With the current sales, I decided to finally make the leap and upgrade my gear. I've been using an HEQ-5, asiAIR pro, and z6ii. Currently (pun intended), I'm able to run everything from a RAV power 250wh power cube (It looks like they've discontinued this). This has a DC out rated at 12v 10a. I use that to run the HEQ-5, then the PD out that is rated for 12v 3a with a PD to DC converter cable to run the asiAIR pro.
I've upgraded to an AM3 mount and 2600mm pro and plan to keep using the ASIpro (unless there is a compelling power splitting reason to upgraded to the PLUS). I have not purchased any power connectors yet for these.
I have three main questions. 1) is there an airline friendly (under 100wh if I understand it) power bank that I can use to power the AM3 when I travel with it and am at places without AC power (one of the selling point for me on this mount). I assume it needs 12v 5a to run but would need a stable supply through the power drainage.
2) My RAV power cube only has on DC out. Is there a was to split that and run everything and still have ample power to each device? I would use the 12v outs on the asiAIR but I've read mixed thoughts about using that for AM3 and for the 2600mm
3) If I'm going to use AC power at home, what's the best solution with the fewest number of cables? Can I power all this off one AC plug somehow?
I don't really understand the electricity side of this, so go easy on me. Thanks in advance for the help.
