.
Of the roughly 117,000 objects in this list 77,000 are in the PGC and 69,000 are in 2MASX.  Of course those postdate the above MACcat, yet the latter does contain some already published galaxies (eg KUG).
There will of course be overlap between those latter two, a quick crossmatch of those reveals nearly 600,000 in common, however those are all sky and not just visible from the North.  I can assure you though that not every 2MASX galaxy matches every PGC one, nor vice versa.  Not every PGC object is a galaxy either, it at times includes bright star halos.  However, the MAC which was not done via machine densitometer mapping of the glass plates is not likely to have any of those.
It doesn't match any nebula catalogue to speak of, so likely they are all galaxies and a smattering of unresolved "pairs" of stars and plate defects.
It appears that there is no means of crossmatching more than several hundred objects at a time against NED so I haven't been able to check that.
Anybody interested enough should be able to update some of these objects using various galaxy catalogues via CDS Xmatch.  I used a 3 arcsecond radius on the central position.  In some cases this will provide morphological types, and objects that are in pre galaxy zoo based SDSS galaxy morphological catalogues that people have been able to give a type for (eg Sc, Sb, E, etc) will be the more realistic candidates for viewing and/or imaging.
#7 yuzameh
yuzameh
Posted 15 August 2023 - 03:07 PM
Here's an example of the KUG one (which only has a small number of objects).  Their MAC ID and RA and Dec are given, then the KUG data.  The first column is the angular distance in arcseconds between the input MAC coordinates and the KUG coordinates (all crossmatched at J2000 by default, not matter what the columns say, CDS fixes this on the fly to J2000, or rather already has the big catalogues indexed on J2000 internally).
Notice it gives B mags, or more properly the magnitudes on POSS blue sensitive glass plates, sometimes called "photographic magnitude".  I've always personally found B mag from glass plate measures fairly comparable to the actual visual extended object magnitdue, whereas V mag values when NOT given as surface brightness or other extended object way are always too bright compared to reality.  Think the V mag of M33 and how it actually looks through a telescope at low power if you don't follow what I mean.
Copy paste the following into a text file, save it as kug.csv, and it should autoload into excel just by double clicking on it.  Make sure you don't end up saving it as kug.csv.txt if you use something useless like notepad.  EDIT : DANG!  beware line-wrap!
angDist,mac,ra,dec,_RAJ2000,_DEJ2000,recno,KUG,RAB1950,DEB1950,TYPE,u_TYPE,Amaj,Amin,Bmag,UVX,n_INDEX,Name,_RA.icrs,_DE.icrs
2.511222,1333+3433,203.2626667,34.55,203.26257,34.550693,5885,1330+348,13 30 47.3,+34 48 25,Sp,,0.4,0.1,17.0,L,,,13 33 03.0,+34 33 02
0.895294,0812+3611,123.24375,36.19833333,123.243472,36.198226,2119,0809+363,08 09 43.5,+36 20 57,Sp,:,0.4,0.2,16.5,M,,,08 12 58.4,+36 11 54
2.841351,1239+2736,189.8339583,27.60444444,189.833099,27.604652,5423,1236+278,12 36 52.0,+27 52 45," C",:,0.4,0.3,16.5,M,,,12 39 19.9,+27 36 17
1.397054,0001+0900,0.263375,9.008611111,0.263559,9.008954,8074,2358+087,23 58 29.5,+08 43 50,Sk,:,0.4,0.3,16.0,L,,,00 01 03.3,+09 00 32
1.879694,1457+4939,224.3901667,49.65861111,224.389388,49.658475,6652,1455+498B,14 55 54.7,+49 51 29,Sp,,0.7,0.3,17.5,L,,,14 57 33.5,+49 39 31
0.157799,0242+3613,40.69283333,36.21972222,40.692836,36.219766,1261,0239+360,02 39 41.0,+36 00 27,Sp,:,0.4,0.2,16.5,L,,,02 42 46.3,+36 13 11
2.955406,1032+4019,158.0211667,40.31722222,158.02082,40.316445,3840,1029+405,10 29 09.6,+40 34 26,Sp,:,0.6,0.1,17.0,L,,,10 32 05.0,+40 18 59
2.607376,1240+2733A,190.192625,27.56555556,190.193068,27.564947,5433,1238+278A,12 38 18.6,+27 50 21," C",:,0.5,0.3,16.5,L,,,12 40 46.3,+27 33 54
0.858804,1240+2733B,190.206,27.56361111,190.205953,27.563846,5435,1238+278B,12 38 21.7,+27 50 17,Sp,:,0.2,0.1,17.0,L,*,,12 40 49.4,+27 33 50
1.528824,0002+1253,0.5171666667,12.89166667,0.516735,12.891724,8098,2359+126,23 59 30.2,+12 36 48,Sk,:,0.4,0.2,17.0,L,,,00 02 04.0,+12 53 30
1.155109,2236+1430,339.2106667,14.51583333,339.21085,14.515566,7250,2234+142,22 34 23.0,+14 15 21," ?",,0.4,0.2,16.0,L,,,22 36 50.6,+14 30 56
2.187905,0002+2321,0.625,23.35055556,0.624653,23.350038,8104,2359+230,23 59 56.0,+23 04 18,Sp,,0.4,0.2,16.0,M,,,00 02 29.9,+23 21 00
1.124163,0002+2653,0.6832916667,26.89638889,0.683242,26.896698,3,0000+266,00 00 10.0,+26 37 06,Sp,:,0.3,0.1,16.5,L,,,00 02 44.0,+26 53 48
0.584521,1458+4811,224.5591667,48.19222222,224.559048,48.192364,6654,1456+483,14 56 32.8,+48 23 29,Sp,,0.6,0.1,17.0,L,,,14 58 14.2,+48 11 33
1.204533,0817+2408,124.2860417,24.14277778,124.286169,24.142464,2186,0814+242,08 14 10.0,+24 17 52,Sp,,0.7,0.1,16.5,M,,,08 17 08.7,+24 08 33
0.843279,1241+1839,190.3291667,18.65666667,190.329184,18.656433,5441,1238+189,12 38 49.2,+18 55 50," ?",,0.2,0.2,16.5,L,,,12 41 19.0,+18 39 23
0.700542,1241+2255,190.365375,22.93055556,190.365379,22.930361,5442,1238+232,12 38 58.9,+23 12 16,Sp,,0.5,0.2,16.0,L,,I3659,12 41 27.7,+22 55 49
2.149209,1241+2628,190.262625,26.485,190.261958,26.485002,5436,1238+267B,12 38 34.9,+26 45 33,Sp,:,0.3,0.3,17.0,L,,,12 41 02.9,+26 29 06
2.501577,1459+4759,224.9008333,47.99583333,224.900068,47.996303,6661,1457+481,14 57 54.6,+48 11 39,Sp,,0.4,0.2,16.5,L,,,14 59 36.0,+47 59 47
2.485724,2237+2022,339.2855417,20.37833333,339.285557,20.377643,7254,2234+201,22 34 43.6,+20 07 04,Sp,:,0.5,0.2,17.0,L,,,22 37 08.5,+20 22 40
2.895857,0004+0813,1.196375,8.231388889,1.196289,8.230589,31,0002+079A,00 02 13.2,+07 57 08,Sp,:,0.5,0.2,16.0,L,,,00 04 47.1,+08 13 50
0.710858,0004+1548,1.159958333,15.81666667,1.160162,15.816691,28,0002+155,00 02 04.4,+15 32 18,Sp,:,0.3,0.2,16.5,L,,,00 04 38.4,+15 49 00
1.417853,1500+4939,225.1908333,49.66138889,225.190674,49.661769,6669,1459+498,14 59 07.8,+49 51 31,Sk,:,0.3,0.3,17.0,L,,,15 00 45.8,+49 39 42
1.282605,1033+3730,158.3471667,37.5025,158.346889,37.50278,3860,1030+377A,10 30 30.2,+37 45 39,Sp,:,0.3,0.2,17.5,L,,,10 33 23.3,+37 30 10
1.067143,1242+2552,190.5752917,25.86916667,190.575621,25.869158,5456,1239+261,12 39 50.2,+26 08 35,Sp,,0.3,0.2,16.5,M,,,12 42 18.1,+25 52 09
2.186227,1033+4014,158.4970417,40.24083333,158.496671,40.240296,3866,1031+404,10 31 04.3,+40 29 55,Sp,,0.5,0.2,16.0,L,,,10 33 59.2,+40 14 25
1.185058,0005+1714,1.28775,17.23833333,1.287546,17.238068,38,0002+169,00 02 34.9,+16 57 35,Sp,,0.7,0.2,16.5,L,,,00 05 09.0,+17 14 17
2.288929,0005+2733,1.400708333,27.55805556,1.400071,27.557764,43,0003+272,00 03 01.6,+27 16 46,Sp,:,0.3,0.1,16.5,L,,,00 05 36.0,+27 33 28
1.255146,0005+2738,1.378333333,27.63555556,1.37794,27.635544,42,0002+273B,00 02 56.3,+27 21 26," C",:,0.2,0.1,16.5,L,,,00 05 30.7,+27 38 08
2.851266,1501+4922,225.4174583,49.37416667,225.416297,49.373931,6676,1500+495,15 00 01.6,+49 34 12,Sp,:,0.7,0.7,16.5,L,,,15 01 39.9,+49 22 26
2.597410,0245-0440,41.30508333,-4.681388889,41.305325,-4.682069,1278,0242-048,02 42 43.2,-04 53 32,Sp,:,0.4,0.2,16.5,L,,,02 45 13.3,-04 40 55
1.400134,0245-0535,41.46975,-5.588055556,41.469852,-5.588431,1279,0243-057,02 43 23.4,-05 47 53,Sp,:,0.7,0.2,16.0,L,,,02 45 52.8,-05 35 18
1.014475,1244+2446,191.241,24.77166667,191.241146,24.771418,5477,1242+250,12 42 30.0,+25 02 41,Sp,,0.4,0.1,16.5,M,,,12 44 57.9,+24 46 17
0.618262,1244+2954,191.012375,29.91638889,191.012404,29.916219,5469,1241+301,12 41 36.4,+30 11 23,Pi,:,0.6,0.3,15.5,M,,,12 44 03.0,+29 54 58
1.685246,0429+7313,67.43995833,73.225,67.439846,73.224533,1588,0423+731,04 23 49.0,+73 06 52,Sk,:,1.0,0.1,17.0,L,,,04 29 45.6,+73 13 28
1.555920,2241+0759,340.4270833,7.994722222,340.427219,7.995133,7282,2239+077,22 39 11.9,+07 44 00,Sp,:,0.5,0.1,16.5,L,,,22 41 42.5,+07 59 42
0.864197,0008+2659,2.058875,26.99916667,2.059124,26.999075,87,0005+267B,00 05 39.4,+26 43 15,Sp,,0.4,0.1,16.5,M,,,00 08 14.2,+26 59 57
1.120079,2241+2016,340.4940417,20.2725,340.494032,20.272189,7286,2239+200A,22 39 33.1,+20 00 37,Sp,,0.4,0.2,15.5,L,,,22 41 58.6,+20 16 20
2.098049,0830+3954,127.5800833,39.90555556,127.580811,39.905723,2332,0827+400,08 27 01.0,+40 04 26," ?",,0.3,0.2,16.5,L,,,08 30 19.4,+39 54 21
2.320741,0431+0645,67.933,6.751666667,67.933315,6.751103,1603,0429+066,04 29 03.0,+06 38 42,Sk,:,0.5,0.2,16.5,L,,,04 31 44.0,+06 45 04
1.857954,1246+2159,191.6922083,21.98527778,191.691664,21.98517,5489,1244+222,12 44 17.6,+22 15 29,Sp,:,0.5,0.3,16.5,L,,I3763,12 46 46.0,+21 59 07
1.947759,0831+3024,127.9462083,30.40972222,127.946368,30.409199,2349,0828+305,08 28 42.2,+30 34 44,Sp,:,0.7,0.2,16.0,M,,,08 31 47.1,+30 24 33
1.080636,1246+2615,191.54425,26.25,191.544582,26.250038,5486,1243+265,12 43 43.4,+26 31 23,Ic,:,0.4,0.2,16.5,H,,,12 46 10.7,+26 15 00
1.273495,1247+1923,191.9615,19.38444444,191.961151,19.384315,5499,1245+196,12 45 21.7,+19 39 25,Sp,:,0.4,0.2,16.0,L,,I3784,12 47 50.7,+19 23 04
1.855000,0011+2906,2.765,29.11555556,2.765586,29.115614,127,0008+288,00 08 28.4,+28 50 15," ?",,0.3,0.3,17.0,L,,,00 11 03.7,+29 06 56
2.688346,0834+2955,128.6385417,29.91666667,128.638883,29.915981,2396,0831+300C,08 31 29.3,+30 05 18," ?",,0.5,0.2,15.5,H,,Z149.052,08 34 33.3,+29 54 58
0.868391,0012+2513,3.002458333,25.2325,3.002192,25.232512,146,0009+249,00 09 25.3,+24 57 16,Sp,:,0.3,0.1,17.0,L,,,00 12 00.5,+25 13 57
2.274104,0014+2740,3.672166667,27.67111111,3.671655,27.670671,181,0012+273,00 12 05.4,+27 23 34,Sk,:,0.5,0.2,16.5,L,,,00 14 41.2,+27 40 14
1.343502,1249+2546,192.4187917,25.7725,192.418955,25.772843,5515,1247+260,12 47 13.6,+26 02 42," ?",,0.5,0.3,16.5,M,,,12 49 40.5,+25 46 22
2.791311,0437+7409,69.494125,74.16555556,69.496569,74.16516,1606,0431+740,04 31 46.7,+74 03 51," ?",,0.5,0.4,17.5,L,,,04 37 59.2,+74 09 55
2.572122,0254+3619,43.71675,36.3225,43.715939,36.322211,1317,0251+361,02 51 44.5,+36 07 11,Sp,,0.6,0.4,16.0,M,,,02 54 51.8,+36 19 20
1.467125,1250+2515,192.7164167,25.25916667,192.716015,25.258982,5529,1248+255,12 48 24.9,+25 31 51,Sp,:,0.3,0.1,16.5,L,,,12 50 51.8,+25 15 32
1.304514,2248+1833,342.1769167,18.56444444,342.177262,18.564289,7322,2246+182,22 46 15.7,+18 17 59,Sp,:,0.6,0.2,16.5,L,,,22 48 42.5,+18 33 51
1.284064,1250+3200,192.5377917,32.00666667,192.53776,32.006311,5522,1247+322,12 47 44.2,+32 16 42,Sp,:,0.3,0.1,16.5,L,,,12 50 09.1,+32 00 23
2.398806,2251+0713,342.9174167,7.225,342.917438,7.225666,7339,2249+069,22 49 08.9,+06 57 36," ?",,0.3,0.2,17.0,M,,,22 51 40.2,+07 13 32
1.156083,0131-1230,22.91275,-12.51527778,22.912475,-12.515454,438,0129-127,01 29 11.0,-12 46 21,Sp,:,0.4,0.3,15.5,L,,,01 31 39.0,-12 30 56
2.218275,2252+1148,343.078,11.81388889,343.07741,11.813674,7344,2249+115,22 49 48.9,+11 32 52,Sp,:,0.4,0.2,16.5,M,,,22 52 18.6,+11 48 49
1.716386,1151+2348,177.984375,23.81138889,177.984021,23.811039,4530,1149+240,11 49 21.2,+24 05 21,Ic,:,0.3,0.3,15.1,M,,U6830,11 51 56.2,+23 48 40
2.921048,1152+2007,178.1197083,20.1325,178.120426,20.132952,4545,1149+204,11 49 54.2,+20 24 40,Sp,:,0.3,0.2,16.5,L,,,11 52 28.9,+20 07 59
2.059932,1347+3752,206.9578333,37.8825,206.957155,37.882702,6005,1345+381,13 45 39.4,+38 07 53," C",,0.4,0.2,16.0,M,,,13 47 49.7,+37 52 58
0.878912,1153+2033,178.4829583,20.55138889,178.482767,20.551223,4572,1151+208,11 51 21.3,+20 49 46," C",:,0.3,0.2,16.5,M,,,11 53 55.9,+20 33 04
2.713208,2258+2623,344.743875,26.38555556,344.743053,26.385395,7396,2256+261,22 56 33.4,+26 07 02,Sp,,0.5,0.3,16.5,M,,,22 58 58.3,+26 23 07
1.181217,2258+2633,344.5799583,26.55972222,344.580309,26.559626,7386,2255+262,22 55 54.5,+26 17 30,Sp,,0.6,0.2,16.0,M,,,22 58 19.3,+26 33 35
2.115327,0850+3345B,132.7304583,33.76361111,132.730296,33.764183,2555,0847+339,08 47 48.4,+33 57 06,Sk,:,0.9,0.1,16.5,L,,,08 50 55.3,+33 45 51
1.774854,0850+3454,132.7205417,34.91,132.720537,34.909507,2552,0847+350,08 47 44.6,+35 05 49,Sp,:,0.3,0.1,17.0,L,,,08 50 52.9,+34 54 34
0.245441,0850+3619,132.7279167,36.33166667,132.727861,36.331718,2551,0847+365A,08 47 44.5,+36 31 09,Sp,:,0.5,0.1,17.0,L,,,08 50 54.7,+36 19 54
0.423775,1154+2044,178.5435833,20.74666667,178.543523,20.74677,4576,1151+210A,11 51 35.9,+21 01 30,Sp,:,0.3,0.1,17.0,L,,,11 54 10.4,+20 44 48
2.119762,1349+3517B,207.301875,35.28472222,207.301183,35.284556,6019,1347+355A,13 47 00.1,+35 31 57,Sp,:,0.4,0.2,16.5,M,,,13 49 12.3,+35 17 04
1.592249,0029+0010,7.43675,0.1694444444,7.436942,0.169046,228,0027-001,00 27 11.1,-00 06 26,Sp,:,0.2,0.1,16.5,L,,,00 29 44.9,+00 10 09
1.998947,2301+0700,345.2915417,7.003055556,345.291598,7.003608,7423,2258+067,22 58 38.3,+06 44 05,Sk,:,0.4,0.2,16.5,L,,,23 01 10.0,+07 00 13
2.215630,0137+3154,24.26033333,31.91277778,24.260136,31.91337,470,0134+316,01 34 11.9,+31 39 32,Sp,,0.4,0.2,16.0,L,,,01 37 02.4,+31 54 48
2.141391,0137+3206,24.3775,32.10111111,24.376805,32.101196,473,0134+318,01 34 39.7,+31 50 49,Sp,,0.4,0.2,16.0,M,,,01 37 30.4,+32 06 04
0.971447,1350+3318,207.5854167,33.31194444,207.585117,33.311844,6030,1348+335,13 48 06.9,+33 33 33," C",:,0.3,0.3,16.5,L,,,13 50 20.4,+33 18 43
2.025422,0853+3319,133.4292917,33.33472222,133.429467,33.334179,2575,0850+335B,08 50 37.1,+33 31 27," C",,0.2,0.2,17.5,M,,,08 53 43.1,+33 20 03
0.612367,1350+3455,207.60625,34.92472222,207.60645,34.924677,6031,1348+351,13 48 13.3,+35 10 19,Sp,,0.4,0.3,17.0,L,,,13 50 25.5,+34 55 29
1.388049,1350+3527,207.7027083,35.45694444,207.702285,35.457117,6039,1348+357,13 48 36.8,+35 42 15,Sp,:,0.8,0.3,16.5,L,,,13 50 48.5,+35 27 26
1.857657,1351+3342,207.91925,33.71083333,207.919535,33.710375,6051,1349+339,13 49 27.7,+33 57 25,Sp,,0.3,0.3,17.0,L,,,13 51 40.7,+33 42 37
2.416443,2303+2318,345.7732083,23.30555556,345.772478,23.305582,7439,2300+230,23 00 38.8,+23 02 10,Sp,:,0.3,0.2,16.0,L,,,23 03 05.4,+23 18 20
1.677463,0854+3724,133.6880417,37.41638889,133.688627,37.416357,2581,0851+376,08 51 34.2,+37 36 26,Sp,,0.4,0.2,17.5,M,,,08 54 45.3,+37 24 59
1.450875,0140+2934,25.05854167,29.5675,25.058401,29.567884,494,0137+293,01 37 24.5,+29 18 54," ?",,0.3,0.3,16.0,M,,,01 40 14.0,+29 34 04
1.814152,0855+3425,133.8120417,34.42111111,133.812126,34.420612,2585,0852+346A,08 52 07.8,+34 36 43,Sk,:,0.7,0.1,17.0,L,,,08 55 14.9,+34 25 14
1.507525,0307-0048,46.93654167,-0.8130555556,46.936152,-0.813209,1398,0305-010,03 05 11.7,-01 00 16," C",,0.4,0.2,15.6,L,,Z390.002,03 07 44.7,-00 48 48
0.902721,0307-0424,46.956,-4.404444444,46.955929,-4.404685,1401,0305-045,03 05 19.5,-04 35 45," ?",,0.2,0.1,16.5,L,,,03 07 49.4,-04 24 17
2.128305,1353+2454,208.3796667,24.91083333,208.379476,24.910268,6077,1351+251,13 51 12.0,+25 09 21,Sp,:,0.3,0.1,16.5,L,,,13 53 31.1,+24 54 37
1.243128,1353+3248,208.4656667,32.80083333,208.465547,32.800503,6086,1351+330,13 51 38.4,+33 02 45,Sp,:,0.3,0.2,16.5,M,,,13 53 51.7,+32 48 02
2.347442,1353+3252,208.3496667,32.88222222,208.349355,32.881625,6076,1351+331,13 51 10.5,+33 07 38,Sp,:,0.3,0.2,17.0,L,,,13 53 23.8,+32 52 54
0.104951,2306+0435A,346.681875,4.587222222,346.681846,4.587226,7465,2304+043B,23 04 11.1,+04 19 00,Sp,:,0.4,0.2,16.5,L,,,23 06 43.6,+04 35 14
1.053602,1353+3334,208.4627917,33.58305556,208.462562,33.583277,6085,1351+338A,13 51 38.3,+33 49 43,Sp,:,0.4,0.2,16.0,L,,,13 53 51.0,+33 35 00
1.158762,1159+2105,179.8395417,21.09083333,179.839886,21.090813,4664,1156+213,11 56 47.6,+21 22 09,Sp,:,0.3,0.3,16.0,L,,,11 59 21.6,+21 05 27
0.280737,1159+2429,179.843875,24.49694444,179.843791,24.496929,4665,1156+247,11 56 48.5,+24 46 31," ?",,0.4,0.1,16.0,L,,,11 59 22.5,+24 29 49
2.689251,0857+4518,134.5058333,45.31027778,134.505071,45.310798,2603,0854+455,08 54 38.8,+45 30 16,Sp,,0.4,0.2,16.5,L,,,08 58 01.2,+45 18 39
1.564291,0143+2759,25.86316667,27.99944444,25.863642,27.999557,514,0140+277,01 40 38.3,+27 44 54,Sp,,0.4,0.2,16.0,M,,,01 43 27.3,+27 59 58
0.739874,0143+3031,25.90541667,30.51888889,25.905653,30.518917,516,0140+302,01 40 46.7,+30 16 04,Sk,:,0.3,0.2,16.5,L,,,01 43 37.4,+30 31 08
1.533281,1354+1925,208.5731667,19.42111111,208.573044,19.421521,6095,1351+196,13 51 55.0,+19 40 00,Sp,:,0.4,0.3,16.5,L,,,13 54 17.5,+19 25 17
0.835462,0144+2805,26.24958333,28.09194444,26.249369,28.092079,522,0142+278A,01 42 10.6,+27 50 30,Sk,,0.4,0.3,16.0,L,,,01 44 59.8,+28 05 31
1.703848,0310+3515,47.560375,35.25,47.559802,35.250071,1407,0307+350,03 07 06.1,+35 03 39,Sk,,0.8,0.2,16.0,L,,,03 10 14.4,+35 15 00
2.205057,0311+0014,47.78741667,0.2355555556,47.786949,0.23516,1411,0308+000,03 08 35.0,+00 02 49," ?",,0.4,0.2,17.0,L,,,03 11 08.9,+00 14 07
2.918820,1355+2507A,208.8826667,25.12666667,208.88286,25.125875,6122,1353+253,13 53 13.2,+25 22 13,Sp,,0.7,0.6,15.4,L,,"Z132.049,I4346",13 55 31.9,+25 07 33
0.251508,0901+3435,135.2738333,34.59055556,135.273766,34.590513,2629,0857+347,08 57 59.2,+34 47 13,Sp,:,0.3,0.2,16.5,L,,,09 01 05.7,+34 35 26
1.176946,0147+2916,26.81491667,29.27083333,26.814815,29.271148,543,0144+290,01 44 25.2,+29 01 19,Sp,,0.3,0.3,16.5,M,,,01 47 15.6,+29 16 16
2.890794,2312+0620,348.0192083,6.337222222,348.018428,6.337014,7498,2309+060,23 09 32.2,+06 03 54,Sp,:,0.6,0.2,17.0,L,,,23 12 04.4,+06 20 13
1.598497,1356+3712,209.026375,37.20833333,209.026469,37.208771,6133,1353+374,13 53 57.1,+37 27 10,Sp,:,0.3,0.2,16.5,L,*,,13 56 06.4,+37 12 32
1.714671,0147-1340,26.90054167,-13.67055556,26.900453,-13.671024,551,0145-139,01 45 09.7,-13 55 12," C",:,0.5,0.3,16.0,L,,,01 47 36.1,-13 40 16
0.607962,0903+3414,135.7506667,34.24055556,135.75087,34.240539,2642,0859+344,08 59 54.4,+34 26 19,Sp,:,0.3,0.2,17.0,L,,,09 03 00.2,+34 14 26
1.118612,0904+4203,136.1715,42.0525,136.171377,42.052797,2652,0901+422B,09 01 25.2,+42 15 08," C",,0.3,0.2,16.0,L,,,09 04 41.1,+42 03 10
1.714850,0905+3553,136.2972083,35.89277778,136.297111,35.892308,2656,0902+360,09 02 03.8,+36 05 32," C",:,0.2,0.2,17.0,L,,,09 05 11.3,+35 53 32
2.762299,2315+1845,348.8067083,18.75555556,348.806164,18.756124,7538,2312+184,23 12 44.2,+18 29 00,Sp,:,0.3,0.2,17.0,L,,,23 15 13.5,+18 45 22
2.374673,1358+3239,209.6042083,32.65916667,209.604967,32.659002,6161,1356+329,13 56 12.5,+32 54 06,Sp,:,0.3,0.2,17.0,L,,,13 58 25.2,+32 39 32
1.260999,1358+3646,209.6704583,36.77777778,209.670172,36.777513,6169,1356+370,13 56 31.7,+37 01 12,Sp,,0.5,0.2,17.0,L,,,13 58 40.8,+36 46 39
0.474874,0150+3313,27.64666667,33.2225,27.646746,33.222386,575,0147+329,01 47 41.5,+32 58 30,Sp,:,0.7,0.2,16.5,L,,,01 50 35.2,+33 13 21
1.708957,0907+3606,136.769875,36.11333333,136.769546,36.11294,2671,0903+363B,09 03 57.2,+36 18 52,Sp,:,0.6,0.2,16.5,L,,,09 07 04.7,+36 06 47
0.993519,2316+1305,349.203125,13.09694444,349.203357,13.096786,7562,2314+128,23 14 18.0,+12 49 25,Sp,:,0.3,0.2,16.5,L,,,23 16 48.8,+13 05 48
1.111498,0151+3031,27.98958333,30.53388889,27.989338,30.534114,601,0149+302,01 49 05.5,+30 17 15," C",,0.2,0.1,16.0,M,,,01 51 57.4,+30 32 03
1.904185,1359+3240,209.9242083,32.67444444,209.924048,32.673933,6179,1357+329,13 57 29.3,+32 54 57,Sp,:,0.3,0.2,17.0,L,,,13 59 41.8,+32 40 26
2.795483,1400+2557,210.080375,25.96277778,210.080065,25.962053,6188,1358+262A,13 58 01.7,+26 12 13,Sp,:,0.5,0.2,16.0,L,,,14 00 19.2,+25 57 43
0.462925,0152+3540,27.99945833,35.67888889,27.999595,35.678824,599,0149+354,01 49 04.0,+35 25 56,Sp,:,0.2,0.1,17.0,L,,,01 51 59.9,+35 40 44
1.305864,0152-0323,28.18575,-3.398888889,28.185963,-3.398595,619,0150-036B,01 50 12.8,-03 38 41,Sp,,0.6,0.2,16.0,M,,,01 52 44.6,-03 23 55
1.450750,0910+4617,137.5624167,46.29333333,137.561875,46.293184,2690,0906+464,09 06 53.4,+46 29 50,Sp,,0.5,0.2,16.5,L,,,09 10 14.8,+46 17 35
1.866356,0153+3118,28.47604167,31.30027778,28.475437,31.300235,634,0151+310A,01 51 01.3,+31 03 17,Sp,,0.3,0.2,16.0,L,,,01 53 54.1,+31 18 01
1.552402,0153+3238,28.33141667,32.64888889,28.331818,32.648621,624,0150+324,01 50 25.9,+32 24 10,Sp,,0.5,0.2,17.0,L,,,01 53 19.6,+32 38 55
2.315110,0319-0057,49.82191667,-0.9694444444,49.821274,-0.96947,1465,0316-011,03 16 44.3,-01 09 01," C",:,0.2,0.2,16.0,M,,,03 19 17.1,-00 58 10
1.873992,1402+1734,210.5403333,17.5775,210.540122,17.57702,6213,1359+178A,13 59 46.6,+17 49 03,Sp,,0.7,0.1,16.0,M,,,14 02 09.6,+17 34 37
0.504169,1402+2556,210.6750417,25.94638889,210.675141,25.946281,6217,1400+261,14 00 24.8,+26 11 11,Sp,,0.6,0.2,16.5,L,,,14 02 42.0,+25 56 47
2.756433,0911+3351,137.8659167,33.85388889,137.865606,33.853168,2697,0908+340,09 08 23.6,+34 03 30,Sp,:,0.9,0.2,17.0,L,,,09 11 27.7,+33 51 11
2.029655,2319+1354,349.8159167,13.90194444,349.815359,13.901787,7597,2316+136,23 16 44.9,+13 37 41,Sp,:,0.4,0.2,15.7,L,,Z431.041,23 19 15.7,+13 54 06
2.406864,0912+3611,138.24025,36.18583333,138.239422,36.185853,2709,0909+363,09 09 50.8,+36 23 32," ?",,0.2,0.1,17.5,L,,,09 12 57.5,+36 11 09
2.776035,1207+2543,181.7542917,25.72083333,181.75435,25.720064,4809,1204+259,12 04 28.1,+25 59 54,Sp,,0.4,0.2,15.7,L,,Z128.031,12 07 01.0,+25 43 12
2.261899,1403+3459,210.7869167,34.97833333,210.786774,34.977716,6226,1400+352,14 00 58.9,+35 13 03," C",,0.3,0.3,16.5,H,,,14 03 08.8,+34 58 40
1.429614,0154-1004,28.67433333,-10.07416667,28.67393,-10.074165,662,0152-103,01 52 13.7,-10 19 09,Pd,,0.6,0.1,16.0,M,,,01 54 41.7,-10 04 27
1.902699,2320+1557,350.213625,15.96611111,350.21311,15.966296,7620,2318+156,23 18 20.7,+15 41 32," ?",,0.4,0.2,16.5,L,,,23 20 51.1,+15 57 59
1.894929,0155+0728,28.76904167,7.482222222,28.769432,7.482579,670,0152+072,01 52 26.8,+07 14 16,Pd,,0.4,0.2,16.5,L,,,01 55 04.7,+07 28 57
1.848588,0155+3137,28.84,31.625,28.839912,31.625508,673,0152+313,01 52 28.3,+31 22 51," C",:,0.3,0.2,16.5,M,,,01 55 21.6,+31 37 32
1.197284,0155+3141,28.94454167,31.69305556,28.944151,31.693045,685,0152+314,01 52 53.2,+31 26 55,Sp,:,0.3,0.3,16.5,L,,,01 55 46.6,+31 41 35
1.703224,0155+3157,28.952875,31.95555556,28.953351,31.955802,687,0152+317,01 52 55.2,+31 42 41,Sk,:,0.5,0.4,17.0,L,,,01 55 48.8,+31 57 21
1.031647,0155-0026,28.99166667,-0.4438888889,28.991402,-0.443779,699,0153-006,01 53 24.5,-00 41 17," ?",,0.3,0.2,16.5,M,,,01 55 57.9,-00 26 38
1.289248,1208+2536,182.0407083,25.61333333,182.040362,25.613158,4823,1205+258,12 05 36.9,+25 53 29,Sp,:,0.3,0.2,16.5,L,,,12 08 09.7,+25 36 47
2.054759,2321+0814A,350.3260833,8.241944444,350.325907,8.241401,7627,2318+079B,23 18 46.1,+07 58 02,Sk,:,0.3,0.2,17.0,M,,,23 21 18.2,+08 14 29
2.772999,1208+4011,182.019,40.18833333,182.018626,40.187618,4822,1205+404,12 05 32.4,+40 27 57,Sp,:,0.3,0.2,17.0,L,,,12 08 04.5,+40 11 15
1.830756,2321+1513,350.261,15.22222222,350.260936,15.222727,7621,2318+149,23 18 32.0,+14 56 55,Sp,,0.4,0.4,16.5,L,,,23 21 02.6,+15 13 22
2.675807,1208+4215,182.1795,42.25,182.17988,42.249312,4831,1206+425,12 06 11.4,+42 31 39,Sk,:,0.4,0.4,16.5,L,,,12 08 43.2,+42 14 58
2.828494,2322+1754,350.518875,17.90138889,350.518447,17.900717,7638,2319+176,23 19 34.3,+17 37 35,Sp,,0.3,0.3,16.5,L,,,23 22 04.4,+17 54 03
2.950376,0916+3613,139.0753333,36.22638889,139.074899,36.225648,2730,0913+364,09 13 11.8,+36 26 05,Sp,,0.3,0.3,17.0,L,,,09 16 18.0,+36 13 32
2.164358,0916+4421,139.0029167,44.3525,139.00374,44.352622,2724,0912+445B,09 12 43.8,+44 33 41,Sp,:,0.3,0.2,16.0,M,,,09 16 00.9,+44 21 09
0.391535,0157+3258,29.45854167,32.98111111,29.458491,32.981011,732,0154+327B,01 54 55.3,+32 44 16," C",:,0.3,0.2,17.0,L,,,01 57 50.0,+32 58 52
2.845125,1210+1901,182.6530417,19.01666667,182.652545,19.016031,4879,1208+192,12 08 03.8,+19 17 39,Sp,,0.2,0.2,16.5,L,,,12 10 36.6,+19 00 58
2.626671,1210+2622,182.6105,26.3675,182.610095,26.366867,4873,1207+266,12 07 54.0,+26 38 42,Sp,,0.3,0.2,16.0,M,,,12 10 26.4,+26 22 01
1.082334,1407+2604,211.8625833,26.07361111,211.862324,26.073421,6274,1405+263A,14 05 10.4,+26 18 38,Sk,:,0.4,0.2,16.0,L,,,14 07 27.0,+26 04 24
0.792155,1407+2605,211.9751667,26.08638889,211.975386,26.086487,6277,1405+263B,14 05 37.6,+26 19 24,Sp,:,0.6,0.3,16.0,L,,,14 07 54.1,+26 05 11
1.072875,1407+5447,211.8191667,54.80055556,211.819657,54.800461,6276,1405+550,14 05 32.8,+55 02 15," C",:,0.6,0.2,16.5,M,,,14 07 16.7,+54 48 02
2.224807,0158+3046,29.55175,30.76777778,29.551083,30.768009,739,0155+305,01 55 19.2,+30 31 30,Sp,:,0.4,0.2,16.5,L,,,01 58 12.3,+30 46 05
1.354054,0158+3203,29.6475,32.065,29.647209,32.065284,745,0155+318B,01 55 41.2,+31 49 21,Sp,:,0.6,0.2,16.0,L,,,01 58 35.3,+32 03 55
1.789205,1211+3544,182.8995833,35.73805556,182.899072,35.738329,4909,1209+360,12 09 04.2,+36 00 59,Sp,,0.5,0.3,16.5,L,,,12 11 35.8,+35 44 18
1.930276,1211+4039,182.9794583,40.655,182.979477,40.654464,4920,1209+409,12 09 24.0,+40 55 57," C",,0.3,0.2,15.0,M,,"Z215.050,MK435",12 11 55.1,+40 39 16
1.377120,2324+1443B,351.0715417,14.72,351.07115,14.720053,7671,2321+144,23 21 46.1,+14 26 43,Sp,,0.3,0.2,16.0,L,,,23 24 17.1,+14 43 12
2.373382,0159+3027,29.92479167,30.46222222,29.924782,30.461563,769,0156+302,01 56 48.9,+30 13 10,Sp,:,0.3,0.2,17.0,L,,,01 59 41.9,+30 27 42
0.499517,0159+3053,29.8925,30.89222222,29.892341,30.892197,765,0156+306A,01 56 40.8,+30 39 00,Sp,,0.7,0.1,16.5,L,,,01 59 34.2,+30 53 32
0.896501,0159+3728,29.81695833,37.46888889,29.816734,37.469063,754,0156+372,01 56 17.2,+37 13 36,Sp,,0.5,0.3,16.5,L,,,01 59 16.0,+37 28 09
1.508183,2324+1748,351.2442083,17.80944444,351.244637,17.80935,7677,2322+175,23 22 28.3,+17 32 04,Sp,:,0.3,0.1,17.0,L,,,23 24 58.7,+17 48 34
2.057089,0918+3344A,139.5357083,33.74638889,139.535622,33.745822,2746,0915+339,09 15 05.5,+33 57 23," ?",,0.3,0.2,17.5,L,,,09 18 08.5,+33 44 45
1.004383,2325+1403,351.4510417,14.05444444,351.451321,14.054511,7685,2323+137,23 23 17.1,+13 46 46," ?",,0.2,0.1,16.5,L,,,23 25 48.3,+14 03 16
2.690848,2325+1549,351.4803333,15.82861111,351.480357,15.827864,7687,2323+155,23 23 24.4,+15 33 10,Sp,:,0.2,0.1,16.5,L,,,23 25 55.3,+15 49 40
1.418506,2325+1819,351.3471667,18.33277778,351.346855,18.333038,7681,2322+180,23 22 52.9,+18 03 29," ?",,0.1,0.1,17.0,L,,,23 25 23.2,+18 19 59
1.208924,2326+1406,351.6950833,14.1075,351.695319,14.107746,7699,2324+138,23 24 15.6,+13 49 57,Sp,:,0.3,0.2,17.0,L,,,23 26 46.9,+14 06 28
1.233828,0331+0214,52.92433333,2.242222222,52.924352,2.24188,1519,0329+020,03 29 06.1,+02 04 22," ?",,0.3,0.2,17.0,L,,,03 31 41.8,+02 14 31
0.775502,1214+3624,183.6679167,36.405,183.668161,36.404912,4999,1212+366,12 12 09.5,+36 40 58,Sk,:,0.3,0.1,17.0,L,,,12 14 40.4,+36 24 18
0.971636,2328+1432,352.148,14.53916667,352.148043,14.5389,7721,2326+142,23 26 04.2,+14 15 48,Sp,,0.3,0.2,16.5,L,,,23 28 35.5,+14 32 20
1.371090,0202-0409,30.66433333,-4.15,30.664715,-4.150012,822,0200-043,02 00 08.3,-04 23 25," ?",,0.7,0.3,15.0,L,,,02 02 39.5,-04 09 00
1.616436,0921+4315,140.399,43.2575,140.399182,43.257071,2771,0918+434,09 18 21.5,+43 28 13,Sp,,0.8,0.2,16.5,M,*,,09 21 35.8,+43 15 25
0.406452,0203-0015,30.75129167,-0.2513888889,30.751388,-0.25133,828,0200-004,02 00 26.8,-00 29 29,Sp,:,0.2,0.2,16.5,L,,,02 03 00.3,-00 15 05
1.878810,1414+3409,213.5319583,34.15055556,213.532089,34.150045,6366,1411+343,14 11 58.9,+34 22 58,Sp,:,0.5,0.1,17.0,M,,,14 14 07.7,+34 09 00
2.565724,0922+3351,140.512,33.86444444,140.512486,33.863857,2778,0919+340,09 19 00.4,+34 04 39,Sk,:,0.6,0.2,17.0,L,,,09 22 03.0,+33 51 50
1.255246,0204+0153,31.181375,1.886388889,31.181707,1.886496,859,0202+016,02 02 08.8,+01 38 51,Sp,:,0.6,0.3,16.5,L,,U1573,02 04 43.6,+01 53 11
1.965921,1415+2637,213.9223333,26.63138889,213.921727,26.631322,6384,1413+268,14 13 26.1,+26 51 47,Sp,,0.7,0.6,16.0,L,,,14 15 41.2,+26 37 53
1.954258,1415+3552,213.9583333,35.88277778,213.957672,35.882865,6390,1413+361,14 13 43.0,+36 06 52,Sk,:,0.6,0.1,16.5,L,,,14 15 49.8,+35 52 58
1.387591,2330+1435,352.7045833,14.59944444,352.704939,14.599271,7745,2328+143,23 28 17.7,+14 19 24," ?",,0.3,0.2,17.0,L,,,23 30 49.2,+14 35 57
1.560234,2330+1536,352.6568333,15.60472222,352.657099,15.605072,7743,2328+153,23 28 06.4,+15 19 45,Sp,,0.7,0.4,16.0,L,,,23 30 37.7,+15 36 18
1.986115,0205+0003,31.32575,0.05611111111,31.325892,0.055578,871,0202-001,02 02 44.5,-00 10 59,Sp,,1.1,0.1,16.5,M,,,02 05 18.2,+00 03 20
2.115642,0205-0227,31.267375,-2.452777778,31.267952,-2.452892,865,0202-026B,02 02 32.1,-02 41 30,Sp,:,0.3,0.2,16.5,L,,,02 05 04.3,-02 27 10
1.964785,2331+2248,352.8535,22.80722222,352.853938,22.806855,7753,2328+225B,23 28 54.8,+22 31 51,Sp,:,0.4,0.3,16.0,L,*,,23 31 24.9,+22 48 25
2.518049,2331+2605,352.762,26.08527778,352.761234,26.085404,7750,2328+258A,23 28 33.2,+25 48 34,Sp,:,0.3,0.2,16.5,L,,,23 31 02.7,+26 05 07
1.835999,0206+3034C,31.61833333,30.57722222,31.618077,30.577682,879,0203+303,02 03 34.2,+30 20 23,Sp,:,0.6,0.2,16.5,L,,,02 06 28.3,+30 34 40
1.979772,0206-0240,31.67258333,-2.682222222,31.672714,-2.681688,882,0204-029A,02 04 09.4,-02 55 10,Sp,,0.7,0.3,15.5,L,,,02 06 41.5,-02 40 54
0.588294,0924+4650,141.1305417,46.84583333,141.130534,46.84567,2811,0921+470,09 21 12.3,+47 03 40," ?",,0.4,0.2,17.5,M,,,09 24 31.3,+46 50 44
2.403547,1217+2504,184.4879583,25.07694444,184.487366,25.076547,5054,1215+253,12 15 25.5,+25 21 15,Sp,,0.4,0.4,16.5,L,,,12 17 57.0,+25 04 36
1.080992,2332+1439,353.0255417,14.65861111,353.025715,14.658362,7769,2329+143,23 29 34.6,+14 22 56," ?",,0.3,0.2,17.0,L,,,23 32 06.2,+14 39 30
0.676579,0925+4705,141.4585,47.09361111,141.458763,47.093554,2823,0922+473,09 22 31.0,+47 18 36,Sp,:,0.4,0.1,17.5,L,,,09 25 50.1,+47 05 37
2.117988,1418+2455,214.6768333,24.92166667,214.676833,24.922255,6409,1416+251,14 16 26.3,+25 09 07," ?",,0.3,0.3,16.0,M,,,14 18 42.4,+24 55 20
2.380224,0926+3259,141.5917083,32.99083333,141.591344,32.990247,2837,0923+332,09 23 20.9,+33 12 26,Sp,:,0.9,0.2,17.5,L,,,09 26 21.9,+32 59 25
2.538460,1218+1829,184.5010833,18.49611111,184.500887,18.495431,5056,1215+187B,12 15 28.1,+18 46 23,Sp,:,0.6,0.1,16.0,L,,,12 18 00.2,+18 29 44
2.902458,1218+2730,184.7200833,27.49194444,184.720707,27.491358,5073,1216+277,12 16 21.9,+27 46 08,Pi,:,0.6,0.3,16.5,M,,,12 18 53.0,+27 29 29
0.696741,1218+2915,184.5507917,29.25138889,184.550735,29.251576,5059,1215+295,12 15 41.2,+29 31 45," ?",,0.3,0.2,16.5,L,,,12 18 12.2,+29 15 06
1.828072,0209+0251,32.284,2.855,32.284345,2.855373,914,0206+026,02 06 32.8,+02 37 09,Sp,:,0.3,0.2,16.5,M,,,02 09 08.2,+02 51 19
2.370002,2334+1625,353.676125,16.42861111,353.675456,16.428464,7791,2332+161,23 32 10.6,+16 09 07,Sp,:,0.3,0.2,16.5,L,,,23 34 42.1,+16 25 42
2.491378,1419+2640,214.8283333,26.67611111,214.828074,26.675459,6411,1417+269,14 17 04.1,+26 54 17,Sk,,0.7,0.4,14.9,L,,"Z163.028,I4405",14 19 18.7,+26 40 32
1.204486,0209-0210,32.449625,-2.171388889,32.449296,-2.171451,929,0207-024,02 07 15.5,-02 24 26,Sp,:,0.3,0.2,16.5,L,,,02 09 47.8,-02 10 17
2.611486,1219+2517,184.7907083,25.29694444,184.789906,25.296936,5080,1216+255,12 16 38.3,+25 34 28,Sp,:,0.4,0.3,16.5,L,,,12 19 09.6,+25 17 49
1.946805,1557+1622,239.4440417,16.37333333,239.443519,16.373131,6746,1555+165,15 55 29.6,+16 30 57,Sp,:,0.6,0.2,16.5,L,,,15 57 46.4,+16 22 23
0.796560,0928+3248,142.1991667,32.80944444,142.199066,32.80924,2867,0925+330,09 25 47.3,+33 01 41,Sp,:,0.3,0.2,16.5,L,,,09 28 47.8,+32 48 33
0.580872,0928+4831,142.013,48.52638889,142.013225,48.526327,2851,0924+487A,09 24 42.3,+48 44 40," ?",,0.3,0.2,15.3,M,,Z238.057,09 28 03.2,+48 31 35
2.676745,1219+2955,184.9272083,29.93277778,184.926439,29.933107,5094,1217+302,12 17 11.7,+30 12 38,Sk,:,0.3,0.2,16.5,L,,,12 19 42.3,+29 55 59
2.086812,0210+3429,32.72666667,34.49805556,32.727152,34.497636,946,0207+342,02 07 56.3,+34 15 45,Sp,:,0.6,0.4,16.0,M,,,02 10 54.5,+34 29 51
1.242060,2335+2111,353.9878333,21.18416667,353.987642,21.184462,7803,2333+209,23 33 26.1,+20 54 28,Sp,,0.3,0.2,16.5,L,,,23 35 57.0,+21 11 04
1.053776,2335+2133,353.820625,21.55333333,353.82085,21.553538,7799,2332+212,23 32 46.2,+21 16 37,Sp,,0.5,0.2,16.0,L,,,23 35 17.0,+21 33 13
1.717280,2335+2256A,353.8083333,22.93833333,353.808272,22.938807,7797,2332+226,23 32 43.4,+22 39 44,Sp,:,0.3,0.2,16.5,L,,,23 35 14.0,+22 56 20
1.993696,0929+3917,142.4205833,39.29027778,142.420435,39.289736,2878,0926+395,09 26 33.4,+39 30 33,Sp,:,0.4,0.1,17.0,L,,,09 29 40.9,+39 17 23
0.938656,0211+0010,32.85220833,0.1825,32.852469,0.182506,965,0208-000,02 08 50.8,-00 03 08,Sp,,0.7,0.1,16.5,M,,,02 11 24.6,+00 10 57
2.466323,0211+0116,32.85404167,1.266666667,32.853634,1.266116,963,0208+010,02 08 50.4,+01 01 53,Sp,,0.5,0.2,16.0,M,,,02 11 24.9,+01 15 58
0.455241,1220+2525,185.2192083,25.42972222,185.219266,25.429607,5112,1218+257,12 18 21.6,+25 42 25,Sk,:,0.5,0.2,15.7,L,,"Z128.081,I3185",12 20 52.6,+25 25 47
2.586993,1320+3308,200.1258333,33.14583333,200.125765,33.145117,5776,1318+334,13 18 11.3,+33 24 25,Sp,,0.6,0.2,16.0,M,,,13 20 30.2,+33 08 42
0.833958,2336+1726,354.1782917,17.44888889,354.178086,17.449012,7808,2334+171,23 34 11.2,+17 10 20," ?",,0.5,0.2,16.5,L,,,23 36 42.7,+17 26 56
2.784993,0212+0116,33.132625,1.267777778,33.131994,1.26733,987,0209+010,02 09 57.2,+01 02 00,Sp,:,0.3,0.2,17.0,L,,,02 12 31.7,+01 16 02
1.286187,0212+0116A,33.186875,1.278611111,33.186612,1.278853,988,0210+010A,02 10 10.3,+01 02 42,Sp,:,0.2,0.1,17.0,L,,,02 12 44.8,+01 16 44
1.485376,0212+0221,33.19195833,2.359444444,33.191548,2.359398,990,0210+021,02 10 10.8,+02 07 32,Sp,,0.6,0.2,16.5,L,,,02 12 46.0,+02 21 34
1.300855,2336+2104,354.078,21.06694444,354.07788,21.067288,7804,2333+207,23 33 47.7,+20 47 26,Sp,:,0.3,0.2,16.5,M,,,23 36 18.7,+21 04 02
0.988704,2336+2122,354.1785417,21.37,354.178302,21.36984,7809,2334+210,23 34 11.8,+21 05 35,Sp,:,0.3,0.2,16.5,M,,,23 36 42.8,+21 22 11
0.355948,0212+3057,33.069125,30.96361111,33.069212,30.963676,976,0209+307,02 09 21.3,+30 43 46,Sp,:,0.6,0.2,16.0,L,,,02 12 16.6,+30 57 49
2.541388,0212+3132,33.0,31.54388889,32.999449,31.544416,969,0209+313A,02 09 04.1,+31 18 36,Sk,:,0.4,0.4,16.0,L,,,02 11 59.9,+31 32 40
2.364118,0212-0229,33.22520833,-2.495277778,33.224565,-2.495143,994,0210-027,02 10 21.8,-02 43 44,Sp,:,0.2,0.2,17.0,M,,,02 12 53.9,-02 29 43
2.257774,0931+3523,142.89625,35.39222222,142.896019,35.391624,2914,0928+356,09 28 32.3,+35 36 45,Sp,,0.3,0.2,17.0,L,*,,09 31 35.0,+35 23 30
0.978539,0931+6744,142.821125,67.73888889,142.820441,67.738971,2885,0927+679,09 27 02.8,+67 57 33,Sp,:,0.3,0.2,16.0,L,,,09 31 16.9,+67 44 20
1.914403,0213+0118,33.36925,1.303333333,33.368775,1.303094,999,0210+010B,02 10 54.0,+01 04 11,Sp,,0.4,0.2,16.5,L,,,02 13 28.5,+01 18 11
0.678997,1221+2414,185.4599583,24.24888889,185.459752,24.248875,5127,1219+245,12 19 19.3,+24 31 34,Sk,:,0.4,0.2,16.5,L,,I3204,12 21 50.3,+24 14 56
0.757651,0214+0128,33.613625,1.475277778,33.613422,1.475222,1015,0211+012,02 11 52.6,+01 14 33,Pd,,1.1,0.6,16.0,M,,U1725,02 14 27.2,+01 28 31
0.800411,2337+2648A,354.3962917,26.815,354.396278,26.815222,7818,2335+265,23 35 04.8,+26 32 18,Sp,:,0.3,0.2,16.0,L,,,23 37 35.1,+26 48 55
1.925914,1222+1234,185.7295833,12.56666667,185.729319,12.566198,5148,1220+128,12 20 22.7,+12 50 36,Sp,:,0.5,0.1,15.5,L,,I3233,12 22 55.0,+12 33 58
2.195082,1222+1327,185.5979167,13.46,185.597375,13.460307,5136,1219+137,12 19 51.1,+13 44 15,Sk,:,0.3,0.2,16.0,L,,,12 22 23.4,+13 27 37
2.274312,1601+1623,240.3865833,16.39333333,240.386088,16.392917,6788,1559+165A,15 59 16.0,+16 31 54," C",:,0.2,0.2,16.5,M,,,16 01 32.7,+16 23 35
1.426033,1222+2449,185.6820417,24.82,185.681867,24.820363,5144,1220+250,12 20 12.8,+25 05 51,Sp,:,0.6,0.4,16.5,L,,I3231,12 22 43.6,+24 49 13
0.810764,0215+3105,33.808125,31.09305556,33.808145,31.092831,1024,0212+308,02 12 18.1,+30 51 38," ?",,0.5,0.2,16.5,L,,,02 15 14.0,+31 05 34
2.105382,0340-0118,55.143375,-1.309722222,55.142994,-1.310166,1548,0338-014,03 38 01.9,-01 28 14,Sp,:,0.4,0.3,16.5,L,,,03 40 34.3,-01 18 37
1.233209,1427+1250,216.86275,12.84111111,216.862981,12.840853,6480,1425+130,14 25 02.5,+13 03 52,Sp,,0.5,0.4,16.5,L,,,14 27 27.1,+12 50 27
0.537357,1427+1354,216.9272917,13.90694444,216.927154,13.906878,6483,1425+141,14 25 18.7,+14 07 49," ?",,0.3,0.1,16.5,L,,,14 27 42.5,+13 54 25
1.773771,1427+1611A,216.9715833,16.19583333,216.971225,16.196186,6486,1425+164,14 25 31.0,+16 25 10,Sk,:,0.3,0.2,16.0,L,,"Z104.030A,I4433",14 27 53.1,+16 11 46
0.840291,1427+1658,216.9595833,16.97305556,216.959614,16.972824,6485,1425+171,14 25 28.8,+17 11 46,Sp,:,0.2,0.2,16.5,L,,,14 27 50.3,+16 58 22
1.881870,1602+1353,240.6206667,13.885,240.620218,13.884711,6807,1600+140,16 00 09.5,+14 01 21,Sp,:,0.3,0.2,16.0,M,,,16 02 28.9,+13 53 05
2.671006,1223+3333,185.9767917,33.5625,185.977322,33.561904,5163,1221+338,12 21 25.2,+33 50 20," ?",,0.1,0.1,17.5,L,,,12 23 54.6,+33 33 43
0.979447,1602+1514B,240.6767083,15.23722222,240.676579,15.237464,6813,1600+153,16 00 24.5,+15 22 30," ?",,0.3,0.1,17.0,L,,,16 02 42.4,+15 14 15
1.394528,0934+2716,143.551625,27.28166667,143.551198,27.281589,2981,0931+275A,09 31 17.8,+27 30 16,Sp,:,0.3,0.2,16.0,M,,,09 34 12.3,+27 16 54
0.909284,1428+1234,217.0009583,12.57305556,217.001176,12.572919,6489,1425+127,14 25 35.5,+12 47 46,Sp,,0.4,0.3,16.5,L,,,14 28 00.3,+12 34 23
1.363617,1224+3353,186.161125,33.89444444,186.161489,33.894216,5174,1222+341A,12 22 09.6,+34 10 16,Sp,:,0.3,0.2,16.5,L,,,12 24 38.8,+33 53 39
2.402586,1103+3121,165.7668333,31.36666667,165.766054,31.366718,4084,1100+316,11 00 19.8,+31 38 10,Sk,:,0.4,0.2,16.5,L,,,11 03 03.9,+31 22 00
1.332548,1103+4510,165.8919583,45.17055556,165.892135,45.170207,4088,1100+454,11 00 43.5,+45 26 23,Sp,:,0.6,0.3,16.0,M,,,11 03 34.1,+45 10 13
0.545835,1225+2609,186.4005417,26.16305556,186.400647,26.162937,5189,1223+264,12 23 05.9,+26 26 23,Sk,:,0.4,0.3,17.0,L,,I3316,12 25 36.2,+26 09 47
1.372028,1225+3358,186.4134583,33.97888889,186.413518,33.978511,5192,1223+342,12 23 10.3,+34 15 19,Sp,,0.3,0.1,17.0,L,,,12 25 39.2,+33 58 43
2.845810,1104+4048A,166.0032083,40.81722222,166.002979,40.816451,4099,1101+410,11 01 12.6,+41 05 10,Sp,,0.4,0.2,16.5,M,,,11 04 00.7,+40 48 59
1.151142,2341+2525,355.3191667,25.42138889,355.318828,25.421482,7854,2338+251,23 38 45.5,+25 08 39," ?",,0.3,0.2,17.0,L,,,23 41 16.5,+25 25 17
2.395884,1226+2037,186.5299167,20.62055556,186.529649,20.619939,5202,1223+208,12 23 36.1,+20 53 48,Sp,,0.4,0.3,16.5,L,,,12 26 07.1,+20 37 12
1.960825,1226+2518,186.5892083,25.31111111,186.589089,25.311645,5206,1223+255,12 23 51.1,+25 35 18,Sp,:,0.5,0.4,17.0,L,,,12 26 21.4,+25 18 42
2.937470,1226+3310,186.6417917,33.17472222,186.641728,33.173908,5213,1224+334,12 24 05.1,+33 27 02," ?",,0.2,0.2,17.0,L,,,12 26 34.0,+33 10 26
1.567188,1432+1430,218.0295833,14.51583333,218.029583,14.515398,6522,1429+147A,14 29 44.0,+14 44 08,Pi,,0.4,0.3,16.0,L,,,14 32 07.1,+14 30 55
0.791436,1227+1842,186.8358333,18.71555556,186.835695,18.715379,5222,1224+189,12 24 49.4,+18 59 31,Sp,,0.9,0.3,16.5,L,,,12 27 20.6,+18 42 55
1.503773,1228+1717,187.0060833,17.29666667,187.006304,17.296306,5237,1225+175,12 25 30.2,+17 34 22,Sp,,0.3,0.2,16.0,L,*,Z099.060(West component only),12 28 01.5,+17 17 47
1.368521,1228+1843,187.051375,18.74833333,187.051568,18.748,5241,1225+190,12 25 41.3,+19 01 28,Sp,,0.2,0.1,17.5,M,,,12 28 12.4,+18 44 53
2.882164,0106+3313,16.69225,33.23166667,16.691313,33.23183,266,0103+329,01 03 59.9,+32 57 53,Ig,,0.7,0.2,16.5,M,,,01 06 45.9,+33 13 55
2.122611,1228+4200,187.0662083,42.01444444,187.065988,42.013878,5246,1225+422,12 25 49.2,+42 17 25,Sp,:,0.6,0.3,16.5,L,,,12 28 15.8,+42 00 50
2.634288,1434+0953,218.54675,9.884722222,218.547426,9.884419,6541,1431+101,14 31 44.9,+10 06 11,Sp,:,0.4,0.3,16.5,L,,,14 34 11.4,+09 53 04
2.676540,2343+1738A,355.915375,17.63638889,355.91479,17.635897,7868,2341+173,23 41 07.4,+17 21 30,Sp,:,0.3,0.3,16.0,L,,,23 43 39.5,+17 38 09
2.280401,1435+5512,218.7592917,55.21416667,218.758218,55.214328,6552,1433+554,14 33 28.4,+55 25 55,Sp,,0.3,0.2,16.5,M,,,14 35 02.0,+55 12 52
1.057242,1107+4549,166.8582083,45.83,166.857809,45.829906,4127,1104+461,11 04 36.0,+46 06 02," ?",,0.4,0.4,16.0,M,,,11 07 25.9,+45 49 48
1.450997,1108+3610,167.1095833,36.17638889,167.109124,36.176547,4132,1105+364,11 05 41.2,+36 26 51,Sp,:,0.4,0.2,16.0,M,,,11 08 26.2,+36 10 36
0.402746,1231+2849A,187.75075,28.82833333,187.750702,28.828437,5285,1228+291B,12 28 31.2,+29 06 16," ?",,0.3,0.2,16.5,M,,,12 31 00.2,+28 49 42
1.690166,1606+1810A,241.567,18.17055556,241.566536,18.170717,6855,1604+183,16 04 01.5,+18 18 16,Sk,:,0.4,0.3,15.5,L,,"Z108.144,I1189,MK300",16 06 16.0,+18 10 15
0.461266,0707+6902,106.8174167,69.04333333,106.817143,69.043416,1681,0701+691,07 01 54.5,+69 07 15,Sp,,0.5,0.2,16.5,H,,,07 07 16.1,+69 02 36
1.964298,1232+2101,188.1882917,21.02472222,188.187976,21.024263,5317,1230+213,12 30 14.9,+21 18 00,Sp,:,0.4,0.1,17.0,L,,,12 32 45.1,+21 01 27
1.067492,1232+2443,188.0784583,24.72805556,188.078638,24.727808,5310,1229+250,12 29 49.3,+25 00 13,Ic,:,0.4,0.4,17.0,M,*,I3472,12 32 18.9,+24 43 40
1.110260,0708+3629,107.1845417,36.49916667,107.184336,36.499427,1689,0705+365,07 05 23.1,+36 34 47," C",:,0.4,0.2,16.0,H,,,07 08 44.2,+36 29 58
1.583354,1438+4833,219.5297917,48.55916667,219.529377,48.558823,6564,1436+487,14 36 21.4,+48 46 27,Sp,,0.5,0.2,17.5,L,,,14 38 07.1,+48 33 32
1.596215,1438+5101,219.698875,51.02222222,219.698179,51.022152,6570,1437+512,14 37 06.5,+51 14 13,Sk,:,0.4,0.2,17.0,M,,,14 38 47.6,+51 01 20
2.961078,1438+5124,219.700125,51.40277778,219.701394,51.403001,6571,1437+516,14 37 08.0,+51 37 04,Sk,:,0.3,0.3,17.5,L,,,14 38 48.3,+51 24 11
1.428820,0230+2847,37.53141667,28.79694444,37.531395,28.796548,1144,0227+285,02 27 11.7,+28 34 29,Sp,:,0.5,0.2,17.0,L,,,02 30 07.5,+28 47 48
2.370137,1233+3252,188.2525417,32.86805556,188.251916,32.867659,5328,1230+331C,12 30 32.7,+33 08 36,Sp,:,0.4,0.2,17.0,L,,,12 33 00.5,+32 52 04
2.391083,0110+3436,17.66979167,34.61305556,17.669662,34.6124,285,0107+343,01 07 53.3,+34 20 48," C",,0.2,0.1,16.0,M,,,01 10 40.7,+34 36 45
1.840380,1234+2653,188.609875,26.885,188.609331,26.884839,5360,1231+271,12 31 57.4,+27 09 37," ?",,0.2,0.1,17.5,L,,,12 34 26.2,+26 53 05
2.401526,0231+3245,37.79145833,32.75833333,37.79108,32.757747,1157,0228+325,02 28 10.1,+32 32 12," ?",,0.2,0.1,16.5,L,,,02 31 09.9,+32 45 28
1.438939,1609+3437,242.2996667,34.6175,242.300135,34.617394,6879,1607+347,16 07 19.1,+34 44 52," C",,0.2,0.2,16.5,L,,,16 09 12.0,+34 37 03
1.603440,1111+3218,167.9345833,32.31555556,167.934068,32.315649,4163,1109+325,11 09 01.3,+32 35 15,Sp,:,0.4,0.1,17.0,L,,,11 11 44.2,+32 18 56
1.911194,1609+3702,242.43725,37.0375,242.437384,37.03802,6885,1607+371,16 07 55.9,+37 10 04,Sp,:,0.3,0.2,16.5,M,,,16 09 45.0,+37 02 17
2.413013,0715+6915,108.8940417,69.26333333,108.89379,69.262669,1715,0710+693,07 10 12.8,+69 20 59," ?",,0.5,0.4,16.5,L,,,07 15 34.5,+69 15 46
2.184287,0944+3618,146.0169583,36.30916667,146.016536,36.309669,3209,0941+365,09 41 02.4,+36 32 22," ?",,0.4,0.2,16.5,M,,,09 44 04.0,+36 18 35
2.986426,2348+2121,357.2256667,21.35083333,357.226532,21.35103,7899,2346+210,23 46 22.0,+21 04 23,Sp,:,0.7,0.2,16.5,L,,,23 48 54.4,+21 21 04
0.804861,2348+2732,357.0054583,27.54916667,357.005272,27.549016,7891,2345+272,23 45 29.5,+27 16 16,Sp,:,0.6,0.2,16.0,L,,,23 48 01.3,+27 32 56
0.369756,1112+2816,168.1154167,28.27805556,168.115423,28.277953,4175,1109+285,11 09 46.3,+28 33 00,Sp,:,0.5,0.3,16.0,L,,,11 12 27.7,+28 16 41
2.871773,0233+3051,38.35875,30.85833333,38.359644,30.858551,1190,0230+306B,02 30 28.1,+30 38 21," ?",,0.4,0.2,17.0,L,,,02 33 26.3,+30 51 31
1.408520,1112+4057,168.03275,40.95583333,168.032396,40.956119,4170,1109+412,11 09 21.6,+41 13 41," ?",,0.3,0.2,17.0,L,,,11 12 07.8,+40 57 22
1.932678,0112+3420,18.119125,34.34166667,18.118833,34.341187,306,0109+340,01 09 40.9,+34 04 34," ?",,0.3,0.3,17.0,M,,,01 12 28.5,+34 20 28
2.205198,2349+2620,357.4661667,26.33944444,357.465962,26.33886,7904,2347+260,23 47 19.7,+26 03 39,Sp,:,0.6,0.2,16.5,L,,,23 49 51.8,+26 20 20
2.522406,0234+2957,38.65083333,29.965,38.650033,29.964899,1202,0231+297,02 31 38.5,+29 44 47," ?",,0.3,0.3,15.0,M,,Z505.017,02 34 36.0,+29 57 54
0.798540,0234+3013,38.71358333,30.23194444,38.713327,30.231932,1206,0231+300,02 31 53.4,+30 00 49,Sk,,0.3,0.3,16.5,L,,,02 34 51.2,+30 13 55
0.221550,1236+4007,189.2208333,40.13194444,189.220762,40.131973,5392,1234+404,12 34 28.0,+40 24 25," C",,0.3,0.2,16.5,L,,,12 36 53.0,+40 07 55
2.866420,2349+2800,357.4226667,28.00583333,357.423263,28.005236,7901,2347+277,23 47 09.6,+27 43 38,Sp,:,0.6,0.2,16.5,L,,,23 49 41.6,+28 00 19
1.094633,1113+2800A,168.2974167,28.01222222,168.297523,28.011933,4181,1110+282B,11 10 30.2,+28 17 03,Sp,:,0.4,0.2,16.5,M,,,11 13 11.4,+28 00 43
2.617953,1113+3648,168.4009583,36.8125,168.401858,36.8124,4183,1110+370,11 10 52.3,+37 05 05,Sk,:,0.3,0.2,17.0,L,,,11 13 36.4,+36 48 45
1.520681,0726+3723,111.6838333,37.38555556,111.683341,37.385715,1772,0723+374,07 23 22.6,+37 29 12,Pi,,0.8,0.4,14.6,L,,U3849,07 26 44.0,+37 23 09
0.308088,0946+4358,146.7395,43.97277778,146.739615,43.972756,3268,0943+442,09 43 47.9,+44 12 16,Sp,:,0.5,0.2,16.5,L,,,09 46 57.5,+43 58 22
1.570545,0946+4526,146.6628333,45.43527778,146.663187,45.434919,3259,0943+456,09 43 27.6,+45 39 59,Sp,,0.5,0.3,17.0,M,,,09 46 39.2,+45 26 06
2.530111,0946+4632,146.6264583,46.53527778,146.625782,46.534751,3256,0943+467,09 43 17.1,+46 45 58,Sp,,0.4,0.2,17.0,M,,,09 46 30.2,+46 32 05
2.589232,0235+3235,38.7575,32.58972222,38.75774,32.589032,1207,0232+323,02 32 01.7,+32 22 15,Sp,:,0.5,0.2,17.0,L,,,02 35 01.9,+32 35 21
1.539305,1237+2642,189.4215,26.70805556,189.421679,26.707659,5401,1235+269,12 35 12.8,+26 58 57,Sp,:,0.6,0.3,15.7,M,,"Z159.034,I3599",12 37 41.2,+26 42 28
2.014570,1237+2709,189.3168333,27.15722222,189.316503,27.156746,5396,1234+274,12 34 47.6,+27 25 54,Sk,:,0.3,0.2,17.0,L,,,12 37 16.0,+27 09 24
0.819511,1237+2737,189.480875,27.62833333,189.480631,27.628262,5405,1235+279,12 35 27.2,+27 54 11,Sp,:,0.3,0.2,16.0,L,*,,12 37 55.4,+27 37 42
0.856241,1237+2808,189.334,28.14722222,189.333828,28.147039,5398,1234+284,12 34 52.0,+28 25 19," ?",,0.3,0.2,17.5,L,,,12 37 20.1,+28 08 49
2.592494,1237+2816A,189.331,28.27833333,189.330374,28.27787,5397,1234+285,12 34 51.2,+28 33 10," ?",,0.3,0.2,18.0,L,,,12 37 19.3,+28 16 40
2.264742,1114+3406,168.7290833,34.10638889,168.728346,34.106237,4195,1112+343,11 12 11.9,+34 22 44,Sk,:,0.4,0.2,17.0,L,,,11 14 54.8,+34 06 22
2.562985,1238+2736A,189.5080833,27.61416667,189.507661,27.613561,5407,1235+278,12 35 33.7,+27 53 18,Sp,:,0.2,0.1,17.0,M,,,12 38 01.8,+27 36 49
2.044986,1613+3721,243.2544167,37.35416667,243.2551,37.354333,6912,1611+374A,16 11 13.0,+37 28 50,Sp,,0.4,0.2,16.5,L,,,16 13 01.2,+37 21 16
0.524027,0237-0108,39.46708333,-1.141944444,39.467204,-1.141863,1232,0235-013,02 35 19.3,-01 21 28," C",:,0.3,0.3,16.0,L,,,02 37 52.1,-01 08 31
2.692611,0947+4528,146.9802083,45.46861111,146.979151,45.468513,3286,0944+457,09 44 43.7,+45 42 03,Sp,,0.5,0.2,16.5,M,,,09 47 55.0,+45 28 07
1.264257,0947+4701,146.9115833,47.02722222,146.911142,47.027041,3279,0944+472,09 44 25.2,+47 15 33,Sp,:,0.3,0.3,17.5,L,,,09 47 38.7,+47 01 37
2.695537,2351+0851,357.888125,8.864444444,357.888877,8.864537,7934,2349+085,23 49 00.0,+08 35 11,Sp,:,0.4,0.2,16.5,M,,,23 51 33.3,+08 51 52
2.788124,2351+1621,357.79175,16.35722222,357.791704,16.356449,7922,2348+160C,23 48 37.1,+16 04 42,Sk,:,0.5,0.2,16.5,L,,,23 51 10.0,+16 21 23
2.804869,1446+4810,221.5999167,48.17888889,221.600123,48.178122,6601,1444+483,14 44 39.8,+48 23 13,Sp,,0.5,0.4,17.0,M,,,14 46 24.0,+48 10 41
0.974201,2351+2437,357.869625,24.62694444,357.869442,24.626731,7933,2348+243B,23 48 56.2,+24 20 55,Sp,,0.7,0.2,16.0,L,,,23 51 28.7,+24 37 36
1.775747,0238-0011,39.63375,-0.1852777778,39.633471,-0.184871,1237,0235-004,02 35 58.5,-00 24 01,Sp,,0.4,0.2,16.5,L,,,02 38 32.0,-00 11 06
1.517876,1617+3509,244.4635417,35.15638889,244.463365,35.156785,6944,1615+352B,16 15 59.9,+35 16 40,Sp,:,0.7,0.2,16.0,L,,,16 17 51.2,+35 09 24
2.740849,0948+3423,147.1708333,34.38361111,147.171609,34.383199,3307,0945+346,09 45 42.3,+34 36 58," ?",,0.5,0.5,16.5,L,,,09 48 41.2,+34 23 00
2.620607,0948+3636A,147.2166667,36.605,147.215851,36.605318,3310,0945+368B,09 45 50.8,+36 50 18,Sp,,0.4,0.3,16.5,M,,,09 48 51.8,+36 36 19
1.847866,0948+3636B,147.1654167,36.61361111,147.16479,36.613509,3305,0945+368A,09 45 38.5,+36 50 47,Sp,:,0.3,0.3,17.0,L,,,09 48 39.5,+36 36 49
1.566121,2352+1353,358.1301667,13.88555556,358.130589,13.88541,7952,2349+136,23 49 58.2,+13 36 26,Sp,,0.6,0.2,16.0,M,*,,23 52 31.3,+13 53 07
2.191599,1618+3509,244.6477083,35.16222222,244.647228,35.161757,6954,1616+352,16 16 44.1,+35 16 55,Sp,,0.2,0.1,17.0,L,,,16 18 35.3,+35 09 42
2.694633,1619+3357,244.7965417,33.95805556,244.795649,33.957946,6960,1617+340,16 17 17.9,+34 04 39,Sp,:,0.4,0.2,16.5,L,,,16 19 11.0,+33 57 29
0.749733,1619+3415,244.9704167,34.25805556,244.970563,34.257886,6969,1618+343,16 18 00.4,+34 22 36,Sk,:,0.9,0.2,16.0,L,,,16 19 52.9,+34 15 28
2.495550,1619+3421,244.7830833,34.35805556,244.782267,34.357893,6959,1617+344,16 17 15.3,+34 28 39," ?",,0.3,0.3,16.5,L,,,16 19 07.7,+34 21 28
0.628428,0240+0216,40.08308333,2.271666667,40.083184,2.271524,1250,0237+020,02 37 44.6,+02 03 27,Pd,,0.6,0.4,16.0,L,,,02 40 20.0,+02 16 17
0.845084,0240+0225,40.07345833,2.426666667,40.073665,2.426555,1249,0237+022,02 37 42.2,+02 12 45," C",,0.4,0.3,15.6,L,,Z388.091,02 40 17.7,+02 25 36
1.842654,1448+4953,222.1762917,49.88722222,222.175617,49.886952,6615,1447+500,14 47 01.6,+50 05 38,Sp,:,0.6,0.2,16.5,L,,,14 48 42.1,+49 53 13
1.483730,0949+3515,147.3808333,35.26472222,147.380748,35.264316,3323,0946+354B,09 46 31.8,+35 29 52,Sp,:,0.4,0.3,16.5,L,,,09 49 31.4,+35 15 52
2.486836,1620+3951,245.2325,39.86083333,245.231702,39.860514,6982,1619+399,16 19 12.5,+39 58 41,Sp,:,0.4,0.2,16.0,L,,,16 20 55.6,+39 51 38
2.378966,1620+3954,245.2272083,39.90861111,245.226351,39.908546,6981,1619+400A,16 19 11.3,+40 01 34," ?",,0.4,0.2,16.0,M,,,16 20 54.3,+39 54 31
1.194405,2353+1835,358.2620417,18.5975,358.262355,18.597648,7960,2350+183,23 50 30.0,+18 19 10,Sp,:,0.4,0.3,16.0,M,,,23 53 03.0,+18 35 52
2.340791,0950+4415,147.6042917,44.25694444,147.605167,44.257117,3342,0947+444,09 47 16.1,+44 29 28,Sp,:,0.3,0.2,16.5,M,,,09 50 25.2,+44 15 26
2.111085,1117+3515,169.3065417,35.2675,169.307237,35.267353,4215,1114+355,11 14 30.9,+35 32 26,Sp,:,0.4,0.2,17.0,L,,,11 17 13.7,+35 16 02
1.684531,1623+3719,245.9868333,37.32444444,245.987216,37.324089,7013,1622+374,16 22 09.7,+37 26 18,Sp,,0.2,0.1,16.5,L,,,16 23 56.9,+37 19 27
1.639764,0751+4251,117.9798333,42.85555556,117.979256,42.855724,1941,0748+429,07 48 26.2,+42 59 04,Sk,:,0.5,0.2,16.0,L,*,,07 51 55.0,+42 51 21
2.488771,2354+1146,358.5557083,11.77944444,358.556007,11.778818,7972,2351+115,23 51 40.1,+11 30 02,Sp,:,0.4,0.3,16.5,L,,,23 54 13.4,+11 46 44
2.414190,0756+3315,119.1084167,33.25694444,119.108597,33.256291,1979,0753+333A,07 53 13.8,+33 23 24,Sp,,0.3,0.2,17.0,L,*,,07 56 26.1,+33 15 23
1.516156,1627+3607,246.8479167,36.11666667,246.848086,36.117065,7045,1625+362A,16 25 34.6,+36 13 39," ?",,0.3,0.1,16.5,M,,,16 27 23.5,+36 07 01
0.673281,1627+3608,246.9049583,36.145,246.9049,36.144819,7048,1625+362B,16 25 48.3,+36 15 18,Sp,,0.6,0.1,16.5,L,,,16 27 37.2,+36 08 41
1.122822,1119+3259,169.75875,32.99444444,169.758565,32.994715,4237,1116+332,11 16 20.3,+33 16 06,Sp,:,0.7,0.2,16.0,L,,,11 19 02.1,+32 59 41
1.252938,0801+3448,120.4839167,34.8125,120.483923,34.812152,2017,0758+349,07 58 42.1,+34 57 06,Sk,:,0.4,0.1,16.0,L,,,08 01 56.1,+34 48 44
0.297077,1120+3536,170.16475,35.61305556,170.164772,35.612975,4255,1117+358,11 17 57.3,+35 53 13,Sp,:,0.4,0.2,16.5,L,,,11 20 39.5,+35 36 47
2.025438,1120+3612,170.153375,36.20972222,170.152683,36.209653,4253,1117+364A,11 17 54.2,+36 29 01,Sp,:,0.4,0.1,17.0,L,,,11 20 36.6,+36 12 35
2.332278,0803+6118,120.9075417,61.30611111,120.908528,61.305669,2023,0759+614A,07 59 18.7,+61 26 47,Sp,:,0.3,0.1,16.5,L,,,08 03 38.0,+61 18 20
0.723816,0804+6132,121.0884167,61.5475,121.088427,61.547701,2030,0800+616,08 00 01.0,+61 41 21,Sp,,0.3,0.2,16.0,H,,,08 04 21.2,+61 32 52
2.682741,0957+3649,149.3227083,36.8325,149.321947,36.832929,3465,0954+370,09 54 17.6,+37 04 17," ?",,0.3,0.2,16.5,L,,,09 57 17.3,+36 49 59
1.938347,1121+3332A,170.2585417,33.53333333,170.25891,33.532891,4258,1118+338,11 18 20.6,+33 48 25,Sp,:,0.5,0.2,17.0,L,,,11 21 02.1,+33 31 58
1.780363,0958+3615,149.5675,36.25916667,149.567703,36.2587,3483,0955+364,09 55 17.3,+36 29 52," ?",,0.4,0.3,16.0,L,,,09 58 16.2,+36 15 31
0.597142,1633+3506,248.2740833,35.10027778,248.273934,35.10039,7083,1631+352,16 31 15.6,+35 12 16," ?",,0.4,0.2,16.0,H,,,16 33 05.7,+35 06 01
1.393874,2359+0831,359.841375,8.533055556,359.841176,8.533389,8039,2356+082,23 56 48.2,+08 15 18,Sp,:,0.7,0.3,16.5,L,,,23 59 21.9,+08 32 00
1.254727,2359+2536,359.8515417,25.61138889,359.85127,25.611141,8041,2356+253,23 56 50.8,+25 19 58,Sk,:,0.5,0.1,16.5,L,,,23 59 24.3,+25 36 40
0.922419,1640+3214,250.00425,32.24583333,250.003993,32.245969,7104,1638+323A,16 38 06.8,+32 20 32,Sp,:,0.4,0.4,16.0,L,,,16 40 01.0,+32 14 45
2.458018,1124+3434,171.2397917,34.57611111,171.239865,34.575431,4280,1122+348A,11 22 16.5,+34 51 01,Sp,:,0.4,0.3,16.5,M,,,11 24 57.6,+34 34 32
2.182159,1125+3522,171.3840417,35.36277778,171.38444,35.362266,4285,1122+356,11 22 51.1,+35 38 14,Sp,,0.5,0.4,16.5,L,,,11 25 32.3,+35 21 44
0.601137,1127+2720,171.9799167,27.34694444,171.979998,27.347095,4305,1125+276,11 25 16.4,+27 37 21,Sp,,0.5,0.3,16.5,L,,,11 27 55.2,+27 20 50
1.401394,1127+3605,171.9418333,36.09972222,171.94166,36.099359,4304,1125+363,11 25 05.1,+36 22 29,Sk,:,0.5,0.2,16.5,L,,,11 27 46.0,+36 05 58
2.189538,1128+3451,172.1298333,34.85916667,172.130524,34.858946,4312,1125+351,11 25 50.9,+35 08 04,Sp,:,0.8,0.2,16.5,L,,,11 28 31.3,+34 51 32
0.704137,1128+3646,172.1385417,36.77638889,172.138776,36.776444,4313,1125+370,11 25 52.4,+37 03 07,Sp,,0.4,0.3,16.5,L,,,11 28 33.3,+36 46 35
2.065058,1659+2953,254.86475,29.89472222,254.864127,29.894529,7135,1657+299,16 57 30.7,+29 58 06,Sp,:,0.7,0.3,16.0,L,,,16 59 27.4,+29 53 40
2.066663,1704+3044,256.1167083,30.74027778,256.116237,30.739871,7141,1702+308,17 02 32.7,+30 48 28,Sp,,0.5,0.2,16.0,M,,,17 04 27.9,+30 44 24
0.516060,1709+2841,257.3557917,28.68416667,257.355841,28.68403,7151,1707+287,17 07 27.3,+28 44 46,Sp,,0.6,0.3,16.0,L,,,17 09 25.4,+28 41 03
2.736224,1011+3555,152.9116667,35.92583333,152.911104,35.925225,3616,1008+361,10 08 42.5,+36 10 20," C",:,0.2,0.2,17.0,L,,,10 11 38.7,+35 55 31
2.831944,1013+4705,153.39175,47.09,153.391703,47.089214,3642,1010+473,10 10 27.5,+47 20 14,Sp,:,0.9,0.1,17.0,L,,,10 13 34.0,+47 05 21
1.306575,1015+4637,153.9722917,46.625,153.971821,46.625165,3669,1012+468,10 12 47.9,+46 52 28," ?",,0.2,0.2,17.0,M,,,10 15 53.2,+46 37 31
2.132838,1017+3448,154.4872083,34.81388889,154.486729,34.813446,3694,1015+350A,10 15 02.7,+35 03 50,Sp,:,0.3,0.1,17.5,L,,,10 17 56.8,+34 48 48
1.678173,1017+4636,154.4807083,46.60305556,154.480612,46.603517,3690,1014+468,10 14 50.6,+46 51 14," ?",,0.3,0.1,17.0,L,,,10 17 55.3,+46 36 13
2.119998,1018+3440,154.551625,34.67305556,154.551505,34.672475,3698,1015+349,10 15 18.4,+34 55 23,Sp,,0.5,0.2,16.5,L,,,10 18 12.4,+34 40 21
2.855611,1019+4633,154.8369583,46.55055556,154.835805,46.550544,3716,1016+468,10 16 16.3,+46 48 06,Sp,:,0.4,0.2,16.5,M,,,10 19 20.6,+46 33 02
1.275610,2232+1938,338.235,19.64583333,338.234899,19.645492,7236,2230+193,22 30 31.5,+19 23 15,Sk,:,0.7,0.2,16.0,L,,,22 32 56.4,+19 38 44
2.999690,2234+2041,338.586,20.69694444,338.585822,20.696128,7240,2231+204,22 31 56.1,+20 26 15," ?",,0.6,0.2,16.0,M,,,22 34 20.6,+20 41 46
1.196019,1022+3635A,155.6321667,36.58777778,155.632042,36.587461,3749,1019+368,10 19 37.1,+36 50 25,Sk,:,0.3,0.2,17.0,L,,,10 22 31.7,+36 35 15
1.666809,1022+3740,155.6935417,37.67333333,155.69324,37.67373,3750,1019+379,10 19 51.0,+37 55 36," C",,0.2,0.2,17.0,L,,,10 22 46.4,+37 40 25
2.694642,1023+3445,155.7955,34.75638889,155.796285,34.756009,3754,1020+350,10 20 18.0,+35 00 33," C",:,0.3,0.2,17.0,L,,,10 23 11.1,+34 45 22
0.783683,1030+3648,157.5220417,36.8075,157.522254,36.807364,3825,1027+370,10 27 12.1,+37 03 50,Sp,:,0.4,0.2,17.0,L,,,10 30 05.3,+36 48 27
Edited by yuzameh, 15 August 2023 - 03:08 PM.
