This is the second of three posts on a processing technique I call the synthetic blue channel method. This first post can be found in the Loony Bin here:
https://www.cloudyni...channel-method/
I won't go into the details of why this works here, just tell you how to do it and provide some examples. To understand why it works, see the first thread.
So you have an achromat that you'd like to image planets with, but it has nasty chromatic aberration. The chromatic aberration produces a blue/violet glow around the planet and turns them yellow and magenta. You can black clip out the blue glow, but the yellow/magenta tone is difficult to deal with. It occurs because the blue channel is out of focus, spreading the blue from the bright highlights around, turning the highlights yellow and turning the shadows blue and the belts and GRS of Jupiter magenta.
How can you fix this? Simple. Throw out the blue channel, and replace it with a synthetic one, created from the green and red channels:
B_synthetic = 2G - R
That's it. Process as normal from there.
Some examples.
Here are some of my planetary images, imaged with my 1100 EdgeHD. Note that it does not show CA; these are control cases to determine how well the method can reproduce the full color image.
Original on the left, synthetic blue channel method on the right.
Note that the reds become a bit more orange on Jupiter. This is pretty clear here because I prefer high saturation images. But the result is not unpleasant.
Here's Saturn:
Mars:
Again, these examples do not use ANY of the data from the original blue channel.
Next up, actual images from achromats.
