A small displacement of a Cass secondary can result in a large focus shift. That kind of flexibility is so advantageous that advanced scopes are built with a motorized secondary. It's typical that one is likely to move the focus position out to accommodate accessories that chew up a lot of backfocus. For example a generic 12" f/10 RC secondary is shifted 5mm closer to the primary, the image is displaced about 60mm farther out. What is interesting to note is that the image quality will degrade with increasing image displacement from the design position. Assuming said 12" scope has perfect optics, that 60mm image shift will introduce almost 1 wave of pure spherical aberration. If one focuses the image to minimize the pure spherical one get about a 1/4 wave wavefront. Now 1/4 wave is not too bad, but if you paid for perfect optics...
That kind of degradation will not be discernible if one is imaging, but it will affect visual image quality under the best seeing conditions.
The B&C 16" is more forgiving. Only a 1.6mm secondary movement will yield the same 60mm image displacement, and the focused image quality is still better than 1/10th wave.
