That's a really useful set of test files - thanks for making the effort!
Unfortunately it confirms beyond doubt that in-camera processing is producing rings in the raw data. As before, I've debayered and binned the data (to reduce noise), then divided the (bias-subtracted) red channel by the (bias-subtracted) green channel. Here is the result after stretching:
You can see a very clear progression of sharply defined concentric rings. Doing the same with the blue channel instead of the red channel gives the following:
Something might be going on in the blue channel but I'm not sure what.
You've already said that you don't notice the rings and mottle at higher ISOs, so that's probably the best workaround. Certainly with my EOS R there are no rings at ISO 1600 and above in a stacked image.
We now know for certain that both the EOS R/Ra and EOS R8 produce rings at low ISO. There is therefore a possibility that all Canon mirrorless cameras are similarly affected.
Mark
Thank you for doing this, actually I see it on ISO 3200 too, maybe less but its visible, only time I didn't notice them was when I manually dither and ISO 3200, I tried adding flats but they didn't help much, there is a difference though. Yesterday I tried dithering and ISO 800 and they were visible again so I don't know anymore what has biggest impact on them.
Can this be considered as a sensor defect and is it possible that only some units are affected? I dont think warranty helps in this case because they will probably say nothing is wrong, I mean its visible only after a lot of stretching, I doubt they will see it as a reason for repair/replacement.
EOS R8 and R6 mk2 are using the same sensor but I didn't see anyone mentioning this problem, would be nice if we can get some r6 raw photos to test.
From your experience what is the best way to combat those rings if its even possible?
Here is ISO 3200 photo, if you boost saturation you can recognize ring pattern.
ISO 3200, 20 sec, no dithering. Link to RAW photos on google drive is few posts above.
