At 42 degrees Latitude I often split Sirius A/B depending on the aperture and conditions. I prefer lower powers from 80x-120x so that B shows up as a perfect sharp point rather than a dot.
Even with a good quality 100mm refractor it can be a challenge most nights.
I've had much better results with a 130mm during good seeing and transparency. It will pop in and out of view with many false sightings in between due to the scintillation of A.
My 160 has been the most consistent refractor at delivering a solid confirmation of seeing the B component.
With a C14 SCT, it's easy when seeing is decent, and is still bright enough that it's very visible with a binoviewer.
Here is a photo from the 14" using a Canon 60Da set at ISO800 and a 1" exposure. B was also visible on the Liveview screen while I was trying to achieve focus.
See photo.
