OK, got it setup. The lift table made it easy. There are issues:
1.) I cannot polar align it because the mount head wants to flop down as soon as I try to tilt it that way. There is too much weight for the pivot to hold up.
2.) There is not enough counterweight to balance on the polar axis. I will need to dig up the counterweight from my 10" Starfinder EQ mount and see if it will fit the shaft. If not, then maybe a Cave counterweight will work. Of course, this will make number 1 worse.
3.) The finder mount puts the finder too close to the telescope tube. Either that or my head is too big.
I did a rough collimation and then I glanced at Saturn, but it obviously still needs to cool down some more.
Next will be to get the Magellan II system working.
This is a very fun project. Keep at it, you will be rewarded. Others have struggled with that neck pivot and found solutions.
-drl
