Here is a progress report.
There was only less than 1/2 day available for construction. But I was able secure all the rafters and add two more purlins to the structure. As work on the roof has progressed I'm beginning to get the knack of how to install the hollow-wall anchors that secure the purlins to the metal rafters. These light duty connectors were never meant to be structural members. But they should do the job if I add one or more sheet metal screws at each location.
So here are a few things I've learned in the process. It is difficult to get these anchors to fully tighten down on the purlins. One problem is that if one isn't careful, the washers on the Phillips-screw end will spin in the wood surface. The washers have short spikes that are meant to protrude into the wood to secure it. But it can just as easily spin and auger out the wood surface. So I'm now holding the washer end with a vice-grip to prevent its spinning. Once the anchor begins to pull the wood down onto the metal rafter, the washer is allowed to pull into the wood without damage to that surface.
So after struggling with many of the hollow-wall actors, the technique I use is now working well. But another issue has become apparent. The washer itself is extremely light duty and barely larger than the size of the hole needed to insert the anchor. So I intend to remove all the Phillips-screws and add a larger washer that will make it unlikely the anchor will pull through the wood. Now I feel that very high wind loads could still rip the roof off. Such is the fate of a self-designed "simple observatory". But should there be forecasts of gale- or storm-force winds, you can bet I'll do whatever I can to keep the roof in place. Why even a couple nylon straps wrapped over the roof, down around more solid wall structures would help a lot.
In any case here are some more photos.
Just three more purlins to go.
A few days ago when the walls were covered with a tarp another issue came up. Water running off the lower end of the tarp would splash up on the south wall. This isn't good even if the walls are painted. So it seemed like some sort of rain gutter would be the solution. But a gutter cannot extend down very far below the roofing, lest it run afoul of the side rails on the sliding roof track. So this is what I came up with.
This is some sort of galvanized steel flashing. Likely I'll cut off about 1/2 of the right hand side to reduce weight. The section shown on the left is 3 inches long. It will lay on top of the lower end of the metal rafters with a purlin connector holding it in place. The little rain-gutter V will route water away from the south wall.
Another slight design change:
I removed the two diagonal tension cables. They were just too much in the way for my being able get ladder access to the top side of the roof structure. After thinking things over I decided that these tension cables will not lay in straight lines from corner to corner. With the purlins secured to rafters in locations formerly occupied by the steel cables, these will now just have to find their place over the rafters and around the purlins. The resultant direction the cables end up being in really doesn't matter. Their purpose is to provide some tension at each corner to maintain the squareness of the roof structure.
The plastic wiggle-board showed up today. Tomorrow with a full day available for construction, I'l hoping to get the roofing installed before the rains on Friday.
Best Regards to All,
Russ
Edited by Rustler46, 11 April 2024 - 01:02 AM.
