artik, what are your thoughts on using OpenLiveStacker to create a sort of open source version of the Pegasus Astro SmartEye?
SoHo Enterprise has an IMX585 sensor for the RPi: https://soho-enterpr...rt-sample-sale/
It works with Pi Zero 2W: https://soho-enterpr...or-rpi-zero-2w/
Not sure if Zero 2W has enough power for live stacking?
If not, there is a CM4 expansion board, which should keep the physical size of the “eyepiece” sort of small: https://github.com/harlab/CM4Ext_Nano
CM4 offers 8gb RAM and faster eMMC.
There is a high resolution 2.1 inch 480x480 MIPI touchscreen that can be the digital eyepiece: https://www.buydispl...h-circle-screen
I suppose the end result would be an eyepiece with the dimensions slightly larger than that of a large eyepiece like the largest Panoptics or Naglers.
I still can’t figure out how Pegasus Astro managed to fit the electronics into their small eyepiece that can perform live stacking, they must have designed a custom CPU board.
