It's been awhile since a lot of this work was done so I'm going by memory
One of the first things done was removing the 5mm EP from the Diagonal.
I just used some WD-40 to lube it and thankfully it pulled out with little effort.
What was left of the thumb screw had sort of a raised notch where it broke.
I can't remember if I drilled it out or if I turned it inward with a small screw driver.
I think it threaded in easily.
The Diagonal with the VB's Thumb Screw temporarily threaded in.
While the Diagonal looks really bad the EP protected the prism.
To clean it up I tried to remove it's back and the head of the upper right screw broke off.
I drilled and picked out what was left it and was lucky that I didn't ruin the threads.
I had screws from another diagonal for replacements but since they were black Phillips heads,
I used them to replaced the 2 on the bottom (not shown) and used 2 of the chrome ones on the top where they show.
The diagonal, the EP and VB will be re-painted later.
The focuser was next on the list and this bottom view shows it's condition
One knob wobbled meaning the pinion was bent on one side.
I like to set the knobs in a protected vise and use the toothed edges of the knob
to fine tune rotating it to the high spot and use a wood dowel as a punch.
A black mark is used to indicate the high spot.
It's rotated so that it shows in this photo but it helps you if you need to slightly
rotate and gauge it's position while you work.
If it looks good rotated in the vise I then check it by laying it loose in the focuser without the rack tube.
Lightly holding it's cover down when rotating I couldn't detect any wobble so I knew it was good to go.
I don't know how else to guide you other than a few light blows on the high spot was done by feel.
Punching it on where the shaft doesn't ride in the housing or under the cover is also a good idea.
The focuser felt way too tight so I think that's why I removed the shims.
In retrospect I'm not really sure why I did. I think they just fell out?
The center one has 3 marks from the small screw adjusters in the top of the focuser housing.
After cleaned of residue and roughness they were re-glued using a clear contact cement I found at Dollar Tree.
A test showed it felt great, but later I made the mistake of setting it on a heater to cure.
I got distracted and left it too long so it must have swelled the glue which made it once again too tight.
I lightly sanded them (in place) and they now feel just right.
I made some black index marks to mark the shim's locations.
One shim was cocked so I glued it back the same since it was already twisted to that shape.
Like the finder and the tube, the housing is also marked with a #38 in red.
Before putting it back, all of the OTA's hardware was cleaned and polished.
As always I tend to use Nevr-Dull and Blue Magic for this type of stuff.
Edited by Kasmos, 20 August 2023 - 07:03 PM.
