Autoguiding My GCO 16" Ritchey-Chretien
6 replies to this topic
#1 Aucello
Aucello
Posted 29 November 2023 - 10:30 PM
I put a 16" (f8) RC into my backyard observatory that was originally designed for a Meade 10" SCT. Needless to say, the RC barely fit within the dimensions of the building. My biggest concern, however, was that the open dome shutters only provided a width of 24". Not only would I have to frequently rotate the dome during an imaging session, but the placement of the piggyback guide scope would frequently need to be moved as the RC position rotated - otherwise, the guide scope FOV would eventually be obstructed by the dome, as it approaches the edge of the 24" viewing window.
I tried off-axis guiding, but that proved to be inconsistent and unreliable in being able to capture adequate guide stars while operating at such a long focal length. I came up with a novel solution that seems to work very well. It struck me that a nice place for a guide scope would be at the very front of the telescope and within the area occupied by the secondary mirror cell.
My first challenge was that I didn't want to attach anything directly to the mirror cell, or the spider, given the delicate nature of maintaining RC optics collimation. I also didn't have room between the front of the RC and the observatory wall for much of a guide scope. So, I found a little 30mm mini guide scope at Orion and purchased it. I mounted it on a platform that attaches to the front of my telescope – it sits in front of my secondary mirror holder so it doesn’t obstruct the primary mirror (see photo). The horizontal plate lies in the plane of my spider vane, so it too doesn’t add any obstruction. The question was – can thus little cigar-sized scope adequately autoguide my 16 inch Ritchey-Chretien telescope? The answer appears to be yes, as testing has proved it to work very well.
Rick
  • D_talley, AndreyYa, lambermo and 2 others like this
#2 DuncanM
DuncanM
  • Loc: Arizona Sky Village (Bortle 1) or the rain forest
Posted 29 November 2023 - 11:33 PM
Rick
If that works go for it!
I suspect that an OAG with a 12x12mm guider prism (Example: ASI OAG-L) and an autoguide camera with a very large and sensitive sensor would work best of all. I'd suggest an ASI 174mm as a minimum and something like the ASI533MM as ideal. Bin it as much as possible for maximum sensitivity.
#3 rgsalinger
rgsalinger
  • Loc: Carlsbad Ca
Posted 30 November 2023 - 12:29 AM
It would be interesting to me to know why you can't autoguide with an OAG.
I use a 25" F8 RC with a large prism (Monster MOAG) OAG and a QHY174 guide camera and it all works just fine. I also have a trick to share in that you can put a positvive lens (about 50 dollars) into the guiding system which acts as a focal reducer and brightens up the image. We did that in the past where we had this crappy ATIK guide camera. With the advent of the 174 that's what we switched over to about 4 years ago. Not a problem since we set it up.
Rgrds-Ross
#4 arbit
arbit
Posted 30 November 2023 - 02:42 AM
That's an interesting outcome.
Can you share details of your cameras/ focal lengths and PHD2 settings? Plus guid8ng performance?
Just curious about the pixel scale ratio.
Sent from my SM-S908E using Tapatalk
#5 michael8554
michael8554
  • Loc: Wiltshire UK
Posted 30 November 2023 - 05:28 AM
Hi Rick
A clever solution to the problem.
Amazed it works though.
If that's a LodeStar camera, the pixel scale is about 14arcsec/pixel !
#6 stargzr66207
stargzr66207
  • Loc: Kansas, USA
Posted 30 November 2023 - 11:14 AM
Rick
That’s an ingenious solution to the problem. Very good design & craftsmanship. Congrats!
Ron Abbott
#7 BKMaynard
BKMaynard
  • Loc: Maryville, Il. (st.louis area)
Posted 30 November 2023 - 11:22 AM
You may want to paint it a flat black
