It's funny, I hear a lot about the quality of the build, and beauty of the scope itself, but I rarely see an image generated from one of them that can't be easily beaten by a scope 1/10 of the price. Have you?
What is the point of this discussion? There was never a time, where you couldn't easily buy a scope far cheaper than the Questar, that not only matched it, but wildly outperformed it optically. This is as true today, as it was in 1960. Everyone knows that. No one denies it (if they're honest with themselves).
Now, I don't own a Questar, and have only used one for a few hours, but I do own something else: A $3000 63mm Zeiss achromat. Yes, I own, and use, a 63mm scope that has cost me over $3k. Why on Earth would I have spent so much money on such a small scope, you may ask? Because it gives me great joy and pleasure to use it, as well as to look at, when I'm not using it. For others, it would likely have made much more sense to spend it on a large Dobsonian, or something like that, but for me, the small scope has been just right. And so is the case with many Questar owners, I believe. It's right for them, because it gives them joy and pleasure to use it. I've literally used the little Zeiss thousands of hours, but only taken very few pictures with it that I've published. It's not really built for that, but for visual observing (and I'm primarily also just interested in visual observing). Something similar is likely the case for most Questar owners: They're primarily visual observers, and the scope is also optimized for that.
You don't need to spend much to get a good telescope, thank God, but if you have the means to afford it, I don't see anything wrong in going for the very best you can afford. You may not understand the choice others make, but that doesn't mean they've made a wrong one.
Clear skies!
Thomas, Denmark
