Replacement focuser for older SV102ED
#1
Posted 06 December 2023 - 05:37 PM
#2
Posted 06 December 2023 - 05:42 PM
Call and talk to Stellarvue.
- gene 4181 and Astro-Master like this
#3
Posted 06 December 2023 - 07:14 PM
#4
Posted 06 December 2023 - 07:27 PM
You might want to look here: https://www.ebay.com...ar=444600863290
#5
Posted 06 December 2023 - 07:46 PM
so there's a internal thread in the tube and you know what it measures?
generally you could look at a site like TS and virtually piece together the fittings you need to adapt what you have to a new say.......rack and pinion.
What I couldn't say for certain is how this would affect the back focus distance - is your focus point close to the scope or racked out quite a way?
#6
Posted 06 December 2023 - 08:18 PM
Ris242 - the back flange of the OTA has 88.5mm female threads. Looking for a focuser with matching male threads or something close I could use adapters with. Hard to find the specs on most focusers or the use a flange coupling.
#7
Posted 06 December 2023 - 10:45 PM
I would like to add an EAF to my SV102ED but the stock focuser isn’t configured for one. I’ve been looking for a replacement focuser that will fit. So far only found a feather touch but very pricy. Any suggestions or experience with this?
One option:
The 102mm F/7 SV0102ED was essentially identical to the original AT-102ED, same optics, some slight differences. You can buy a new AT-102ED for $584, it has a 2 inch rack and pinion focuser that maybe configured to add the EAF. You could sell the SV-102ED and have a very nice focuser that did not cost a great deal.
Posted 07 December 2023 - 10:14 AM
Thanks Jon. I also have been thinking of just upgrading the scope. I really like the images this scope provides so guess it was a last option for me. I see you use a AT scope. Do you like it?
#9
Posted 10 December 2023 - 04:37 AM
I do like my AT-80LE. It's a unique scope in that it's an 80 mm F/6 FPL-53 doublet. Typically 80 mm F/6s are triplets and 80 mm FPL-53 doublets are F/7 but the 80 mm F/6 provides a very wide field, 5.5° with the 41 mm Panoptic.
