Hey Ray also finally played with the C1, C2 and C3 settings on the OM-D E-M1X and will be utilizing these so no hassle at all changing exposures and HDR settings. As expected the C1, C2 and C3 will line up with the order of changes I'll need to make:
C1 - At Beginning: Rotate all cameras 22'ish degrees counter clockwise, get all lens in focus, then every 30 seconds take exposure at 1/500, f7.1, ISO 200, and silent. Controlled via the camera intervalometer. Camera remembers everything except to set this to ON. So at beginning I'll need to open that up and select ON then trip the shutter and away we go. Most likely only using TV85 and solar filter at this point. Other lens have screw on filters I'll use for focusing but I don't think I want to bother taking them off...maybe I'll use the 300 but really not much too see hear the TV85 won't more than cover.
C2 - 30 seconds prior to totality: Remove the TV85 solar filter and lens caps from 40-150 and 300, every second take 3 exposures at 1/2000, f7.1, ISO 200, +/- 2 and silent. Controlled by external intervalometer which will be set up for 60 exposures every second. So this should be easy, hear the warning, change to C2 and trip the external intervalometer.
C3 - Totality: every 8 seconds take 7 exposures at 1/15, f7.1, ISO200 7 +/-2 and silent. Controlled by the same external intervalometer where I'll need to just change the time between shots from 1 to 8, leave the count of shots to 60 since it will cover the entire time...again not so bad, remember I have 3 min and 30 seconds at this point, change to C3 and change time on intervalometer.
Coming out of totality just do things in reverse...let me know folks if this seems about right or anyone sees glaring issues. Getting my initial exposures from past sun exposures.
