EAA Monthly Observing Challenge - September 2023
291 replies to this topic
#1 Cey42
Cey42
  • Loc: Kirkland, WA
Posted 31 August 2023 - 05:10 PM
Welcome to the September 2023 challenge! I gathered a wide variety of objects for you to enjoy. Several of these are new to the challenge.
September 2023 Objects
Double Stars: Albireo, 61 Cygni
Open Cluster: NGC 7160
Globular Cluster: M 2, M 71
Planetary Nebula: NGC 6826, NGC 6905, NGC 7026
Emission Nebula: IC 1396A/LBN 452, NGC 6992
Dark Nebula: Barnard 143
More Information
A lot of the objects this month are in Cygnus. A constellation with lots of great objects in it, which includes my favorite double star (Albireo) and my favorite wide FOV object (Veil Nebula).
Double Stars
Albireo, in Cygnus, makes its first appearance to the EAA challenge. Albireo is a beautiful colored optical double star. The main star Beta Cygni A (mag 3.2) is yellow in color while the Beta Cygni B (mag 4.7) is blue. To capture these colors use low gain and short exposure. https://en.wikipedia.org/wiki/Albireo
61 Cygni is also a first in the EAA challenge. This pair of yellow stars are of similar magnitude of 5.2 & 6.0 look like a pair of headlights. These stars are interesting for several reasons. In 1792, it was discovered that these are a pair of high proper motion stars. With an annual proper motion of 5.28” these are the seventh ranked stars for proper motion. I hope to come back to this one over the years to see if we can see the motion. In 1838, these stars became the first stars (other than our Sun) to have a distance estimated of 10.3 light-years close to our current value of 11.4 light-years. https://en.wikipedia.org/wiki/61_Cygni
Open Cluster
NGC 7160 – Another first appearance to the EAA challenge. Both William and John Herschel each only viewed it once, not a popular cluster with the Herschels. There is a fun asterism here called the Alligator Cluster, which is why I added it. Two stars are the nostrils, two bright stars the eyes, and then several stars forming the body. Do you see it? https://en.wikipedia.org/wiki/NGC_7160
Globular Clusters
M 2 – This compact globular cluster, in Aquarius, is one of the richest known with between 100,000 and 150,000 stars. https://en.wikipedia.../wiki/Messier_2
M 71, in Sagitta, makes its first appearance to the EAA challenge. Until the 1970s, M71 was classified as packed open cluster. This is in a dense star field. https://en.wikipedia...wiki/Messier_71
Planetary Nebula
NGC 6826 (Blinking Planetary Nebula) – We make our way back to Cygnus with NGC 6826. This is a lovely planetary nebula 36” in diameter but one should be able to capture the structure. For those using SharpCap, it may help to move the mid-line way right to see the structure. https://en.wikipedia.org/wiki/NGC_6826
NGC 6905 (Blue Flash Nebula), a small nebula in Delphinus, makes its first appearance to the EAA challenge. My images of this one reminds me of a blue-green version of NGC 40. https://en.wikipedia.org/wiki/NGC_6905
NGC 7026 (Cheeseburger Nebula) – Another newcomer to the EAA Challenge. NGC 7026, in Cygnus, is a bipolar nebula showing quite a bit of structure. Discovered in 1873 by Sherburne Burnham an amateur astronomer who worked as a court reporter by day. https://en.wikipedia.org/wiki/NGC_7026
Other Nebula
IC 1396A/LBN 452 Elephant Trunk Nebula, in Cepheus, is an elongated globule of dust and gas within IC 1396. The nebula hides young protostars that are forming. https://en.wikipedia...'s_Trunk_Nebula
NGC 6992 East Veil Nebula – Last month we observed the Western part of the supernova remnant and this month I wanted to focus on the other side. The East Veil Nebula is composed of NGC 6992, NGC 6995 and IC 1340. If your FOV is not big enough for all three, focus on NGC 6992 on the North end. The supernova is believed to have exploded 5,000 years ago. https://en.wikipedia...iki/Veil_Nebula
Barnard 143 (LDN 694) is a dark nebula in Aquila. Living in Bortle 7 skies, I have a hard time capturing dark nebula. This is one of the few that have come out well for me. I hope it is the same for you. https://en.wikipedia.org/wiki/E_Nebula
Here is the SkySafari observing list.
Attached File  CN Sept 2023.skylist   2.17KB   50 downloads
Thank you and I hope you enjoy the collection this month.
  • Bob Campbell, Ptarmigan, gun4hire and 15 others like this
#2 alphatripleplus
alphatripleplus
    World Controller
  • Loc: Georgia
Posted 31 August 2023 - 05:40 PM
Nice selection, Cey. Looks like you are correct that this is M71's debut in the monthly challenge. smile.gif
#3 roelb
roelb
  • Loc: Belgium, Antwerp
Posted 31 August 2023 - 05:46 PM
#4 tbhausen
tbhausen
Posted 31 August 2023 - 07:48 PM
This is an exciting list! Such a bummer to miss August... I really need my camera--the Swan holds so many treasures!
#5 BrentKnight
BrentKnight
  • Loc: Foley, Alabama
Posted 31 August 2023 - 08:57 PM
Lot's of darks - thanks Cey!
#6 Tfer
Tfer
  • Loc: Northern Alberta, Canada
Posted 01 September 2023 - 12:26 AM
Hopefully, I’ll be able to spend an evening or two grabbing these.  Thanks Cey.
Your addition of the SkySafari list is invaluable as always.
#7 gun4hire
gun4hire
  • Loc: South Dakota
Posted 01 September 2023 - 08:15 AM
Here we go!!! I was fighting the fullish moon rising and getting brighter by the minute...It won in the end! Bad seeing to add to the problems. I was impatient, since I got a new Optolong Ultimate filter. I picked the objects best suited for my ASKAR FMA180 (and 2 that were notlol.gif ). The new filter was great! It killed some stars, but nice white stars!!!
ZWO 294 all cropped a tiny bit at least to get out some of the amp glow..Flats and darks. Apparently not done totally correct. I have an ASKAR 107PHQ coming, so I will save a few challenge objects for it!!
get.jpg?insecure
Elephant Nebula--60 frames 30 minutes
get.jpg?insecure
Eastern Veil--40 frames 20 minutes
get.jpg?insecure
NGC7160--10 frames 10 minutes cropped a lot
get.jpg?insecure
Albireo-- 8 frames 4 minutes cropped extreme.
Edited by gun4hire, 01 September 2023 - 09:58 AM.
  • Bob Campbell, Ptarmigan, alphatripleplus and 12 others like this
#8 dob45
dob45
  • Loc: Italy
Posted 01 September 2023 - 09:12 AM
ngc 6826 and ngc 7026 are two PNs with similar characteristics: small and with high surface brightness. Has anyone ever tried to shoot them with a 2x or even 3x Barlow? or is it crazy?
#9 GazingOli
GazingOli
  • Loc: Stuttgart GERMANY
Posted 01 September 2023 - 09:24 AM
Thanks for the selection. First time for me to try on dark nebulae.
CS.Oli
#10 BrentKnight
BrentKnight
Posted 01 September 2023 - 09:30 AM
Here we go!!! I was fighting the fullish moon rising and getting brighter by the minute...It won in the end! Bad seeing to add to the problems. I was impatient, since I got a new Optolong Ultimate filter. I picked the objects best suited for my ASKAR FMA180 (and 2 that was notlol.gif ). The new filter was great! It killed some stars, but nice white stars!!!
get.jpg?insecure
get.jpg?insecure
get.jpg?insecure
get.jpg?insecure
Nice captures.  I mounted my L-Ultimate, but no chance to use it yet.  Maybe this weekend.  You are going to love the 107PHQ!
  • mklosterman1 and PeterAB like this
#11 Maximumron
Maximumron
  • Loc: Far northeast Iowa
Posted 01 September 2023 - 11:13 AM
Great list, Cey! I see some real challenge objects in there. Can't wait to get at it!
#12 bigbangbaby
bigbangbaby
  • Loc: USA
Posted 01 September 2023 - 03:38 PM
Thanks, Cey! Great list.
#13 Cey42
Cey42
  • Loc: Kirkland, WA
Posted 01 September 2023 - 04:25 PM
@gun4hire Nice captures. The narrowband filter really does help with Eastern Veil Nebula and the Elephant Nebula. I see a nice alligator and that you split Albireo.
#14 Clouzot
Clouzot
  • Loc: French Riviera
Posted 01 September 2023 - 05:33 PM
It's not crazy at all, but it really depends on what OTA/camera combo you'll be using. The usual "astrograph-like" Newton with f/D < 5, a more substantial Dob with a longer focal length, or even a Mak?
The thinking here is that the usual planetary techniques can apply to PNs, albeit with some adaptations.
Take for example the usual rule-of-thumb that says: for planetary imaging, the pixel size (in µm) should be between one third and one sixth of the f/D ratio of your telescope. One third to be used when the seeing is not optimal, and one sixth when the sky cooperates.
If you need a Barlow for the pixel size to be between 1/3 x fD and 1/6 x fD, then install it and don't look back
I did shoot 6826 a long time ago at my C9's native focal length (f/D=10, 2350mm) and an ASI183 (whose pixel size is 2.4µm, so well inside the above "bounds")
I think a good way to grab details and structure is to use the shortest possible exposures that still allow Sharpcap to detect stars and align your frames. In my case, 8s was the absolute minimum, because the old Sharpcap wasn't that good at detecting faint stars, and seeing degraded details a lot, but I'm sure one can do much, much better now.
Screenshot 2020 07 25 At 01.22.40
(thanks Cey for this month's selection. It's a very nice list)
  • Bob Campbell, Ptarmigan, mklosterman1 and 6 others like this
#15 PeterAB
PeterAB
  • Loc: Southern Wisconsin, USA
Posted 01 September 2023 - 09:47 PM
I got out under the very bright moon early morning September 1.  I was working on my Astro League open cluster project.   Star clusters are great objects when the moon is out.   I added the two challenge globular to my observation list for the night.   Seeing was unusually good.    No wildfire smoke!  This is my first completely clear night all summer.    Transparency reduced m3.5 naked eye because of the moon.   Cool temperatures and light wind made for a very nice out.
Astro Tech 102EDL f7 refractor, Sky Rover 1.0x flattener, asi294mc, IR/UV cut.  Sharpcap 4.1 with darks, flats, and color noise reduction.   Gain 130.   Exposure guided.    Guiding was working unusually well with my old CG5 ASGT mount,  seeing maybe?     All views north up, east left 1.5x1 degrees.
M2 (NGC 7089).  345 seconds (23x15s).   A very tiny galaxy, IC1391, is hiding out in the northeast.   Best seen in the live view and uncompressed saved image.
M71 (NGC 6838).  540 seconds (36x15s).   Globular cluster with old yellow stars in a rich milky way foreground star field.
IC1396.  180 seconds (12x15s).    This observation was also for my open star cluster project.   I stretched the live view a lot for this image.   I  just got the dark nebula.   I do my open cluster program observations without a dual band filter to bring out the stars vs the nebula.   I like the star view, but, I think I will try a second view with a dual band filter.
Peter
Edited by PeterAB, 01 September 2023 - 10:13 PM.
#16 PeterAB
PeterAB
Posted 01 September 2023 - 10:33 PM
One more challenge open cluster from early morning September 1.   Same conditions and equipment as above.
NGC 7160 (Alligator Cluster, Bruce Lee Cluster).   360 seconds.   This is not on my open cluster program list.   It is on Don Pensack's 500 best deep sky object list that I am working through.   An attractive cluster in a rich star field.
Peter
Edited by PeterAB, 01 September 2023 - 10:56 PM.
  • Bob Campbell, Ptarmigan, roelb and 6 others like this
#17 bigbangbaby
bigbangbaby
  • Loc: USA
Posted 02 September 2023 - 12:54 AM
The second evening getting acquainted with narrowband EAA was mostly unproductive, though I managed to get one image for the September challenge.
8" f/4 Newtonian + Nexus .75 reducer
ASI294MM Pro @ 0 deg C
PHD2 guiding with 50 mm Orion guide scope and ASI224 camera.
AM5 mount
Eastern Veil, NGC 6992; 10x30 sec each of SII, OII and HA
NGC6992_2023-09-02, 10x30R 10x30G 9x30B 10x30L, (SII Ha OIII Ha), ZWO ASI294MM Pro.JPG
Edited by bigbangbaby, 02 September 2023 - 09:26 AM.
  • Bob Campbell, Ptarmigan, mklosterman1 and 12 others like this
#18 dob45
dob45
  • Loc: Italy
Posted 02 September 2023 - 02:14 AM
thanks for the advices !
I'll try to apply them to my 18" f/4.2 dobsonian....
#19 dob45
dob45
  • Loc: Italy
Posted 02 September 2023 - 02:30 AM
I had observed  some of the objects on the list in recent months:
18" f/4,2  self-made dobson, ASI 178MM , Bortle 8 ,  resize, crop, no dark, no flat, bin 2
ngc 6905 (106x2s=212 seconds)
M71 (40x2s = 80 seconds)
vdB142-LBN 452 Elephant Trunk Nebula (75x4s = 300 seconds)
  • Ptarmigan, RGWOOD, mklosterman1 and 11 others like this
#20 kaymann
kaymann
  • Loc: Arizona, USA
Posted 02 September 2023 - 11:53 AM
  • steveincolo likes this
#21 gun4hire
gun4hire
  • Loc: South Dakota
Posted 02 September 2023 - 12:44 PM
AM5 mount
Looks like we are standing there!!! sweet and scary looking at the same time!
  • roelb likes this
#22 Cey42
Cey42
  • Loc: Kirkland, WA
Posted 02 September 2023 - 04:31 PM
PeterAB, I like your wide FOV shot of M71. A nice contrast of the yellow stars of the GC and the rest of the FOV.
Dob45, I took a double take on your image of NGC6905. Your really looks like NGC 40 to me. Nice capture of the structure.
#23 bigbangbaby
bigbangbaby
  • Loc: USA
Posted 02 September 2023 - 04:44 PM
Thanks, gun4hire. I plan to capture it in LRGB to see how it looks compared with OSC images posted here.
#24 GazingOli
GazingOli
Posted 02 September 2023 - 07:59 PM
with the 'help' of The Moon, I did the first objects of this month's Challenge:
NGC 6992 East Veil Nebula 43 frames x 16 s (click to enlarge)
IC 1396 Elephant Trunk Nebula 86 frames x 16 s (click to enlarge)
unfortunately I missed the chance to do flats yesterday afternoon...
61 Cyg 21 frames x 4 s
Albireo 22 frames x 4 s
M 2 32 frames x 4 s
M 71 (first time ever) 44 frames x 4 s
NGC 7160 31 frames x 4 s
all images captured with
Selfmade apo refractor 80 / 480 'Olifraktor' on Celestron Evolution mount with wedge
ZWO ASI 533 camera, darks applied, Baader UV/IR Cut-L Filter (Item No 2459207A)
images captured and stacked with SharpCap 4, Location Stuttgart, Germany
CS.Oli
Edited by GazingOli, 03 September 2023 - 02:36 AM.
  • gun4hire, oneuke, alphatripleplus and 10 others like this
#25 Bob_Stan
Bob_Stan
  • Loc: Northeast
Posted 02 September 2023 - 08:49 PM
Managed to get out early before the moon rose above the trees.
NGC 6905
C11 f/10
ASI 294 MCPro
12x20 secs bin 2x2
Cropped
  • gun4hire, mklosterman1, roelb and 8 others like this
