Nice...colors pop a bit more, and the Wall shows up amazingly clear.
Siril did the same thing; it flipped the image the second time I went through the process; not sure why.
Once it was flipped and even when I flipped it back, Siril couldn't plate solve for color calibration (it worked for my first attempt...dunno why it failed the next time). I just tried to set the colors manually and went for the brown/organish look since it brought out a lot more detail. Not sure what this thing actually should look like, but I like your rendition.
I'm going to practice again with Siril and see if I can get to the similar image as yours. Siril was easy enough to work with, especially since it integrated Starnet to remove the stars early in the process and then add them back after curves/levels adjustments. In my last image, I didn't push the stretch on the stars, to keep them more or less the same size as in the original.
Then I'll move on to PI.
I'll watch some you-tubes for the process work-flow.
I think my plan will be to re-process until I get similar results, while it's cloudy/cold, then re-shoot/process the entire data set on the first available night. This was kinda a cobbled up data set.
If there is any other advice or criticisms, I'm open to it.
I think I'm fairly comfortable with polar alignment, guiding and focusing.
My mount guides somewhere around 1-2 arc sec, dunno how good or bad that is, but it is repeatable.
I need to learn more about choosing the right exposure and gain. SharpCap and Nina both have stuff to help with that (more Nina than SharpCap).
I mostly shoot from my bortle 5 back yard, so I'm learning more about 'lucky imaging' and how that can improve image quality.
I shot this with both 20sec/Gain-100 x200 or so and 40sec/Gain-350 x200 or so.
The camera has a 585 sensor, the read noise drops off at 250. I think I'll use 250 gain and 30sec exposures as my next experiment.
Ron
