Can 52 Orion be split cleanly by a 5" apo?
7 replies to this topic
#1 Kim2010
Kim2010
Posted 11 December 2023 - 04:01 AM
So I can easily see a sliver of black, ie split, 52 Orionis with my C8, but now I am using my 5" TS 125mm apo, and I can't seem to get a clean split, but just a peanut shape. Is this expected of a 5" apo vs the C8? I even used a ridiculous 2.3mm EP and no clean split on the 5". I will try again later and see if it was seeing-related.
Also, when you say pinpoint stars, I am seeing pinpoint stars but not on bright stars which show as "balls". Is this normal as well?
#2 hasebergen
hasebergen
  • Loc: Stuttgart, Europe
Posted 11 December 2023 - 04:44 AM
Hi
it should be work easyly.
I´ve splittet 52 Ori with an 110 years old 122mm refractor with 209/292x and also with a also ~110 years old british 125/2000 refractor with 240power.
If it doesnt work, one the one hand: poor seeing or on the other hand: your telescope is defective ...
regards hannes
  • Feidb and Kim2010 like this
#3 Kim2010
Kim2010
Posted 11 December 2023 - 04:58 AM
Hi
regards hannes
I'll try again, so with 195x should I see a clean black space split?
#4 Redbetter
Redbetter
  • Loc: Central Valley, CA
Posted 11 December 2023 - 08:53 AM
Looks like it is a little less than 1" separation at this time, so very much seeing dependent with a 5".   The 8" has considerably better resolution at this level.
My 125 EDL doublet takes considerable time to thermally equilibrate if the outdoor temp is significantly lower than indoors (e.g. 25+ deg F delta.)  It produces some poor images early on and sharpens noticeably as the optic cools.  The 10" Dob with a fan is probably quicker or similar from what I have seen, although the Dob benefits from greater potential resolution, so any time based resolution comparison is skewed.
I wouldn't expect much temp. difference at night in the Philippines, from my limited time there (Cebu and Bohol), but specific circumstances could vary considerably.
  • Kim2010 and flt158 like this
#5 Bill Barlow
Bill Barlow
  • Loc: Overland Park KS
Posted 11 December 2023 - 12:11 PM
I have been able to split this very close double star group with a C6 and C8 when using magnifications of 200-300X.  Collimation has to be about spot on to see a black gap between the two stars.  I can almost split it with my very nice C5 and with the AP 92 Stowaway at similar magnifications.
Bill
#6 Kim2010
Kim2010
Posted 11 December 2023 - 03:48 PM
Aha! It was all seeing-related because tonight, during moments of clarity so to speak, I can clearly see a peanut-shaped object with MAYBE a thinnnnnnnnnnnnnnnn sliver of black or not, but at least the double star nature of the system is obvious due to the clean peanut shape. I used 5mm and a 2x Barlow (390x) with the 5" apo.
Alnitak's close double was also great to see with black space in between at 5mm no Barlow (195x).
  • Sasa and flt158 like this
#7 C. Evangelista
C. Evangelista
  • Loc: Heidelberg/Germany
Posted 11 December 2023 - 06:22 PM
I can easily get a black-line split of Alnitak at 78x as well of 52 Ori at 130x, with my 130 f/6 triplet apo, albeit at Pickering +7.
So, mainly seeing might be an issue in your case...
#8 Kim2010
Kim2010
Posted 12 December 2023 - 02:49 AM
I'll try again tonight!
