How to mount DSLR on equatorial fork mount?
6 replies to this topic
#1 cloudycloudy
cloudycloudy
Posted 19 September 2023 - 12:24 PM
A Celestron motor-driven equatorial mount will be available after deforking the 8" SCT.
Is there a way to mount a DSLR on this equipment for tracking with telephoto lens?
With fork attached?
With fork removed?
The mount is Celestron Powerstar PEC-8. Here is an example shown here:
https://www.cloudyni...owerstar-8-pec/
#2 BlueMoon
BlueMoon
Posted 19 September 2023 - 12:39 PM
Fabricate a shallow U shaped bracket from aluminum or light steel bar to connect between the arms. Add a Vixen or Arca-Swiss saddle to the center of the bracket and a corresponding dovetail or Arca-Swiss plate to the bottom of the camera. Simplicity.
The link will give you some idea of the general shape. You'll need to measure, etc for your application: https://www.amazon.c...a/dp/B07R6N38GY
Clear skies.
Edited by BlueMoon, 19 September 2023 - 12:43 PM.
  • bobzeq25 likes this
#3 Glenn Graham
Glenn Graham
  • Loc: Beaverton, Oregon
Posted 19 September 2023 - 12:44 PM
Did similar for the solar eclipse. Just put an aluminum bar across the forks. I fashoined a pair of wood blocks to match the shape of the scope tube they were replacing and then connected a flat bar across them. I’ve mounted the DSLR directly with telephoto or attached to small refractor. Tracked great throughout totality so I had quite a few exposures to integrate. Still use it for solar viewing/imaging.
Edited by Glenn Graham, 19 September 2023 - 12:48 PM.
  • BlueMoon, Traveler and lee14 like this
#4 lee14
lee14
  • Loc: CNY
Posted 19 September 2023 - 01:47 PM
Nice solar work!
Lee
  • Glenn Graham likes this
#5 Traveler
Traveler
  • Loc: The Netherlands
Posted 19 September 2023 - 11:18 PM
Made something like that with an ETX mount after deforking the ETX telescope.
And yes, beautiful solar pics !
#6 cloudycloudy
cloudycloudy
Posted 22 September 2023 - 02:19 PM
Nice eclipse photos!  Can you share the setup and technique to get the corona picture?
Thanks for suggestions... fabricating a bracket seems to be the way to go. Is it possible to do without any special tools and limited expertise?
#7 BruceJ
BruceJ
  • Loc: Virginia
Posted 24 September 2023 - 11:02 AM
My older 8" Meade SCT has a camera/lens mount on top. I just screw the camera/lens there and let it ride on the scope. Weight doesn't seem to be an issue, at least with the 70-200 or so. A 500mm f/4 might be an issue....
