Tonight the forecast was for clear skies but the reality turned out to be clear with long intervals of cloud cover moving through. I'd set up my 4 inch refractor to image the galaxy NGC 3718 in UMa. While that was going on I decided that the visual part of the evening would be pairing my Oberwerk 12x60 LW binoculars with my SVBONY SV48P achromat refractor (90mm f/5.5). I put the latter on a Monfrotto 161 MK2B tripod with Oberwerk 280mm fork head.
After twilight I spent an hour on the moon, especially the Alpine Valley area and the Mons Hadley area which both had a favorable solar angle. My best views were using a 3mm eyepiece for 165x. I tried using a 2.5x barlow with a 6.5 mm eyepiece for 190x and the view was acceptable. Trying to achieve more magnification combining this barlow with a 4mm eyepiece for 310x did not produce a sharp image and I considered the result to basically be empty magnification. Seeing conditions happened to be sub-arcsecond tonight according to FWHM values coming off of my imaging run.
Although the lunar views were nice, the achromat doesn't have enough aperture to show the rille in the floor of the Alpine valley and I didn't get much of a view of Hadley rille. That level of lunar detail would probably require at least an 8 inch scope. But the achromat did do a good job of giving me a detailed view of lunar features that were pretty minute in my 12x60 binoculars. There was some obvious chromatic aberration along the lunar limb, but I didn't find it objectionable.
After finishing with the moon I studied the globular M4 in the binoculars from a zero gravity chair and then viewed it in the achromat with and without night vision. I'm in Bortle 6. My southern horizon has the worst light dome pollution and M4 was barely perceptible in the binoculars. It was a bit more definite in the achromat, but the stars didn't resolve until I switched to a PVS-14 equipped eyepiece.
Then I moved to Albireo and easily split the double into blue and gold components.... quite close together at 12x.... and with a tendency to jiggle with hand holding. The view was much steadier and definitive in the achromat. I couldn't see M57, the Ring Nebula, at 12x with the binoculars but it was obvious in the achromat at 43x with a 14mm eyepiece. I thought I could just barely detect M56 with the binoculars and confirmed its position with the achromat staying with the 14mm eyepiece.
I got tired of dodging cloud banks and the mosquitoes were getting thicker towards 11:30 pm. I know I lost a large number of sub-exposures of NGC 3718 to clouds, but I also know I got at least a modest number of cloud free shots with good transparency and excellent seeing. I'm glad I set up both rigs because I rarely see sub-arcsecond seeing. It is too bad that the sky was intermittently covered with clouds, but that's life in New England.
Rick
