My personal experience with these eyepieces.
This last 2 mights have been perfect, the clear sky chart for Conneaut was the best its been in months
Thursday and Friday
So....Thursday I set up the 80mm williams optics f6.9 and the Meade 102mm f8, both refractors, side by side.
Grabbed the ATs and a 20mm Meade UWA to fill the gapf5 between the 28mm and the 16mm
Started with the 28mm , I saw very little difference in performance in either scope. Very sharp, inky black sky, nice sharp stars, it's definitely a keeper.
The 16mm , a few have said its the weak link in these eyepieces, I don't see that. I love the 16mm jet black sky sharp stars all the way across. I spent a lot of my time with this eyepiece, mesmerized by the view.
The 13mm, also extremely good, more magnification, so you loose a bit of that wide open spaces feel, but thats normal nothing wrong with the eyepiece
The 10mm, also extremely good, showed m92 perfectly, only mag. .That started to show granulation in the cluster.
Very good moderate high power eyepiece.
Friday night is even better than Thursday night,
all the above still applies, using a 120mm f5 refractor.
I viewed M13, M92 in Hercules, M56 and M57 both in Lyra, M27 in vulpecula, M71 was behind the tree.and last but not least, M29 in Cygnus.
All were gorgeous in all the eyepieces.
This night I was switching between the 20mm and the 16mm most of the time.
So if your having any doubts about these eyepieces I hope this alleviates some of those worry.
Only down side is the gaps in mag. Nothing between the 28mm and the 16mm, or between the 7mm which is actually 8mm and 4mm.
Also, they 1.25 inch eyepieces need infocus,, my refractors used above, have enough, but just , use of a Barlow isn't possible., unless you switch to a 1.25 diagonal. Which I chose not to do.
Edited by droid, 15 September 2023 - 10:28 PM.
