3D Printed Lens Cell Gives New Life to Lens-less Vixen 80mm Short Tube
3d printing ATM Classic Refractor
12 replies to this topic
#1 jkmccarthy
jkmccarthy
  • Loc: Los Angeles, California U.S.A.
Posted 28 July 2023 - 06:37 AM
Five months ago on ZenMarket, I outbid four others for a Vixen D=80mm F=640mm short tube (that was once a Super-Polaris-FL-80S) with focuser and finder, but missing both the objective lens and a lens cell.  The amount I bid was a fair price for just the sage green 6x30 swivel finder that accounted for my interest in the first place, but after delivery and putting the finder to use on another Vixen Super Polaris classic refractor, I started wondering what I could do with the left over Vixen short tube and focuser . . . .
Being aware that Vixen uses such 90mm O.D. telescope tubes for both its 80mm aperture and 90mm aperture refractors, and having been reading in the Refractors forum praise for the SVBONY SV48P short tube achromat (D=90mm F=500mm), I set my sights on finding a 90mm achromatic doublet for my left-over Vixen short tube.   On the Ali-Express web site, I found a merchant [Ruite Professional Optical Trading] who offered a modestly-priced airspaced O.D. 93mm [Clear Aperture 90mm] F=600mm [**] achromatic doublet, as well as a cheap (in every sense of the word) molded ABS plastic lens cell.  I ordered both.
Ali-Express_Ruite-DIY-90mm-600mm-Achromat.jpg   Ali-Express_Ruite-DIY-90mm-Lens-Cell.jpg
A couple months later I had the lens in the cell, and after replacing the supplied "spacer ring" with three foil spacers I could see under CFL illumination the bulls-eye pattern of Newton's Rings, well centered with the lens elements paired outside the cell, but the sloppy fit in the cell made Newton's Rings elusive.  To address this, I cut shims from thin plastic that I placed at 3 places around the circumference of the lens, in between the outer diameter of the lens and the inner diameter of the cell, but even so, the lack of parallelism and/or flatness of both the plastic lens cell's register that the rear surface of the flint element was resting on, and/or the plastic threaded retainer ring on top of the crown element, put the Newton's Rings bulls-eye pattern significantly off-center in the aperture with the glass installed in the cell.   Not to be deterred, I cut wide cylinders of cardboard and layered these to increase the O.D. at the front of the tube sufficiently for a snug fit inside the rear section of the Ali-Express lens cell, which I then wrapped with masking tape to hold it for a look at the achromat's optical performance.
My daytime tests visually --- and with photos taken using afocal projection from eyepieces into an iPhone's camera lens, accessible in a Google Drive folder here:
https://drive.google...IzH?usp=sharing
--- were nevertheless rather encouraging, despite the significant false color visible, as expected, for a 90mm f/6.67 achromat.
It was at this point that I private-messaged Sean (norvegicus) here on CN to ask if he could design and 3D-print a cylindrical adapter to replace my rolled-up cardboard strips and secure the Ali-Express molded ABS plastic cell onto the front of the Vixen FL-80S tube.   A schematic cross-section of the notional adapter I initially had in mind is shown in solid-blue at the bottom of this drawing:
Sean pointed out some practical difficulties (a polite way of saying impossibilities) associated with 3D printing this adapter in one piece as originally conceived, and although female threads could be printed around the inner surface of the adapter to match the threads on the end of the Vixen tube, there were also a number of challenges associated with how the adapter could best be attached to the Ali-Express molded ABS cell (whose cross-section is shown hatched in the bottom half of my drawing above).   Exchanging messages off-and-on and mulling things over for the first couple of weeks, it became increasingly clear to each of us that designing around the cheap Ali-Express lens cell was making the task more difficult instead of easier, and overall things would be much better -- both design-wise and performance-wise -- if we abandoned that and set about designing a custom lens cell that could be 3D printed in its entirety.   Conceptually, this would have the cross-sectional shape shown in magenta in the upper half of the drawing above.
A week or so earlier, Chris (Kasmos) here on CN contributed several posts to the "What did you do to your Scope/Mount Today?" thread, describing his work to replace the spacers on a Unitron 114 objective lens (see:  https://www.cloudyni...9#entry12708143), and what caught my imagination was his concluding remarks about how the three screws Unitron employed to secure the lens retaining ring onto the front of the cell could, with a "soft touch", be used "to get the [Newton's] rings centered" in the objective.  Having struggled with off-center Newton's Rings with this 90/600 lens in the Ali-Express lens cell, inspired by Chris' remarks I was keen to suggest to Sean that we adopt the Unitron approach of securing the front retaining ring with three screws, instead of threading it into the front of the custom cell, since the capability to fine-tune the centering of the Newton's Rings bulls-eye pattern in the lens aperture was a very appealing idea.  The retaining ring's cross-section shown in purple at upper left above notionally represents this approach.
With this fresh-start concept thus agreed upon, Sean and I then collaborated closely over the next month-and-a-half (!) as he developed and refined the detailed design in his [new] CAD tool ... his insightful comments + ideas and his 3D-printing fabrication experience were really valuable throughout --- and naturally I'm very grateful for his many contributions and his patience, not to mention the many hours of his time.
Here is Sean's 3D CAD rendering of his final design for the retaining ring (note the three pads that contact the glass, to be positioned above where the lens spacers are located between the elements of the doublet ... i.e., the glass is to be installed and clocked such that the lens spacers are located under these tabs : - ) --
... and here a cutaway cross-section through Sean's final design of the full lens cell assembly, that includes the retaining ring again at the top --
In Sean's lens cell assembly's cutaway cross-section, the blue areas are cavities (the doublet lens occupies the widest cavity, while the cavities above and below the widest one are for the telescope's light path and -- in the lowest, teal-color section -- for the end of the Vixen tube as well), while the tan sections are the cylindrical walls of the cell the retaining ring.   Note the assembly consists of three separate pieces (from top to bottom, these are the retaining ring, the main section of the cell containing the objective lens + the female threads that mate with the end of the 90mm O.D. Vixen short tube, and finally at bottom a tapered conical 'rear trim' piece).  All three pieces are held together by two sets of three screws (only one screw of each set appears withing the tan cutaway wall section, as the other two screws in each set are positioned at +/- 120 degrees around from the single screw shown ... see post #2) .
Actual photos to follow in the next message . . . .
           -- Jim
[**] EDIT:  I didn't mean to gloss over the differences between the well-regarded F=500mm (f/5.56) 90mm SVBONY SV48P OTA and the F=600mm (f/6.67) 90mm objective lens chosen here (indeed on Ali-Express Ruite does offer an f/5.56 90mm lens also).   But it's just that in the case of the left-over Vixen FL-80S tube + focuser I was starting with here, both the objective lens *and* the focuser body are threaded onto the opposite ends of the tube, so shortening the focal length much beyond the original 80mm f/8 (F=640mm) length of the original FL-80S lens was not an option, short of machining new male threads around one end of the aluminum tube.
Also, close inspection of the top CAD drawing above (my notional 2D meridional layout) will reveal slanted lines representing the paths of marginal light rays from the edge of the rear surface of the lens to (far off-screen to the right in the CAD view) the edges of the focal plane inside the focuser drawtube.  Including these in my CAD layout helped me determine where to resposition the Vixen short tube's three internal light baffles --- originally designed and positioned for the D=80mm F=640 (f/8) lens) so as not to cause vignetting when used with my D=90mm F=600mm (f/6.67) lens instead.  The internal light baffle closest to the objective lens can be seen in the view of the CAD layout above, far over on the right side.
Edited by jkmccarthy, 28 July 2023 - 02:41 PM.
  • tturtle, deepwoods1, Terra Nova and 5 others like this
#2 jkmccarthy
jkmccarthy
Posted 28 July 2023 - 06:44 AM
PHOTOS !!
1) Before and after glass was installed --
Note the square channels (slots) cut in the wall of the lens cell section that surrounds the glass ... these are provided for small 3D-printed rectangular shims, either plastic [fixed points] or solid rubber [compliant].  Here I've chosen to populate only three of the six slots, two with plastic shims (at 4 o'clock and 8 o'clock) and one with a rubber shim (at 12 o'clock).
As seen in the lower photo, in between the glass and the 3D-printed rectangular shims are 5mm diameter half-cylinder shaped shims of ABS plastic -- this half-cylindrical material I found-on / purchased-from amazon (https://www.amazon.c...e/dp/B07GBM155C), then cut to length, and filed-by-hand the flat side for the desired height and width.  Notice in the first picture of post #3 immediately below that Sean was successfully able to design + 3D-print side rails, each rail measuring 0.5mm tall x 0.75mm wide, running the length of the 3D-printed rectangular shims in order to hold these white ABS plastic half-cylinders in place.  The black 3D-printed shims are each 17mm long x 6mm wide x 2.0mm[**] deep in the region below the white half-cylinder shims that sit on top of them.
[**]Sean designed+fabricated these black 3D-printed shims for me in sets having a range of depths (2.0mm being the thinnest), and as previously mentioned he used both hard plastic (PLA-CF) and solid rubber (95A TPU) material for different flavors of each set.
Edited by jkmccarthy, 28 July 2023 - 02:44 PM.
  • tony_spina, deSitter, RichA and 6 others like this
#3 jkmccarthy
jkmccarthy
Posted 28 July 2023 - 06:58 AM
2)  Close-ups of the 3D-printed rectangular shims, and sitting on top of them, the pieces of 5mm diameter ABS half-cylinder rod that contact the glass:
... plus a close-up of one of these after being installed in the lens cell, before the front retaining ring was installed ...
(The reason why the portions of the ABS cylinders facing the camera have small (0.05mm deep) flats is because in the Ali-Express 90mm / 600mm achromatic doublet I received, the crown element has an O.D. that is 0.1mm larger than the O.D. of the flint element).
Edited by jkmccarthy, 28 July 2023 - 11:09 AM.
  • deSitter, tturtle, deepwoods1 and 3 others like this
#4 jkmccarthy
jkmccarthy
Posted 28 July 2023 - 07:03 AM
3) When the retaining ring is installed on the front of the cell, Sean and I decided there should be O-rings around the screws to oppose the compression force of the screws, in order to minimize any tendency of the retaining ring to distort as the 3 pads underneath the retaining ring contact the glass.    These photos show the O-rings before (with retaining ring screws very loose; pads well above the glass) and after the raised pads first made contact with the glass ...
4) Front view with the front retaining ring installed, ready to snug the retaining ring screws (done under CFL illumination in another location)
5) Close-up view from an oblique angle, showing one of the three pads on the retaining ring contacting the front surface of the lens:
... and its location relative to one of the three spacers in-between the two elements of the achromatic doublet, and one of the three flanged hex head screws that attach the retaining ring to the front of cell.
Edited by jkmccarthy, 28 July 2023 - 10:25 AM.
  • deSitter, tim53, tturtle and 4 others like this
#5 jkmccarthy
jkmccarthy
Posted 28 July 2023 - 07:11 AM
6)  With lens cell mated with the Vixen short tube and focuser ... on two different telescope mounts ...
7) Waxing crescent moon captured earlier this week with a Fujifilm X-H1 camera body (APS-C size imaging array, 6000x4000 pixels) at prime focus of the Ali-Express 90/600 lens in the custom lens cell 3D-printed by Sean (norvegicus) ... this first photo was resized by 0.5x to 3000x2000, then cropped it to create this 1200x800 pixel subset ... so each pixel here is 2x2 pixels in the original image:
Native scale is 1.3-arcsec per pixel, so after having been resized, the image above has a scale of 2.6-arcsec per pixel.   Apart from the resize (and whatever extra[?] JPEG-compression happens during upload to CN), this is a JPG image straight from the camera ... single-frame, no cherry-picking from video, and no post-processing by me to sharpen the image etc.
Visually I could definitely see a blueish-indigo fringe in the sky west of the moon's limb (as in the eyepiece, the moon itself was brighter-white than in the image recorded by the camera, and the human eye's response is logarithmic with greater dynamic range than the digital image sensor's linear response), but there's very little of it in the straight-from-the-camera jpeg here, either before or after my resize-and-crop (only) edits.
Edited by jkmccarthy, 28 July 2023 - 11:05 AM.
  • tony_spina, tim53, tturtle and 6 others like this
#6 jkmccarthy
jkmccarthy
Posted 28 July 2023 - 07:31 AM
8) If instead of resizing by 0.5x, I simply crop 1200x800 pixel subsets from the original image, these are the upper portions of the moon at full-scale (i.e., highest resolution the camera could record -- 1.3 arcsec per pixel) -- click on any of the pictures presented thus far to view the full 1200x800 versions:
Again, I have not applied any after-the-fact sharpening to the JPEG images out of the camera ... if anything, I suspect that the camera's internal noise-reduction default setting might be applying some in-camera smoothing prior to generating the output JPEG.   Visually, the features along the terminator appeared sharper in the eyepiece than in these full-resolution subsets from my digital camera (again, maybe because the images are a bit "underexposed" [and hence have less-than-maximum contrast between the sunlit and dark regions of the moon] compared to the brighter image presented by the eyepiece).
Comments welcome --- and finally, again, my heartfelt thanks to Sean for all his contributions to and efforts on this collaborative effort !!
          -- Jim
Edited by jkmccarthy, 28 July 2023 - 11:07 AM.
  • Weisswurst Josef likes this
#7 deSitter
deSitter
    Still in Old School
Posted 28 July 2023 - 08:28 AM
I am pretty sure this lens will perform better with the original spacing. I had a Meade 90mm where the plastic spacer ring broke. I replaced it with foil and the color correction was very obviously worse. I then made a new spacer like the original from stranded wire cut to exactly the right length to fit in the cell between the elements. The original performance returned.
-drl
  • RichA likes this
#8 deSitter
deSitter
    Still in Old School
Posted 28 July 2023 - 08:29 AM
PHOTOS !!
As seen in the lower photo, in between the glass and the 3D-printed rectangular shims are 5mm diameter half-cylinder shaped shims of ABS plastic -- this half-cylindrical material I found-on / purchased-from amazon, cut to length, and filed-by-hand to the appropriate size.
This is really nice work!
-drl
  • jkmccarthy likes this
#9 norvegicus
norvegicus
  • Loc: en route
Posted 28 July 2023 - 12:59 PM
This was a fun project, my first actual telescope making type experience.  I had no idea how to build a lens cell before this.  This design worked well for 3D printing, and should be stable and easy to service.
  • deepwoods1, Terra Nova, jkmccarthy and 1 other like this
#10 Kasmos
Kasmos
  • Loc: So Cal
Posted 28 July 2023 - 02:27 PM
You guys did a great job!
Maybe I missed reading something, so I have a few questions.
I thought the retaining ring is held by three screws, if so why are there these threads?
Are they just for anti-reflection purposes?
Also, in the area that looks like threads on tube, does the cell thread on to the tube?
Lastly, how are the threaded inserts held in place, with glue?
  • jragsdale likes this
#11 norvegicus
norvegicus
  • Loc: en route
Posted 28 July 2023 - 07:47 PM
The thread in the retaining ring is for a filter. IIRC Jim has an energy rejection filter in this size for solar work with a Quark.
Yes the cell threads onto the tube. You are looking at the space that the tube fits into.
The threaded inserts are heat set into the printed plastic. The holes for them are printed slightly undersized.
Edited by norvegicus, 28 July 2023 - 07:52 PM.
  • Kasmos and jkmccarthy like this
#12 Terra Nova
Terra Nova
Posted 03 August 2023 - 01:36 PM
Nice job. I hope it’s all working out for you. I have a SvBony SV48P and tho it’s not a classic, it’s classic fun to use! It’s everything the ST80s should have been for about the same cost. I can’t get over how much telescope I got for a little over 200 bucks, brand new and shipped! The dual speed finder itself is worth more than what I paid for the scope.
  • rcwolpert and jkmccarthy like this
#13 DocFinance
DocFinance
  • Loc: Clear Lake, Texas
Posted 04 September 2024 - 04:12 PM
Great work.  My high schooler just got a 3d printer up and running, and printing parts for various Wollensak and Jaeger lens sets is going to be the first bunch of projects.  I think I need to find plans for adjustable cells first and foremost.
Thanks for the inspiration.
  • jragsdale, jcruse64 and jkmccarthy like this
Also tagged with one or more of these keywords: 3d printing, ATM, Classic, Refractor
