I always thought the ES 82s were the same as the old Meade 5000 82s. However the focal lengths are very different.
Starman how do you rate the ES 82s in comparison to the UWA/PWA EPs?
JOC, the owner/manufacturer of Explore Scientific, was the maker of Meade Series 5000 eyepieces until 2012..
In 2011, Meade and Celestron left JOC because ES was competing directly.
Meade went to KUO and the focal lengths changed on the S5000 UWAs.
Focal lengths prior to 2012:
4.7, 6.7, 8.8, 14, 18, 24, 30
which were identical to the ES.
After that, the focal lengths changed, with a 20mm the longest and 5.5mm the shortest.
Those were discontinued a while ago and the Meade S5000 PWAs are their current 82° eyepieces, in 28, 16, 7, and 4mm.
Meade doesn't sell the 13mm or 10mm focal lengths in the series, as Astrotech and other companies do.
I have not directly compared the KUO 82s to the JOC 82s--too many years in between them.
But Ernest Maratovich has:
https://astro-talks....2&t=1483#p41976
He tested the ES as ES 82s and tested the PWAs in William Optics UWAN labels.
As you can see, the JOC 24mm and the KUO 16mm get "Poor Image Quality" marks (blue highlight), and the JOC 18, 8.8, and 4.7 get "Excellent Image Quality" yellow highlighting.
Judging from the figures, it seems the ES are generally better, as they should be, given the prices.
On axis sharpness, which seems to be what most people ask about, is virtually identical for all the 82° from both makers.
Ernest doesn't seem to have tested the Barsta 82° eyepieces (See Astromania), but they might be the same as Celestron Luminos, but in a smaller format.
They, too, are available from several companies. Here is one example:
https://astromaniaop...ariantsId=10078
Ernest did test the Luminos eyepieces.
Edited by Starman1, 28 April 2024 - 11:45 AM.
