Thanks to Bomber Bob I now have one of these. Of course it has rained since it arrived. Finally had a brief bit of sun today, so I tried it with the Pentax 85, using its 0.965 tailpiece, partly because it's always ready to grab and go, and partly because I don't have a solar filter for it. I went through the collection of eyepiece sun filters that I've removed from the loaner scopes and found a very nice one from an AO Mayflower, stamped JAPAN SUN, to use in place of an OD3/ND3 filter.
Sadly, the Pentax's long focuser did its usual trick of refusing to bring anything to focus that isn't going through a Pentax diagonal. The Pentax diagonals all have 38mm barrels, so they go all the way into the focuser. The 0.965 tailpiece and the nose of the wedge lengthened the optical path by about 1/4" too much. I did get to see that even with the full 85mm aperture, the image is still not very bright. It gives a slightly greenish orange color. Then the clouds started to roll in again.
I'll have to pull out a different classic to make this work.
Chip W.
