I didn´t want to hack the thread "goldline vs redline", since i do not have the goldline eyepieces. So I start a thread on the redline.
I have the 6, 9 and 20mm, and use them on a F4 small newtonian. My sky is light polluted but usually has pretty good seeing and transparency.
Using the redline was difficult for me, because of the "kidney beans" stuff. But i have learned to place my eyes better and to maintain the position. So it is not a problem for me anymore.
From the 3 in my ownership, the 6mm has the best behavior (scope, eyes and sky - center field sharp and contrasted) and the 20mm the worst (show a lot of "astigmatisms" on the outer field because of my fast newton) but offers 3.4º TFoV, which is not that bad (i am not using it anymore, since I have the flatfield 18mm, which is excellent for me). The 9mm is in between the 6mm and 20mm, but i do not use it that much.
I have flocked the inside of the 6mm and 9mm, with remnant of my flocking paper. It is easy to do, since one can unscrew the barrel (with the barlow inside) and also the top cell, which holds the "eye lenses". I find this feature of this eyepiece quite interesting (the TMB planetary clones are also like this). You can see the photos to visualize it better.
Having these eyepieces flocked, I really get a better view (contrast) on bright objects. This was the first point, I wanted to mention about these eyepieces.
The second point is when I use the focal reducer 0,5x with them. I am not really sure it is a true 0,5x, rather in between 0,5 and 0,7.
With the 20mm, results are pretty ugly with my scope. If you want to scare someone, that is the way to go.....
With the 9mm, well not really helpfull.
But with the 6mm, I enjoy a better outer field but the center gets somehow sharper, Jupiter with more pronounced colors and somehow appears bigger and with more features seen. The TFoV is bigger. And it is awesome with my 3x apochromatic barlow, I have seen 4 bands and colours on the poles. The RDS was like a white perturbation (line) in the main band with in its inside a faint pinkish brown circle. The moons more distant were not pinpoints (negative). it was an awesome big view with the Barlow (approx 180x). The best I have experimented so far on Jupiter.
On the moon, I can use it together with the telextender and barlow (optics chain quite long ----> telextendr 2x + barlow 3x + FR 0,5x + 6mm). The results are impressive, really. I still have in my head the view of the alpes mons and vallis, the faint Egede , the Mons between Serenitatis and Imbrium, the black area north Hyginus. Everything was with a more 3D effect (a way to say it) and really well contrasted. I calculate that the magnification was between 200x and 240x, and was really impressed.
My long optic chain does not work on Jupiter.
The order has its importance. First the telecentric, than the "normal" barlow and the focal reducer fixed to the eyepiece (otherwise it won't work)
May be other persons with the 6mm, focal reducer and a F4 scope could tell, if it works good for them??? I would really like to know because my results goes against the odds.
Edited by Olimad, 20 December 2023 - 11:30 AM.
