Best way to keep a RJ12 connector securly in place?
Equipment Celestron Mount
4 replies to this topic
#1 CeeKay
CeeKay
  • Loc: Vancouver, WA
Posted 19 September 2023 - 07:11 PM
I was looking at my CGEM II the other night, trying to work out some cable management issues and wondering if there was something that can be used to keep the RJ12 plug for the Nexstar+ controller in place and prevent accidental unplugging or damage to the connector?  Any suggestions or possible solutions?
BTW - nothing wrong with the mount or controller, just thinking aloud about this.
Chris (aka: CeeKay)
#2 NearVision
NearVision
  • Loc: SE Wisconsin
Posted 19 September 2023 - 07:52 PM
The rj12 plug has a tab that locks it in place. Normally that should keep it in place unless you really pull on the cable and break it. I know they make network cables that have boots to protect the tab from being unlocked accidentally. I've seen these boots available but they need to be put on the cable before the connector is crimped on. You might find a ready made cable but you would need to make sure the wires go to the right pins on both ends.
Edited by NearVision, 19 September 2023 - 07:52 PM.
  • Jim Waters, peepingearthling and CeeKay like this
#3 macdonjh
macdonjh
Posted 20 September 2023 - 08:09 PM
+1 don't break the tab.  In addition, I use zip ties to secure any cables I have with RJ connectors, with a little slack at the end, to keep tugging forces off the connectors.  Kind of a DIY strain relief.
  • psandelle likes this
#4 KLWalsh
KLWalsh
  • Loc: North Georgia, USA
Posted 20 September 2023 - 09:30 PM
Yeah, the zip tie is a good idea.
They make reusable zip ties, with a tab you press when you want to undo the zip tie. They work well, and then you don’t need to have a pair of wire cutters to cut the zip tie when you need to indo it.
#5 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 21 September 2023 - 04:19 AM
Locking RJ12 plugs.
Pro: they don't fall out at the wrong time.
Con: If the mount slews too far it can rip off the cable, or pull the socket out of the mount.
Also tagged with one or more of these keywords: Equipment, Celestron, Mount
