I've been wrestling with something for over a year and finally realized how to articulate it. I need to find the right telescope to support my binoculars.
It's an ironic problem to have because the common scenario is the reverse -- a binocular used as a finding aid to support telescopes. We are occasionally reminded of this by helpful telescope aficionados. Binocular enthusiasts may ask, do we really need telescopes? Why? Well, certainly not as a finding aid, given how much easier navigation is with binoculars. But telescopes do have possible edge case uses.
Here I was last night with the Oberwerk 100XL-SD and my trusty friend of decades, the TV-101, enjoying its first ride on my iOptron Tri-pier.
I was comparing views of 6 Trianguli between the 100XL configured with the left OTA at 112x and the right at 40x as a finder considering a question posed by binofrac about using one side of a BT for higher magnification views (thus removing the difficulty of attempting to align dual tiny exit pupils).
STF 227 / 6 Trianguli
02h12m +30*18'
5.162/6.613 sep 3.88" pa 67.2*
I was able to resolve the double with both the 100XL and the TV-101, though the view with the latter was slightly cleaner and more refined (as expected). While using a BT in dual mode like this for double stars is workable it's not ideal for a reason that might be overlooked without doing actual side by side comparisons. Using the helical focusers on BTs at high magnification is a pain in the kizitz, and even more so in cold weather when the darn things stiffen up. Swapping eyepieces and focusing with a telescope on the other hand is simplicity itself.
So this is my personal use case. Is it possible to resolve closer (under 4-second) double stars with binocular telescopes? Certainly. But it is difficult to manage by mere mortals (particularly the bespectacled) who do not possess high magnification BT super powers (ahem), and more easily accomplished with a telescope. There. I said it. And yes, I know other use-cases exist, like chasing down fuzzy bits of galactic lint with larger aperture telescopes, but that's not on the celestial menu for urban astronomy.
What telescope to choose?
I added an Orion CC8 Classical Cassegrain last year, thinking it would be an ideal option for double stars beyond the relaxed BT range, not to mention the occasional planetary nebula and etc. But I have rarely used it. Why? It's a lot of work to set it up. It's much easier to plonk the TV-101 on the iOptron Bino-Bracket (a recent happy discovery), and I'm not going to lie, that configuration is a lot of fun, but still nowhere near as easy as setting up a BT or p-gram (a minute or two for either). I've decided to try a StellarVue M002C head on the 161MK2B mount as a quicker setup option for the TV-101, but that will involve manual finding and tracking so we'll see.
This morning I thought of an ideal quick set-up, easy-to-use option for double-star peeks -- a Celestron NexStar 6SE. It's light, can be set up in a few minutes, and has goto for easy finding and tracking at high magnification. Plus thrifty -- sort of the telescope equivalent of a value-priced binocular, which has a certain cachet to it.
So how about it binocular enthusiasts? What is your ideal support telescope? Or do you need one?
Edited by Fiske, 24 November 2023 - 07:47 AM.
