Back to the Restoration
This kit was missiing the tripod hub and it's legs.
Some similar legs from another make of scope will be fairly easy to find,
but an original Atco 1252 Hub would be next to impossible.
Here's what a Atco 1252 hub looks like.
The gray ones look just like the black ones but have a straight cut center hole,
while the black ones holes are tapered.
The hub from my Kenko is very similar to both types of Actos,
but there's no way I'm going to pirate it from that scope.
When I posteded this scope and it's situation in the 'finds thread',
Sean (norvegious) kindly offered a couple of hubs that I might modify.
He also offered 3D printing one but I wanted it to try it using old school methods.
The method would be similar to the one I made for a Swift 839, but not quite as involved.
Swift Hub Link:
https://www.cloudyni...ons/?p=10912288
One was from a fairly modern Celestron, the other was from a Towa GEM.
I had him send the Towa.
It's quite a bit larger in diameter than an original 1252 but it's is the best I could do (for now)
The first issue was how would I drill out/enlarge the center hole?
I don't have sophisticated machine tools so I drilled a bunch of smaller holes.
This was done by hand from the outside and at an angle...
The holes at the clamp bolt channel had to be drilled from the inside.
Then all of the holes were slowly enlarged until the center section could be taken out.
A new center section was made from materials left over from the Swift hub.
The plastic piece was cut from a PVC pipe coupler and the brass is a drain pipe.
I found that if it was cut just right, the inner sleeve had the correct ID when pressed into the PVC coupler.
The ID is the same as the Swift, so I wish I had discovered that on it's hubs build.
I used a circle template to score a guideline and filed the new hole to size.
Test fitting the sleeve...
...and with the collar.
Another coupler will be made and go on the underside.
Edited by Kasmos, 12 September 2023 - 03:11 PM.
