The System...
...is so perfect, so rigid and so flawless (...knock on the wood) that you can't get any better than this. You turn things ON, if sky is clear and the system is temp. equalized, all you get is a perfect guiding for exposures as long as you like, ZERO rejects, round stars corner to corner, and an image bursting with signal. Barring the unforeseen, I couldn't ask for more. Regards
IMPORTANT: All I am trying to say is that due diligence in designing, wiring, attention to detail, and optimizing has gains to be reaped in the performance on a daily basis. Only time I have run into problems was where system was just not temp. equalized, unbeknownst to me at the time and which I learned the hard way with special guidance by non one other than Roland of A-P. My special gratitude to him, along with the workmanship of the folks at Planewave!
Note: The image is a sample of the performance of the system and should be regarded as such, NOT a library of images to be posted in other forums. A short, Hydrogen and Oxygen integration of the Tulip in ASTAP with negligible post in Lightroom; no calibration other than dark.
Note: Take the orthogonality numbers with a grain of salt unless you are 100% sure what you are doing. There are anomalies unrelated to orthogonality, especially temp. changes that appear as tilt. If in doubt, run the fans of CDK14 to get the plumes out even in an equalized system.
Note: Most OAG anomalies will also be the results of temp. changes reeking havoc on the system. If in doubt, run the CDK14 fans to get the guiding corrected to perfection.
Too many optimizations to list here; more in coming posts.
Edited by mmalik, 28 August 2023 - 10:47 PM.
