While it is definitely true that a binoviewer will make the ~50 degree field of view of Plossls feel wider, the same thing applies all the way up.
A pair of super wide eyepieces feel like ultra-wide, and a pair of ultra-wide eyepieces feel like the telescope just goes away and you’re just looking up at the sky with your bare eyes.
Typically, eye placement becomes trickier the wider the apparent field of view of the eyepiece is, and having proper eye placement for both eyes simultaneously is significantly trickier than for just one eye, so ultimately there is a balance to be made between apparent field of view and ease of eye placement/ergonomics.
For some people, the ideal balance favors narrow fields of view and easy eye placement, while others prefer a more space walk feeling at the expense of being very precise with viewing positioning and maneuvering as you look from one edge of the field of view to the other.
Your personal preference will probably also change depending on the target or how tired your are, or even your mood.
Binoviewers are a black hole for eyepieces…
That being said, you can’t go wrong with a pair of Plossls.
And that being said, I’m waiting on a second 25mm Xcel-lx to be delivered to see if I like them better than Plossls.
Mind you, I have pairs of the following already:
30mm Ultrascopics (I really wanted to like these, but eye relief is uncomfortably long and eye placement is very finicky)
26mm Plossls (lenses are too narrow and the eye lens vignettes the view due to the increased eye relief from the binoviewer OCS)
25mm Vixen NPL (adjustable eye guards are garbage and don’t stay where you put them, field of view is restrictive for a Plossl at 50 degrees vs. the 52 degrees that most other Plossls are)
I had previously bought a pair of 27mm Flat Field eyepieces a while back from Amazon, but I returned them because at the time I had a binoviewer with smaller clear aperture and they vignetted pretty badly.
I was thinking of giving them a try again because I remember eye placement being very easy, but then the 25mm Xcel-lx kept being mentioned in threads I was reading, always in a positive context, and it’s supposed to be optically identical to the now discontinued Meade 5000 60 degree eyepieces that had great reviews back in the day for sharpness, contrast, as well as off-axis correction in fast scopes.
