As you could see, there is a lot of various chinese achromatic lenses on eBay these last few years. I decided to buy one of these and play around with it. Since I have my own lathe at home bought especially for ATM only, I play with it all the time and make telescopes! It is a real and great fun! I bought a 90/600mm achromat from seller named lens-store. Lens came last week and I would like to share my experience with you guys.
These sellers or the workshops from where they get that stuff are really playing trying to be opticians by designing really weird optical designs. This particular lens is made from K9 crown and F2 flint, but instead to make the standard Fraunhofer aplanatic lenses which you can normally find in every Synta achromat, this one has a lot of off axis coma when tilted, because it is not designed aplanatic, obviously not like the standard achromat which shows off axis astigmatism only, since standard Fraunhofers are aplanats by design. On the other hand, it came with a thin metal spacer .5mm thick and in that configuration this lens was overcorrected spherically. Then I machined a 2.5mm thick plastic spacer ring and the lens achieved good spherical correction in green light. This is very weird, it was as these glass elements were not designed properly at all! After I increased the lens spacing to reduce overcorrected spherical aberration, it also changed the color correction also and instead of slight blue halo around stars in focus, now I have more purple halo since the blue color now shifts more towards green and the red moves more away from these two. It is now chromatically undercorrected. Now I consider to aspherize the inner crown surface which also has no coating at all! By deepening the center it should correct the overcorrected spherical aberration in the position of the minimal lens spacing, and therefore regaining more optimal color correction. With minimal spacing the color correction is somewhat between C-e and standard C-F correction which gives nicely dark violet chromatic aberration, and when optimally separated for SA correction, it is somewhat in e-F color correction which gives ugly red/purple haze around bright objects, since the red color is much far out from the common blue/green focus. That chromatic undercorrection is more common to Zeiss C80/500 lenses from Asembi binoculars that needed around 130mm glass path of prisms to balance the secondary spectrum properly.
These eBay lenses are therefore very risky to buy, and I do not recommend them for those who are not enough skilled ATM-ers.
Here are some pictures of the collimatable machined aluminum lens cell and the finished OTA. Enjoy!
Edited by Stipe Vladova, 20 November 2023 - 03:23 PM.
