Turning off the Wi-Fi seemed to solve the problem of the hand controller disconnecting from its alignment. And the other problem of the Wi-Fi sky portal connection turning off and powering off the alignment; this again seems to be an early evening problem in my suburban neighborhood. I suspect the problem is neighboring Wi-Fi is being used which interfere with the Wi-Fi sky portal connection. Are there ways to shelter segregate the Wi-Fi sky portal connection on the telescope from local Wi-Fi interference?
WiFi interference was my first thought. I was out Saturday night and my SkyPortal app could not find my telescope sitting right next to me even though my laptop could communicate using CPWI. Even though I was out in the country there were other WiFi signals broadcasting. I retried it at home, and it is fine. The Evolution WiFi is only good for distances measured in a few feet. I assume interference was the likely culprit. I am not sure why the laptop could identify the signal but the iPhone could not. I assume the laptop just has better WiFi hardware. I did not try resetting anything since I could communicate via laptop. The lesson: don't count on any single technology unless frustration is your thing. Even though I have StarSense I still have my alignment scope attached. I've had computers, electronics, and software misbehave too many times.
