All,
I have a Losmandy G11 Gemini 1, Level 3 that I received from an auction. I had to do a few maintenance items and it is up and running and the gotos seem to be pretty good. I have tried autoguiding with some success (see attached dumbbell nebula), but I had to throw out quite a few subs. My main problem seems to be that the mount is not able to guide in dec with my autoguider. I use the Lacerta MGEN 3, which, as far as I know, uses the typical ST4 commands for guiding. The MGEN3 has worked well on a Celestron AVX. The MGEN3 is able to set up and run on RA only for guiding, but can't seem to get the Dec to run. The odd thing is that I have a hand controller that can plug into the autoguider slot and it seems to run the Dec there too.
Has anyone else had this issue?
Chris
