Nice night again in Overgaard. Finding I really get MUCH better results when I re-stack and process the subs myself. A few FYI's here. There is a new release of the app that also updates your firmware. One feature of the new firmware you will see when you mount your Seestar on your PC, they now have a folder that contains the master dark .fit file they are using so you now do have a dark you can use. I assume this dark changes every time you image as it is probably made when the Seestar initially goes off and says it is refining your image. Another thing I have found and I will demonstrate below is I see lots of longer exposed images other users are posting, more on FB than here, that have a wide, large diagonal bright band going across the final image. I have see these in a few of my longer exposed images and one I am posting in this post. This is NOT stray light. This is caused by the fact that the Seestar does NOT derotate the images. I thought that it actually did but obviously it does not. I have posted a screenshot from PI when I post processed some other images. This is a screenshot of the low rejection images PI makes when it stacks things. You can see the crazy alignment some of the subs have. If you restack your own images, you should not have any of these bands. In the future I will not image anything over 15' real Seestar time. The rotation becomes too much of an issue past that. 15' might even be too long but I will see. If I want a long exposure then I will just do multiple 15' sessions.
Here is SH2-162 the bubble nebula
Here is NGC7380 the Wizard Nebula. Posted after this is the Seestar version. If you open the picture up you should see one of those bright bands going diagonally across this image. On my reprocessed image I had to crop about 1/4 to 1/3 of the image off the top because the misalignment made the top of the picture quite bad. But....crop is a wonderful tool!
My reprocessed image
The Seestar processed image
The PI Screenshot showing the gross misalignment of some subs.
A nice shot of the open cluster M52
Edited by rimcrazy, 05 November 2023 - 06:28 PM.
