[...] Regarding the APM Hi-FW Tammy measured it's pseudo-AFOV as 88º, so it might has true AFOV of 80º but its aberrations result on a much larger TFOV. It would be interesting if you could compare the TFOV with the Morpheus 12.5 measuring it as done at the photos of #2 and #3, with and without the LBV...
Alright, I had myself a bit of fun over the holidays.
I tried to reproduce the type of test you had done. So I setup my Sky-Watcher ST-120 mm refractor with 600mm focal length indoors, pointing towards the wall 10m/33ft away. On the wall I taped a graph paper with a grid with squares (9 or 10mm wide) and a ruler. I made sure the paper and ruler was completely flat against the wall, so any distortion you see is definitely the effect of the eyepiece. I then inserted the eyepieces one by one and took a photo through them. I should say that I hand-held the camera, but I was pretty steady and had to very precisely center the camera over the exit pupil to not get optical defects. You could really easily see the different types of distortions the different eyepieces produce.
Here is the APM Hi-FW 12.5mm 84° compared to the Morpheus 12.5mm.
What the photos above show is how close in terms of AFOV the two eyepieces are. I know, it's not a perfect test, but I think it says something. I haven't moved anything between the tests, and the camera has to be at a very precise focal point to not be vignetted, so I consider the images "to scale". Counting pixels the APM is just a little over 1% wider, which would be about 1 degree AFOV wider. My completely subjective visual assessment if you remember was about 2 degrees wider.
It was also pretty clear that the Morpheus has a lot more pincushion distortion, while the APM has a really what I would call flat (distortion-free) field. I've never really understood the "flatness" of flat eyepieces, I thought it had more to do with having less field curvature (not same focus in the center and at the edge) and maybe it does. It was clear during this test that some eyepieces could not focus both in the center and at the edge, and the APM was actually one of those, but at the same time I don't know if the test setup is suitable for drawing conclusions on this since the grid paper was really close (10m/33ft) and the ST-120 also has a really short focal length. But out of all my 10-12 eyepieces I tested like this, it was primarily the three eyepieces that are marketed as "flat" that also had the "flattest" non-distorted field in this test, the APM Hi-FW, the UFF18 and the UFF10, so I found that pretty interesting.
In any case, the pincushion distortion of the Morpheus really reduces the TFOV by magnifying the edges more than the center. I count 217mm on the ruler for the APM Hi-FW and 186mm for the Morpheus 12.5. That's a 16.7% increase for the APM, approximately 89 degrees if the Morpheus is considered 76 degrees. So that to me explains why they can both be considered 12.5mm eyepieces, have almost the same AFOV, yet be marketed with such different FOVs.
Edited by Olle Eriksson, 30 December 2024 - 05:35 AM.
