My few questions are: Which flattener do you recommend? Do any of you use the SFFX-2 and swap for the SFFR-.72 for a wider FOV? I believe I read that Stellarvue will be manufacturing their own reducers and flatteners soon, and idea when? Is a 2600mm pro and adequate camera for this scope or would I benefit more from a full frame? I tend to image mostly nebula and an occasional galaxy. BTW, do any of you have an idea of the image circle provided by this scope? I am considering a ZWO duo camera in the future, but I'll need larger filters, so it will be a while until I get that far along.
Any other things you think I should be aware of?
A couple of thoughts...
I have the SVA130EDT scope and ASI2600MC camera, and use them without a reducer / flattener. Yeah, the stars aren't perfect in the corners, but with my overloaded AVX mount and not so great Seeing in general, the damage is fairly minimal. You might consider doing that first, then get the reducer / flattener later as funds allow. It's not absolutely required.
That said, my longer term plan is to get the reducer, if only to have a bit larger field of view for shooting nebulae. They tend to be larger than galaxies, and at 910mm focal length the field of view is pretty tight. I can just get the full Moon in; M31 doesn't fit. The California Nebula runs from about Redding to a little past Fresno. And going from f/7 to f/5 can only help the imaging speed. The down-side is that the extra weight would push my mount past its rated limits, so it will have to wait for a ground-up rebuild of the system. I presume I'd go with the reducer / flattener made by Stellarview, to be sure of its compatibility and quality.
