My best Jupiter yet
17 replies to this topic
#1 mayhem13
mayhem13
  • Loc: New Jersey
Posted 22 September 2023 - 04:54 PM
Night before last from NJ. C9.25 20% of 31k frames 180 seconds. 2x Barlow, ADC, ASI224mc w UV filter. Stacked with AS, processed with Registaxx and PS. Wish I still had the 14” that night.
#2 CharLakeAstro
CharLakeAstro
  • Loc: Eastern ON
Posted 22 September 2023 - 05:41 PM
Not too bad....                              ...Who am I kidding?!!
  • Thomas Marshall and mayhem13 like this
#3 t-ara-fan
t-ara-fan
  • Loc: 50° 13' N
Posted 22 September 2023 - 06:22 PM
That is really nice. With the C9.25"?
Would you be so kind as to post one good frame from the raw video?
I want to compare your before and after.  And see how mine stands up against it.
  • mayhem13 likes this
#4 mayhem13
mayhem13
  • Loc: New Jersey
Posted 22 September 2023 - 07:42 PM
Thank you!…I’ve been working at this for 3 years just waiting for a night of perfect seeing.
  • RedLionNJ and CharLakeAstro like this
#5 mayhem13
mayhem13
  • Loc: New Jersey
Posted 22 September 2023 - 07:46 PM
Sure thing…..give me a bit.
I was at this that evening for 2 hours….video after video like always waiting on the seeing….and then it happened…..Jupiter didn’t move about the frame…..it just stayed still like I’ve never experienced before so I started another capture……the last 60 seconds they seeing went bad again. I processed 20, 35 and 50% but 20% was the best of the bunch. Went back at it and did 10 and 15 percent but there was no improvement…..only more noise than at 20.
  • RedLionNJ, t-ara-fan and Tulloch like this
#6 miketz
miketz
  • Loc: UK / Greece
Posted 22 September 2023 - 09:12 PM
This is probably the best Jupiter I have seen from a C9.25. It s definitely the seeing but also your scope seems sharp. Havent had good seeing so far with my C9.25 but you definitely set the benchmark!
#7 Ittaku
Ittaku
  • Loc: Melbourne, Australia
Posted 22 September 2023 - 09:30 PM
Super image. Great work!
#8 RedLionNJ
RedLionNJ
  • Loc: Red Lion, NJ, USA
Posted 23 September 2023 - 08:29 AM
I cannot emphasize enough how pleased I was to see your remarks along the lines of "best seeing in 3 years" and "waiting two hours for seeing", etc.  That's exactly the NJ imaging experience I've been relating to everyone for many years now. You can't just go out on a random night, set up and expect great results. You need to have everything in place (including experience) and wait. And wait. And try frequently. And wait some more. And even more.  And eventually, you get those few minutes you've been waiting for and you realize your scope isn't a lemon, you did learn a lot along the way and you wish you'd captured even more data when the seeing was very good.
Well done and congratulations!
  • Mike Spooner, Ittaku and mayhem13 like this
#9 mayhem13
mayhem13
  • Loc: New Jersey
Posted 23 September 2023 - 09:46 AM
Something to add that i did very differently that night.....i bumped the gain to 350 and lowered the frame rate 1.85ms frame rate to get a histogram average around 60. This took my frame rate to 210 avg fps....faster than i have ever imaged before. I'm going to repeat that next session if possible.....clearly that won't work on Saturn though
I wonder if the really fast frame rate had something to do with it?
  • RedLionNJ likes this
#10 RedLionNJ
RedLionNJ
Posted 23 September 2023 - 04:52 PM
Very possibly. I know Don (dcaponeii) sometimes finds a faster frame rate can (on occasion) help with "beating the seeing" - I think it all depends what TYPE of so-so seeing we're encountering, what frequency, nature, etc.
#11 Ittaku
Ittaku
Posted 24 September 2023 - 01:27 AM
I would say there's no need to even talk about NJ here. The same applies for almost everywhere in the world outside the tropics. Experiencing quality seeing comes out of enduring quantity seeing.
#12 mayhem13
mayhem13
  • Loc: New Jersey
Posted 24 September 2023 - 04:02 AM
You ain’t kidding!……three years certainly qualifies for quantity!
I think the other factor that made this possible from a 9.25 is that Jupiter was up around 60 degrees…..that hasn’t happened in the 3 years I’ve been at this either. All of my Saturn pix are pretty much garbage…..Saturn hasn’t been above 37 degrees for the past three years here.
  • RedLionNJ and Ittaku like this
#13 Silent_Light
Silent_Light
  • Loc: West Of Denver Colorado
Posted 24 September 2023 - 04:04 AM
Absolutely stunning image!!
Well worth the wait and time !!
#14 Ittaku
Ittaku
Posted 24 September 2023 - 04:08 AM
Yep Jupiter is 37 for us this year. Saturn is slowly leaving our skies but still 65 degrees which is why I'm spending so much time on it this year.
#15 RedLionNJ
RedLionNJ
Posted 24 September 2023 - 08:01 AM
While perfectly true, Con, I was emphasizing that Mayhem13 and I are only a few miles apart, geographically (and in my opinion, NJ does have worse average seeing than a lot of the world, too).
Or maybe I'm just not as dedicated as you, or, as already pointed out, elevation has a lot to do with it as well. It's our time! :)
  • CharLakeAstro and Ittaku like this
#16 Konstantin 1980
Konstantin 1980
Posted 24 September 2023 - 08:13 AM
The image shows that the point details are deformed, this may be a problem with the quality of the optics; in a bad atmosphere such blurring does not occur (it will be uniform), with the exception of strong jet streams.  I have the same region, a few days earlier at 250 mm Newton, it is clear that most of the small structures in your photo are highly distorted (elongated in some direction). Of course, it could also be due to improper processing.
I see that you have a distortion along the equator, and a little less - perpendicular to the equator. This is very similar to severe astigmatism. You just need to understand what caused it.
Edited by Konstantin 1980, 24 September 2023 - 08:17 AM.
#17 Konstantin 1980
Konstantin 1980
Posted 24 September 2023 - 08:33 AM
try to photograph double stars, I think that the normal diffraction pattern will not be visible there. My telescope draws it perfectly, here is a photo as an example 01_36_06  g.png
#18 mayhem13
mayhem13
  • Loc: New Jersey
Posted 24 September 2023 - 08:46 AM
Thanks. Yes…..I didn’t use Winjupos for derotation as I wasn’t able to do any more captures….the seeing fell apart. This likely accounts for the equatorial distortions you mention…….Jupiters jet streams and currents move at unpredictable speeds so there’s really no consistency to be had I think. Very nice image! It was a coin toss for me between using the C9 or my 250 f4 newt too…….the C9 won as I did some observing early which I can’t do with the newt mounted equatorially.
