I have recently been unable to obtain a successful PHD2 calibration with my EQM-35 Pro, using the ZWO 30mm f/4 scope (120mm f.l.) and the ASI-120MM-mini camera. Guiding has worked fine until the last several sessions. For some reason it has started failing calibration and giving me the error "Calibration failed. Star did not move enough." And it is not consistently failing, or consistently failing at the same place in the calibration process. Tonight, I spent two hours trying to get a good calibration, to no avail. I use the ASCOM drivers and EQMOD for a direct connection into the mount. I have tried adjusting the EQMOD RA and DEC sliders but nothing seems to help. My hope is that some of those wiser than I in the ways of PHD2 may be able to shed some light on this issue. Thanks in advance!
Here is the latest PHD2 log file. I finally had to give up due to clouds. The resuts shown by PHD2 log viewer are not good.
