I have recently bought a used Denk II with the A38 OCS and Power Switch for use primarily with an AP 130GTX and less frequently with a Starmaster 14.5in. I'll be viewing planets and the moon from home and DSOs (with the Dob) from dark skies.
Relevant 1.25in eyepieces I already own are:
TV Plossl 32, 25 (pair)
TV Nagler 9
Tak LE 7.5
Tak Abbe Ortho 12.5 (pair)
Pentax XW 7
I am interested in one eyepiece pair for low power, large FOV viewing and something to push the magnification a bit further than the Tak Abbe Ortho 12.5 when conditions allow.
Low power: I have seen the recommendation for Pan 24 often but given that the field is almost identical to Plossl 32 and magnification with the low-power OCS is 26x vs 34x, are there significant optical advantages? The difference in cost is substantial (2 Pan 24 vs 1 Plossl 32).
Medium power: I don't have any 1.25 eyepieces in the 15-20mm range, I am thinking a pair of TV Delite 18.2 or TV Pan 19 may be a nice addition. Thoughts?
High power: In my first test (seeing was pretty crummy), the Tak 12.5mm was excellent on Jupiter in the middle power OCS but not so great with the high power OCS. It could just have been seeing - I didn't take the binoviewer out and compare in mono mode - but I'd like to have something that gives me 200x or so in the middle OCS position, so roughly 9mm. What are the thoughts on the N9 for binoviewing? Alternatively, I would consider a TV Delite 9 or even the Tak Abbe Ortho 9 but I'd like to keep a slightly bigger FOV if possible. Slightly lower power, what about Pentax XW 10? Anything else that comes to mind?
Thank you for the advice!
Luca
