Outdoor Star Testing
The CFF was mounted, dew shield pushed back off of the objective cell, on my trusty Losmandy G11 (the photos of Paul and the OTA were taken after the testing). We used a 50 micron artificial star placed about 252 feet away, which makes the star size about 10% of the 185's diffraction limit. Small enough but I still used a 2X barlow over the star's 1.25" nosepiece.
It was the same day we tested Paul's AP 110GTX. We star tested the 110GTX after we did the CFF. It was a mostly cloudy day, fairly stable temperature (52 -55 degrees F) but with the higher temperatures during occasional cloud breaks. Ground level Pickering seeing varied from 6 to 8 with 8 during extended cloudy periods. Plenty good.
Scope, had cooled with the dew shield retracted, from an ~66 degree F basement for a little over an hour outside while we were DPAC testing the little AP and then lining the CFF and the star up (which involved at lot of trudging back and forth from the star and scope). Testing itself took about an hour.
I used all the wrong stuff: 2" AP star diagonal, cheaper 6mm ortho but also nice 9 & 7 mm UO orthos, and good quality 2x and 3x barlows. A good combination for high power, 420x, was the 3x barlow and the 9mm UO ortho. So, I violated some star testing "rules" but our objective was to sniff out coma and astigmatism, not spherical & color corrections, which is what the DPAC testing showed me, but.....
Star testing dogma states you need to let the OTA thermally stabilize prior to getting serious. Well, not for me. I start looking right away because a: I'm compulsive and b: I find it fascinating to watch a scope's star image morph and evolve if it is still cooling a little. That educates me. This scope was educational for me. Even though we were primarily looking for coma & astigmatism, I still had a gander at the spherical content, which seemed quite consistent with DPAC once the objective settled out. Early on the scope seemed slightly under corrected, then neutral, then finally, maybe, slightly, overcorrected, both with and without the green filter. Also, in the beginning, I saw signs of mild tube currents, occasionally flattening a portion of the out of focus diffraction rings with a narrow local "bleed" at focus. This went away. Color also went through an evolution. Early, I found, at high power, moderate amounts of red/blue splashing around the airy disk, which was slightly yellow-ish. This too subsided considerably as the objective cooled but there was a small bit of splashing left over, visible above maybe 250X, but the nice round airy disk was quite white.
I saw no coma at all up to 420x, though one could be fooled by a mild tube current. I was not. The only astigmatism I saw was a mild trefoil pattern early at high power that quickly went away.
I found the star test excellent, and again, especially for such a large fast, oil coupled triplet.
Jeff
Edited by Jeff B, 10 December 2023 - 03:05 PM.
