Adding rings will make it much easier to mount but will also add some weight and also push out the center of gravity requiring more counterweight to balance the system. As mentioned earlier, the eq8 is already near its limits
Not so sure about that.
Mark - I would expect a dovetail bar that long will twist visibly under the weight of your 12" - the one under my 10" did, when mounted like that.
I'm pretty sure Stefans one is an Intes (not an Intes-Micro) with the machined aluminium tube (yes they did turn them !) and the textured paint, exactly like my MK66 and the MK91 I had (now with Alex - which was built by Intes, though labelled as Santel).
On both the MK66 and MK91 the Russians simply tapped the holes in the aluminium and secured a base plate using a half dozen bolts - there were no nuts on the inside. To that, attach a dovetail of your choice.
I would describe it as flimsy - while it is OK to mount a 6" like that (my MK66) IMHO you could see in the MK91 that the OTA distorts in some positions around the sky.
I would expect Stefans is the same.
The best arrangement I've seen - bar none - are the rings Matthias Wirth made for my 10". They are quite light (unlike the hideous cast monsters from Parallax) and the OTA sits quite snug on the dovetail under - there is no height penalty.
The other thing is the dovetail. Originally I had a long Losmandy dovetail with the rings as far apart as possible. With the dec axis horizontal, looking along the dovetail the ends were visibly twisting, which was a bit of a surprise.
Subsequently I replaced that with shorter dovetails very close to the length of the dovetail clamp on my mount, the point being that these transfer the load from the rings to the jaws of the clamp without any length in between that can twist. And guess what - the cone error vanished and the whole assembly is very rigid.
In Stefans position I'd suggest measuring the diameter of the OTA carefully, add 2-3mm to be sure (you can fill that with felt anyway) and then ask Markus to get in touch with Matthias Wirth and ask if he could make a set of rings like the ones he supplied for my 10".
Stefan if you want to go this route I'll provide details of the purchase from APM so Markus will know exactly which scope this is, and make sure you ask for 6mm drilled and tapped holes spaced to suit the dovetail.
The dovetail I use is https://www.sidereal...dovetail-200mm/... and the hole spacings for the rings were 55mm.
Lastly the rings make it very easy to piggyback another scope (eg small refractor) for wide field imaging.
Edited by luxo II, 20 February 2024 - 08:48 PM.
