Remember, an image intensifier intensifies "all" light, even sky glow.
Which (especially in periods with lots of solar activity) means in a really dark sky you might want an IR cut filter rather than an IR pass.
Posted 05 September 2024 - 05:52 AM
Posted 05 September 2024 - 03:15 PM
Any eyepieces other than a TV 55mm that the TV scaffold will fit, unless smoothie TVPs?
Posted 05 September 2024 - 03:47 PM
If you scroll down to the section for the TV adapter on this page, there is a link to the recommended eyepieces that will work with it.
https://televue.com/..._page.asp?id=36
Posted 05 September 2024 - 10:25 PM
I was lucky in that I had a few of Radian EPs, and while not the best to use because of the adjustable eye guard, they have worked fine for me. They are nicely sized (8,10,12,14, & 18mm) for my 540mm FL refractor. I use a 5 & 7mm DeLite for extreme magnification but rarely use them. With my longer FL scopes (2300-2600mm) I use the 32mm plossl most often. Sometimes the 40mm might frame a larger open cluster better and a 27 Panoptic works well for the higher magnification but the 32 gets used 90% of the time. The converted 55 plossl with a 7nm filter fits my B7-B8 (18.40 average) skies. I’m still new to Ha and have never tried from a dark site but have been told dark skies makes a big difference. I observe from home, so I’ve never tried it from a darker site. I purchased my NV equipment to make Bortle 8 palatable which then PVS-14 does well in. Here is NGC 7000 ( a poor pic) through the converted 55 plossl to give you an idea of the FOV in my refractor.
Posted 06 September 2024 - 12:55 AM
I have an older 55mm Plossl smoothie made in Japan. It will not take the 67mm adaptor according to that page, though my newer 40mm Plossl would. That means a smaller exut pupil, if not FoV.
The cost of NVDs for astronomy, includes kit to get the expensive device giving best results. When filters and other accessories are added, the total price builds up.
Edited by 25585, 06 September 2024 - 11:44 AM.
Posted 06 September 2024 - 05:17 AM
I have an older 55mm Plossl smoothie made in Japan. It will not take the 67mm adaptor accirding to that page, though my newer 40mm Plossl would. That meand a smaller exut pupil, if not FoV.
You can drop thousands on an apo refractor but you still can't use it without accessories and a mount.
Bob
Posted 06 September 2024 - 12:21 PM
It can be a little less expensive if you get a device that supports prime focus. Minimally, all you need is an eyepiece adapter and a couple of filters. Going with 1.25" as opposed to 2" further minimizes cost.
Posted 06 September 2024 - 10:10 PM
Besides the level of LP you're observing in, the scope used and what objects you're after is something to consider. There might be a minimalist approach that might be w/i your reach. What is your goal?
Posted 07 September 2024 - 06:21 AM
Globular clusters, planetary nebulae to start with.
Posted 07 September 2024 - 10:10 AM
NV will certainly revolutionize globular clusters for you.
However, on PN's you have to realize that the majority of them have very small angular diameters. High Magnifications are a regime where NV astronomy shows its limits due to resulting high effective focal ratios. The only saving grace is that many (but not all) have high surface brightness. So yes, you will be able to detect huge numbers of small PN's and check them off of your list.
Oh, and the fact that one of the appeals of those small high-surface brightness PN's is that they are brightly colored.
PN's are therefore a mixed bag for NV.
Posted 07 September 2024 - 01:28 PM
Posted 07 September 2024 - 02:11 PM
I just know what works from my skies, but I'd say (excluding wide field Ha DSOs) globulars respond best. Open clusters come in second and NV puts galaxies w/i my reach. Some of the bigger and/or brighter PN's respond well but I generally don't expect much with the smaller PN's.
Whether the cost is worth the jump, I'd suggest seeing an intensifier in action before a making a purchase. Make sure the ocular adjustment can work with your vision, and it works for your type scope and level of LP.
They can be a bit bulky. With the setup shown, I still need to add an extension to reach focus. Could you imagine this with a 31 Nagler and a 2x powermate?
Posted 08 September 2024 - 02:57 PM
Probably a 2" eyepiece would be more stable. A 2" diagonal would increase back focus to an extent. I would be using an Amici 2".
Posted 08 September 2024 - 09:07 PM
A sturdy 2” focuser and diagonal are helpful no doubt, but I rarely use any of my 2” eyepieces. I feel the shorter and lighter TV EP's work fine for my needs, plus they're cheaper. I swap EP’s for framing primarily, but also for contrast. Generally, I use 2" to 1.25 adapters and prefer 1.25 filters mounted on the adapter rather than on the EP. If I were allowed only one EP for my use in each scope, (from my level of LP), the refractor would get my 10mm, and the SCT the 32mm.
Posted 10 September 2024 - 03:21 AM
If good night vision devices were cheaper generally, they would be useful for more than astronomy.
Posted 10 September 2024 - 05:48 AM
They are useful for more than astronomy or they would not exist (here in Europe, hunters and airsoft enthusiasts seem to have a copious amount of them and on the second hand market we can just harvest the crumbs).
Here it's actually illegal to hunt with them and it's illegal to have one that can be (trivially) mounted on a hunting rifle. That they needed to write a law for it tells you about the prevalence...
Edited by sixela, 10 September 2024 - 05:48 AM.
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
