Skywatcher AZ-GTi Glitch (?)
3 replies to this topic
#1 NSP
NSP
Posted 24 September 2023 - 05:41 PM
I recent purchased a Skywatcher AZ-GTi mount to use with my smaller telescopes. So far, I’ve been impressed with the mount’s accuracy, but I noticed a glitch where the mount “crashes” when it pans to the west. In short, when I ask the mount to pan to an object in the west, the mount turns most of the way, but then it stops moving, the red Wi-Fi light quits blinking, and the SynScan app displays a loading circle.
I noticed that it doesn’t seem to do this if the azimuth clutch knob is loosened. In fact, if I loosen the knob after it crashes, the red Wi-Fi light starts blinking again, though it messes up my alignment.
Is this a known issue? I’m inclined to return it and try my luck with another one, but I wanted to solicit opinions to see if anyone else has encountered this issue. Thanks!
#2 duganheimer
duganheimer
  • Loc: Missouri
Posted 24 September 2023 - 06:26 PM
I ran into an issue like that when i operated the mount from my raspberry with stellarmate.  Turned out I was slewing at a rate that was faster than the rate on the synscan app.  When I slowed to the same as the synscan app, problem went away.  Don't know if you are using outboard software to operate it.  hope this helps.
#3 NSP
NSP
Posted 25 September 2023 - 08:12 PM
#4 NSP
NSP
Posted 25 September 2023 - 08:13 PM
Oops, prematurely clicked reply. Right now I’m only working with the SynScan app and the mount, so fortunately I can eliminate other technology as being the source of my issue. Thank you for the reply, though!
