Last November 22nd I attempted some lunar shots.
As usual, the turbulence was present in quantity, III scale of Antoniadi, thanks to the roofs and chimneys of the houses in front.
I took a few shots anyway, and I only edited the video for this one today, avoiding its end in the trash can on my PC.
With surprise I saw that in the shadow generated by the mountains that make up the crest of the Plato crater, a small hook can be glimpsed. Of course it's not real, you can clearly see that a hill slightly higher than the bottom intercepts the sunlight, creating the illusion that there is an opening between the mountains above.
The effect is still nice, even more so because I recorded it randomly. Great luck.
22.11.2023
UT 17:26
Celestron C8 telescope
red filter
ZWO ASI178mm camera
Autostakkert3 processing, AstroSurface
sum of 100 frames out of 3379
Lorenzo
