Solo Telescope Session
And me a binocular man
... This was one for the books. First ever astronomy session for me with only a support telescope. It took place in an urban area, in an unlit parking lot, away from home, from 4 to 5am MST. My targets were NGC 6818, M84, M86, Epsilon Lyra Double Double, M11 (Wild Duck Cluster) and NGC 7009. The conditions were clear, except for some hazy clouds hovering over the SW horizon. The moon was waning at 95%, and my SQM brought down an average reading from zenith of 17.9. So not the best conditions, but it was what it was for this urban location, and a good test for my Astrotech 125 EDL with 20mm and 7mm XW eyepieces.
NGC 6818
Faint, star-like and a little fuzzy, NCG 6818 appeared first with averted vision, then directly in my FOV. Eighth magnitude HD 186107 appears about a half degree to the WSW of this planetary nebula.
NGC 6705
Also known as M11 or the Wild Duck Cluster, this open cluster was brightly visible in these urban skies, also within the glow of the waning 95% moon. Two nearby stars frame and form a triangle with M11 - ninth magnitude SAO 142703 to the SE, and 8th magnitude HD 174281 to the SW.
STF 2382 AB, CD (Epsilon Lyra)
First I viewed the double double at 49x, then switched to a 7mm eyepiece for a power of 139x. This clearly brought into view each separate star with a line separating the double in each pair. Epsilon1 Lyra appeared in the upper left of my FOV, and showed a clear separation (2.15") line for the AB stars. Epsilon2 Lyra appeared in the lower right of my FOV, and showed a clear separation (2.34") line for the CD stars.
NGC 7009
This planetary nebula is also known as Caldwell 55, and the Saturn nebula. I could not see its ears tonight. It appeared as a relatively bright, somewhat soft edged, star-like object among other stars in the FOV. The most notable adjacent star was 7th magnitude HD 200157 about a degree to the SW.
M84/M86
Not even in my imagination could I make these two galaxies pop tonight, under the conditions of the newly waning moon being in the same quadrant of the sky. I'll get back to these two next week when I am back home, from my own suburban back yard.
The Astrotech performed very well, was easy to deploy, and had the deep penetration and longer focal for the tight doubles.
