I am seeking help regarding equipment, techniques, software, etc.
Edited by smallbinos, 07 September 2023 - 07:12 AM.
Posted 07 September 2023 - 07:11 AM
Posted 07 September 2023 - 08:51 AM
What got me excited about purchasing equipment and DOING astronomical Spectroscopy was this video - https://www.youtube....h?v=Dm9HDh99y6c
I needed to understand the nuts and bolts of what I was getting into, this video was the key.
Note: I had the equipment and prior experience necessary for astrophotography
Edited by SeymoreStars, 07 September 2023 - 08:53 AM.
Posted 07 September 2023 - 09:02 AM
I started with the rspec grating. Just put in place of a filter. Cost effective and works great.
Take a look at the video and website.
https://www.youtube....h?v=Fv5fFSacVO8
Posted 07 September 2023 - 09:12 AM
I just purchased the rspec grating, it arrives on Saturday.
Posted 07 September 2023 - 02:00 PM
The Paton Hawklsey Star Analyser grating
Posted 12 September 2023 - 07:15 AM
Posted 12 September 2023 - 08:16 AM
I have also been considering the ALPY 600. What are the major differences between it and the SA100?
The ALPY is a low resolution slit spectrograph which includes the calibration and guide modules necessary for a complete system. The Star Analysers are just diffraction gratings mounted in standard filter cells which can be used stand alone as a very low resolution slitless spectrograph, either mounted in front of a camera lens or between camera and telescope. I originally developed it as a simple low cost entry into spectroscopy with the expectation that people would then migrate to proper spectrographs like the ALPY though it is possible to build it into configurations which can give resolutions matching the ALPY in certain circumstances. These slides of a comparison of slitless and slit spectrographs come from my presentations at this workshop.
https://britastro.or...he-nlo-oct-2015
These observations show examples of using the Star Analyser in its simple low resolution setup
https://britastro.or...cabda965bfe692f
https://britastro.or...e1c6a4cf219d14d
and some examples of using the advantages of the ALPY spectrograph
https://britastro.or...e77e0992eb70386
https://britastro.or...31d1ec6d134b3dc
https://britastro.or...70f474be2035d42
(the last in very low resolution mode)
and finally some examples using the high resolution of the LHIRES slit spectrograph
https://britastro.or...5356e4359198628
https://britastro.or...acdefe378f91ae9
https://britastro.or...8b30a0a785a7ab3
Cheers
Robin
Edited by robin_astro, 12 September 2023 - 08:18 AM.
Posted 21 September 2023 - 11:03 PM
At the AMOS conference I noted that some teams appear to be using a transmission grating to do spectral characterization of artificial satellites.
Posted 24 September 2023 - 08:08 PM
I studied spectroscopy as a grad student and have been wanting to do some amateur science for a while now. I heard about the Sol'Ex spectrometer earlier this year and decided I'd give it a go. (The spectra on the Sol'Ex website are pretty impressive.) You can use it to acquire solar spectra or, with the addition of a couple components, stellar spectra. It's a slit spectrometer with a 3D-printed housing and commercially-available optics. You can print the housing yourself or buy one a couple hundred dollars. (I bought one.) I've got all the components at this point but haven't had the time to assemble them and align it. Between the housing, optics and a helical focuser I'm into it for close to $1000. When I eventually acquire some spectra with it I'll share them here. If you're interested, here are links to the Sol'Ex website and to vendors for the components -
http://www.astrosurf...ntation-en.html
https://telescopes.n...she-es0031.html
https://azur3dprints...8-couleur-rouge
Posted 05 May 2024 - 06:01 PM
I finally got around to assembling the hardware and collecting a few test spectra last weekend. Christian Buil's pages at astrosurf.com as well as his YouTube videos were extremely helpful.
Posted 12 July 2024 - 08:29 PM
I recorded spectra of the H-alpha and H-beta regions with my Star'Ex last weekend - scattered sunlight on a heavy overcast day. Next up: Integrate the spectrometer with my RC-6, work out auto-guiding, and record a spectrum of... Vega? I'm thinking that's the lowest degree of difficulty of the available targets.
Posted 24 December 2024 - 05:35 AM
I mean to ask, if any filter put in front of camera sensor, regardless, the ASI can do the plate solve. How about if the filter change to star analyzer grating. Plate solve can still work?
Posted 24 December 2024 - 06:10 AM
Yes I've used plate solving (Astrometry.net) and it happily ignores the spectra, solving on the zero order star images
Posted 24 December 2024 - 06:35 AM
I see, another silly question. Does ASIAIR have this capability (Astrometry.net) in its plate solving tab?
Posted 24 December 2024 - 07:32 AM
While I don't use an Asiair, it should.
Plate-solving is just point pattern matching. Any solver works according to the same principle.
Point sources are extracted. You can use astrometry.net by simply supplying a list of x-y coordinates, plate scale and dimension.
If the focal length, pixel size, and approximate coordinates are provided, you can plate-solve extremely quickly.
If no coordinates are provided ("blind solving"), the same applies, but the search is more computationally intensive.
If focal length and pixel size aren't provided, again, a bit more computing solves the issue.
I've never had any issue plate-solving full star-analyzer fields. To our eyes they may look very messy, but the point sources are there.
Even in Pixinsight, the most capricious solver there ever was
(FWIW, while one often hears complaints about Pixinsight plate solver, they essentially boil down to two causes 1) by default Pixinsight "trusts" the header provided coordinates and performs a near solve: this fails if the header coordinates/pixel scale aren't close enough 2) plate-solving heavily processed images with either saturated or heavily "reduced" stars prevents the software from finding what it considers point sources).
![]() Cloudy Nights LLC Cloudy Nights Sponsor: Astronomics |
